Classes | |
| class | Gudhi::persistence_matrix::FieldOperators |
| Concept of the field operator classes needed for the class Matrix. More... | |
| class | Gudhi::persistence_matrix::PersistenceMatrixColumn |
Concept of the column classes used by the Matrix class. The classes the columns inheritates from are either real or dummy classes, see Row_access_option, Column_dimension_option, Chain_column_option. If used with column compression, the column type has to have its std::hash method. More... | |
| struct | Gudhi::persistence_matrix::PersistenceMatrixOptions |
| Concept of the template parameter for the class Matrix. More... | |
| struct | Gudhi::persistence_matrix::New_cell_constructor< Cell > |
| Cell factory. Constructs and destroyes cell pointers with new and delete. More... | |
| struct | Gudhi::persistence_matrix::Pool_cell_constructor< Cell > |
| Cell factory. Uses Gudhi::Simple_object_pool, which is based on boost::object_pool, to construct and destroy cell pointer. More... | |
| struct | Gudhi::persistence_matrix::Dummy_base_pairing |
| Empty structure. Inheritated instead of Base_pairing, when the computation of the barcode was not enabled or if the pairing is already managed by the vine update classes. More... | |
| struct | Gudhi::persistence_matrix::Dummy_base_swap |
| Empty structure. Inheritated instead of Base_swap, when the column and row swaps are not enabled. More... | |
| struct | Gudhi::persistence_matrix::Dummy_chain_pairing |
| Empty structure. Inheritated instead of Chain_pairing, when the computation of the barcode was not enabled or if the pairing is already managed by the vine update classes. More... | |
| struct | Gudhi::persistence_matrix::Dummy_chain_representative_cycles |
| Empty structure. Inheritated instead of Chain_representative_cycles, when the computation of the representative cycles were not enabled. More... | |
| struct | Gudhi::persistence_matrix::Dummy_chain_vine_swap |
| Empty structure. Inheritated instead of Chain_vine_swap, when vine swappes are not enabled. More... | |
| struct | Gudhi::persistence_matrix::Dummy_chain_vine_pairing |
| Empty structure. Inheritated instead of Chain_barcode_swap, when the barcode is not stored. More... | |
| class | Gudhi::persistence_matrix::Chain_barcode_swap< Master_matrix > |
| Class managing the barcode for Chain_vine_swap. More... | |
| struct | Gudhi::persistence_matrix::Dummy_cell_column_index_mixin |
| Empty structure. Inheritated instead of Cell_column_index, when the row access is disabled. More... | |
| struct | Gudhi::persistence_matrix::Dummy_cell_field_element_mixin |
| Empty structure. Inheritated instead of Cell_field_element, when PersistenceMatrixOptions::is_z2 is true. More... | |
| class | Gudhi::persistence_matrix::Cell_column_index< index > |
| Class managing the column index access of a cell. More... | |
| class | Gudhi::persistence_matrix::Cell_field_element< Field_element_type > |
| Class managing the value access of a cell. More... | |
| struct | std::hash< Gudhi::persistence_matrix::Cell< Master_matrix > > |
| Hash method for Gudhi::persistence_matrix::Cell. More... | |
| struct | Gudhi::persistence_matrix::Dummy_chain_properties |
| Empty structure. Inheritated instead of Chain_column_extra_properties, when the columns are not meant for chain matrices. More... | |
| struct | Gudhi::persistence_matrix::Dummy_dimension_holder |
| Empty structure. Inheritated instead of Column_dimension_holder, when the columns are not storing a dimension. More... | |
| struct | std::hash< Gudhi::persistence_matrix::Heap_column< Master_matrix > > |
| Hash method for Gudhi::persistence_matrix::Heap_column. More... | |
| struct | std::hash< Gudhi::persistence_matrix::Intrusive_list_column< Master_matrix > > |
| Hash method for Gudhi::persistence_matrix::Intrusive_list_column. More... | |
| struct | std::hash< Gudhi::persistence_matrix::Intrusive_set_column< Master_matrix > > |
| Hash method for Gudhi::persistence_matrix::Intrusive_set_column. More... | |
| struct | std::hash< Gudhi::persistence_matrix::List_column< Master_matrix > > |
| Hash method for Gudhi::persistence_matrix::List_column. More... | |
| struct | std::hash< Gudhi::persistence_matrix::Naive_vector_column< Master_matrix > > |
| Hash method for Gudhi::persistence_matrix::Naive_vector_column. More... | |
| struct | Gudhi::persistence_matrix::Dummy_row_access |
| Empty structure. Inheritated instead of Row_access, if the row access is not enabled. More... | |
| struct | std::hash< Gudhi::persistence_matrix::Set_column< Master_matrix > > |
| Hash method for Gudhi::persistence_matrix::Set_column. More... | |
| struct | std::hash< Gudhi::persistence_matrix::Unordered_set_column< Master_matrix > > |
| Hash method for Gudhi::persistence_matrix::Unordered_set_column. More... | |
| struct | std::hash< Gudhi::persistence_matrix::Vector_column< Master_matrix > > |
| Hash method for Gudhi::persistence_matrix::Vector_column. More... | |
| struct | Gudhi::persistence_matrix::Dummy_matrix_dimension_holder |
| Empty structure. Inheritated instead of Matrix_max_dimension_holder or Matrix_all_dimension_holder, when the maximal dimension of a matrix is not stored. More... | |
| class | Gudhi::persistence_matrix::Matrix_max_dimension_holder< dimension_type > |
| Class managing the maximal dimension of a face represented in the inheritating matrix, when the option of face removal is not enabled. More... | |
| class | Gudhi::persistence_matrix::Matrix_all_dimension_holder< dimension_type > |
| Class managing the maximal dimension of a face represented in the inheritating matrix, when the option of face removal is enabled. More... | |
| struct | Gudhi::persistence_matrix::Dummy_matrix_row_access |
| Empty structure. Inheritated instead of Matrix_row_access, when the the row access is not enabled. More... | |
| struct | Gudhi::persistence_matrix::Dummy_ru_pairing |
| Empty structure. Inheritated instead of RU_pairing, when the computation of the barcode was not enabled or if the pairing is already managed by the vine update classes. More... | |
| struct | Gudhi::persistence_matrix::Dummy_ru_representative_cycles |
| Empty structure. Inheritated instead of RU_representative_cycles, when the computation of the representative cycles were not enabled. More... | |
| struct | Gudhi::persistence_matrix::Dummy_ru_vine_swap |
| Empty structure. Inheritated instead of RU_vine_swap, when vine swappes are not enabled. More... | |
| struct | Gudhi::persistence_matrix::Dummy_ru_vine_pairing |
| Empty structure. Inheritated instead of RU_pairing, when the barcode is not stored. More... | |
| class | Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions > |
| Data structure for matrices, and in particular thought for matrices representing filtered complexes in order to compute persistence and/or representative cycles. More... | |
| class | Gudhi::persistence_matrix::Base_matrix< Master_matrix > |
| A basic matrix structure allowing to easily manipulate and access entire columns and rows, but not individual cells. More... | |
| class | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > |
| A base matrix (also see Base_matrix), but with column compression. That is, all identical columns in the matrix are compressed together as the same column. For matrices with a lot of redundant columns, this will save a lot of space. Also, any addition made onto a column will be performed at the same time on all other identical columns, which is an advantage for the cohomology algorithm for example. More... | |
| class | Gudhi::persistence_matrix::Base_pairing< Master_matrix > |
| Class managing the barcode for Boundary_matrix if the option was enabled. More... | |
| class | Gudhi::persistence_matrix::Base_swap< Master_matrix, Base_matrix > |
| Class managing the column and row swaps in Base_matrix and Boundary_matrix. More... | |
| class | Gudhi::persistence_matrix::Boundary_matrix< Master_matrix > |
| Matrix structure to store the ordered boundary matrix \( R \) of a filtered complex in order to compute its persistent homology. Provides an access to its columns and rows as well as the possibility to remove the last faces of the filtration while maintaining a valid barcode. More... | |
| class | Gudhi::persistence_matrix::Chain_matrix< Master_matrix > |
| Matrix structure storing a compatible base of a filtered chain complex. See [41]. The base is constructed from the boundaries of the faces in the complex. Allows the persistent homology to be computed, as well as representative cycles. Supports vineyards (see [21]) and the removal of maximal faces while maintaining a valid barcode. Provides an access to its columns and rows. More... | |
| class | Gudhi::persistence_matrix::Chain_pairing< Master_matrix > |
| Class managing the barcode for Chain_matrix if the option was enabled. More... | |
| class | Gudhi::persistence_matrix::Chain_representative_cycles< Master_matrix > |
| Class managing the representative cycles for Chain_matrix if the option was enabled. More... | |
| class | Gudhi::persistence_matrix::Chain_vine_swap< Master_matrix > |
| Class managing the vine swaps for Chain_matrix. More... | |
| class | Gudhi::persistence_matrix::Cell< Master_matrix > |
| Matrix cell class. Stores by default only the row index it belongs to, but can also store its column index when the row access is enabled, as well as its value when they are different from only 0 and 1. Zero-valued cells are never explicited in the matrix. More... | |
| class | Gudhi::persistence_matrix::Chain_column_extra_properties< Master_matrix > |
| Class managing the pivot and partitioning of columns in Chain_matrix. More... | |
| class | Gudhi::persistence_matrix::Column_dimension_holder< Master_matrix > |
| Class managing the dimension access of a column. More... | |
| class | Gudhi::persistence_matrix::Heap_column< Master_matrix > |
| Column class following the PersistenceMatrixColumn concept. Not compatible with row access. More... | |
| class | Gudhi::persistence_matrix::Intrusive_list_column< Master_matrix > |
| Column class following the PersistenceMatrixColumn concept. More... | |
| class | Gudhi::persistence_matrix::Intrusive_set_column< Master_matrix > |
| class | Gudhi::persistence_matrix::List_column< Master_matrix > |
| class | Gudhi::persistence_matrix::Naive_vector_column< Master_matrix > |
| class | Gudhi::persistence_matrix::Row_access< Master_matrix > |
| Class managing the row access for the columns. More... | |
| class | Gudhi::persistence_matrix::Set_column< Master_matrix > |
| class | Gudhi::persistence_matrix::Unordered_set_column< Master_matrix > |
| class | Gudhi::persistence_matrix::Vector_column< Master_matrix > |
| class | Gudhi::persistence_matrix::Matrix_row_access< Row_type, Row_container_type, has_removable_rows, id_index > |
| Class managing the row access for the inheritating matrix. More... | |
| class | Gudhi::persistence_matrix::Id_to_index_overlay< Matrix_type, Master_matrix_type > |
| Overlay for non-basic matrices replacing all input and output MatIdx indices of the original methods with IDIdx indices. More... | |
| class | Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type > |
| Overlay for chain matrices replacing all input and output MatIdx indices of the original methods with PosIdx indices. The overlay is useless for boundary matrices as MatIdx == PosIdx for them. More... | |
| class | Gudhi::persistence_matrix::RU_matrix< Master_matrix > |
| Matrix structure to store the ordered boundary matrix \( R \cdot U \) of a filtered complex in order to compute its persistent homology, as well as representative cycles. Supports vineyards (see [21]) and the removal of maximal faces while maintaining a valid barcode. Provides an access to its columns and rows. More... | |
| class | Gudhi::persistence_matrix::RU_pairing< Master_matrix > |
| Class managing the barcode for RU_matrix if the option was enabled. More... | |
| class | Gudhi::persistence_matrix::RU_representative_cycles< Master_matrix > |
| Class managing the representative cycles for RU_matrix if the option was enabled. More... | |
| class | Gudhi::persistence_matrix::RU_vine_swap< Master_matrix > |
| Class managing the vine swaps for RU_matrix. More... | |
| struct | Gudhi::persistence_matrix::Default_options< col_type, is_z2_only, FieldOperators > |
| Default option structure for Matrix class. See the PersistenceMatrixOptions concept for a more detailed description of the fields. Produces a base matrix with no enabled option. More... | |
Enumerations | |
| enum | Gudhi::persistence_matrix::Column_types { Gudhi::persistence_matrix::LIST , Gudhi::persistence_matrix::SET , Gudhi::persistence_matrix::HEAP , Gudhi::persistence_matrix::VECTOR , Gudhi::persistence_matrix::NAIVE_VECTOR , Gudhi::persistence_matrix::UNORDERED_SET , Gudhi::persistence_matrix::INTRUSIVE_LIST , Gudhi::persistence_matrix::INTRUSIVE_SET } |
| List of column types. More... | |
| enum | Gudhi::persistence_matrix::Column_indexation_types { Gudhi::persistence_matrix::CONTAINER , Gudhi::persistence_matrix::POSITION , Gudhi::persistence_matrix::IDENTIFIER } |
| List if indexation schemes. See description of indexation schemes for more details about the meaning of the indexation types. More... | |
Functions | |
| constexpr bool | Gudhi::persistence_matrix::_no_G_death_comparator ([[maybe_unused]] unsigned int columnIndex1, [[maybe_unused]] unsigned int columnIndex2) |
| Default death comparator. Simply assumes that two positive paired columns are never swapped. Which is true for the use case in zigzag persistence for example. More... | |
The module provides a data structure for matrices, in particular thought for matrices representing filtered complexes and used as backend for persistence algorithms, such at persistent homology, Persistent Cohomology, or zigzag [41].
The structure is entirely accessed via the class Matrix and it provides several functionnalities which can be enabled or disabled through a template argument following the PersistenceMatrixOptions concept. The main functionnalities are:
Here is a list of examples using the module:
| Enumerator | |
| CONTAINER | Default use of MatIdx indices. |
| POSITION | All input and output MatIdx indices are replaced with PosIdx indices. |
| IDENTIFIER | All input and output MatIdx indices are replaced with IDIdx indices. |
| Enumerator | |
| LIST | List_column: Underlying container is a std::list<Cell*>. |
| SET | Set_column: Underlying container is a std::set<Cell*>. |
| HEAP | Heap_column: Underlying container is a std::vector<Cell*> ordered as a heap. Is not compatible with row access and column compression. |
| VECTOR | Vector_column: Underlying container is a std::vector<Cell*> with a lazy removal method. |
| NAIVE_VECTOR | Naive_vector_column: Underlying container is a std::vector<Cell*>. |
| UNORDERED_SET | Unordered_set_column: Underlying container is a std::unordered_set<Cell*>. |
| INTRUSIVE_LIST | Intrusive_list_column: Underlying container is a boost::intrusive::list<Cell>. |
| INTRUSIVE_SET | Intrusive_set_column: Underlying container is a boost::intrusive::set<Cell>. |
constexpr |
| columnIndex1 | First column index. |
| columnIndex2 | Second column index. |
