Gudhi::persistence_matrix::Cell< Master_matrix > Class Template Reference
Matrix cell class. Stores by default only the row index it belongs to, but can also store its column index when the row access is enabled, as well as its value when they are different from only 0 and 1. Zero-valued cells are never explicited in the matrix. More...
Public Types
using Master = Master_matrix
using index = typename Master_matrix::index
using id_index = typename Master_matrix::id_index
using Field_element_type = typename Master_matrix::element_type
Public Member Functions
 Cell ()
 Constructs an cell with all attributes at default values.
 Cell (id_index rowIndex)
 Constructs a cell with given row index. Other possible attributes are set at default values. More...
 Cell (index columnIndex, id_index rowIndex)
 Constructs a cell with given row and column index. Other possible attributes are set at default values. More...
 Cell (const Cell &cell)
 Copy constructor. More...
 Cell (Cell &&cell) noexcept
 Move constructor. More...
id_index get_row_index () const
 Returns the row index stored in the cell. More...
void set_row_index (id_index rowIndex)
 Sets the row index stored in the cell. More...
Celloperator= (Cell other)
 Assign operator.
 operator id_index () const
 Converts the cell into a row index. More...
 operator std::pair< id_index, Field_element_type > () const
 Converts the cell into a pair of row index and cell value. More...
Friends
bool operator< (const Cell &c1, const Cell &c2)
 Strictly smaller than comparator. More...
bool operator== (const Cell &c1, const Cell &c2)
 Equality comparator. More...
Detailed Description
template<class Master_matrix>
class Gudhi::persistence_matrix::Cell< Master_matrix >
Template Parameters
Master_matrixAn instanciation of Matrix from which all types and options are deduced.
Member Typedef Documentation
◆ Field_element_type
template<class Master_matrix >
using Gudhi::persistence_matrix::Cell< Master_matrix >::Field_element_type = typename Master_matrix::element_type
Value type.
◆ id_index
using Gudhi::persistence_matrix::Cell< Master_matrix >::id_index = typename Master_matrix::id_index
Row index type.
◆ index
using Gudhi::persistence_matrix::Cell< Master_matrix >::index = typename Master_matrix::index
Column index type.
◆ Master
using Gudhi::persistence_matrix::Cell< Master_matrix >::Master = Master_matrix
Access to options from outside.
Constructor & Destructor Documentation
◆ Cell() [1/4]
Gudhi::persistence_matrix::Cell< Master_matrix >::Cell ( id_index  rowIndex)
inline
Parameters
rowIndexRow index of the cell.
◆ Cell() [2/4]
Gudhi::persistence_matrix::Cell< Master_matrix >::Cell ( index  columnIndex,
id_index  rowIndex
inline
Parameters
columnIndexColumn index of the cell.
◆ Cell() [3/4]
Gudhi::persistence_matrix::Cell< Master_matrix >::Cell ( const Cell< Master_matrix > &  cell)
inline
Copy constructor.
Parameters
cellCell to copy.
◆ Cell() [4/4]
Gudhi::persistence_matrix::Cell< Master_matrix >::Cell ( Cell< Master_matrix > &&  cell)
inlinenoexcept
Move constructor.
Parameters
cellCell to move.
Member Function Documentation
◆ get_row_index()
id_index Gudhi::persistence_matrix::Cell< Master_matrix >::get_row_index ( ) const
inline
Returns
◆ operator id_index()
Gudhi::persistence_matrix::Cell< Master_matrix >::operator id_index ( ) const
inline
Returns
The row index of the cell.
◆ operator std::pair< id_index, Field_element_type >()
Gudhi::persistence_matrix::Cell< Master_matrix >::operator std::pair< id_index, Field_element_type > ( ) const
inline
Returns
A std::pair with first element the row index and second element the value.
◆ set_row_index()
void Gudhi::persistence_matrix::Cell< Master_matrix >::set_row_index ( id_index  rowIndex)
inline
Parameters
Friends And Related Function Documentation
◆ operator<
bool operator< ( const Cell< Master_matrix > &  c1,
const Cell< Master_matrix > &  c2
friend
Parameters
c1First cell to compare.
c2Second cell to compare.
Returns
true If the row index of the first cell is strictly smaller than the row index of the second cell.
false Otherwise.
◆ operator==
bool operator== ( const Cell< Master_matrix > &  c1,
friend
Parameters
Returns
true If the row index of the first cell is equal to the row index of the second cell.
false Otherwise.
The documentation for this class was generated from the following file:
