Data structure for matrices, and in particular thought for matrices representing filtered complexes in order to compute persistence and/or representative cycles. More...
Classes | |
| struct | Bar |
| Type for a bar in the computed barcode. Stores the birth, death and dimension of the bar. More... | |
| struct | RowCellComp |
| Compaires two cells by their position in the row. They are assume to be in the same row. More... | |
Public Types | |
| using | index = typename PersistenceMatrixOptions::index_type |
| using | id_index = typename PersistenceMatrixOptions::index_type |
| using | pos_index = typename PersistenceMatrixOptions::index_type |
| using | dimension_type = typename PersistenceMatrixOptions::dimension_type |
| using | Field_operators = typename std::conditional< PersistenceMatrixOptions::is_z2, Gudhi::persistence_fields::Z2_field_operators, typename PersistenceMatrixOptions::Field_coeff_operators >::type |
| Coefficiants field type. | |
| using | element_type = typename Field_operators::element_type |
| Type of a field element. | |
| using | Cell_type = Cell< Matrix< PersistenceMatrixOptions > > |
| Type of a matrix cell. See Cell for a more detailed description. | |
| using | Cell_constructor = Pool_cell_constructor< Cell_type > |
| Cell constructor/destructor used by the matrix. Uses a pool of cells to accelerate memory management, as cells are constructed and destroyed a lot during reduction, swaps or additions. | |
| using | cell_rep_type = typename std::conditional< PersistenceMatrixOptions::is_z2, id_index, std::pair< id_index, element_type > >::type |
| Type used to identify a cell, for exemple when inserting a boundary. If PersistenceMatrixOptions::is_z2 is true, the type is an IDIdx and corresponds to the row index of the cell (the cell value is assumed to be 1). If PersistenceMatrixOptions::is_z2 is false, the type is a pair whose first element is the row index of the cell and the second element is the value of the cell (which again is assumed to be non-zero). The column index of the row is always deduced from the context in which the type is used. | |
| using | Row_type = typename std::conditional< PersistenceMatrixOptions::has_intrusive_rows, boost::intrusive::list< Cell_type, boost::intrusive::constant_time_size< false >, boost::intrusive::base_hook< base_hook_matrix_row > >, std::set< Cell_type, RowCellComp > >::type |
| Type of the rows stored in the matrix. Is either an intrusive list of Cell_type (not ordered) if PersistenceMatrixOptions::has_intrusive_rows is true, or a set of Cell_type (ordered by get_column_index) otherwise. | |
| using | Column_type = typename std::conditional< PersistenceMatrixOptions::column_type==Column_types::HEAP, Heap_column_type, typename std::conditional< PersistenceMatrixOptions::column_type==Column_types::LIST, List_column_type, typename std::conditional< PersistenceMatrixOptions::column_type==Column_types::SET, Set_column_type, typename std::conditional< PersistenceMatrixOptions::column_type==Column_types::UNORDERED_SET, Unordered_set_column_type, typename std::conditional< PersistenceMatrixOptions::column_type==Column_types::VECTOR, Vector_column_type, typename std::conditional< PersistenceMatrixOptions::column_type==Column_types::INTRUSIVE_LIST, Intrusive_list_column_type, typename std::conditional< PersistenceMatrixOptions::column_type==Column_types::NAIVE_VECTOR, Naive_vector_column_type, Intrusive_set_column_type >::type >::type >::type >::type >::type >::type >::type |
| Type of the columns stored in the matrix. The type depends on the value of PersistenceMatrixOptions::column_type defined in the given options. See Column_types for a more detailed description. All columns follow the PersistenceMatrixColumn concept. | |
| using | barcode_type = typename std::conditional< hasFixedBarcode, std::vector< Bar >, typename std::conditional< PersistenceMatrixOptions::has_removable_columns, std::list< Bar >, std::vector< Bar > >::type >::type |
| Type of the computed barcode. It is either a list of Matrix::Bar or a vector of Matrix::Bar, depending if bars need to be removed from the container as some point or not. | |
| using | cycle_type = std::vector< id_index > |
| Type of a representative cycle. Vector of row indices. | |
Public Member Functions | |
| Matrix () | |
| Default constructor. Initializes an empty matrix. | |
| template<class Container_type = boundary_type> | |
| Matrix (const std::vector< Container_type > &columns, characteristic_type characteristic=11) | |
| Constructs a new matrix from the given ranges of cell_rep_type. Each range corresponds to a column (the order of the ranges are preserved). The content of the ranges is assumed to be sorted by increasing IDs. If the columns are representing a boundary matrix, the IDs of the simplices are also assumed to be consecutifs, ordered by filtration value, starting with 0. More... | |
| Matrix (int numberOfColumns, characteristic_type characteristic=static_cast< characteristic_type >(-1)) | |
| Constructs a new empty matrix and reserves space for the given number of columns. More... | |
| Matrix (const std::function< bool(pos_index, pos_index)> &birthComparator, const std::function< bool(pos_index, pos_index)> &deathComparator) | |
| Constructs a new empty matrix with the given comparator functions. Only available when those comparators are necessary. More... | |
| template<class Boundary_type = boundary_type> | |
| Matrix (const std::vector< Boundary_type > &orderedBoundaries, const std::function< bool(pos_index, pos_index)> &birthComparator, const std::function< bool(pos_index, pos_index)> &deathComparator, characteristic_type characteristic=11) | |
| Constructs a new matrix from the given ranges with the given comparator functions. Only available when those comparators are necessary. More... | |
| Matrix (unsigned int numberOfColumns, const std::function< bool(pos_index, pos_index)> &birthComparator, const std::function< bool(pos_index, pos_index)> &deathComparator, characteristic_type characteristic=static_cast< characteristic_type >(-1)) | |
| Constructs a new empty matrix and reserves space for the given number of columns. Only available when those comparators are necessary. More... | |
| Matrix (const Matrix &matrixToCopy) | |
| Copy constructor. More... | |
| Matrix (Matrix &&other) noexcept | |
| Move constructor. After the move, the given matrix will be empty. More... | |
| void | set_characteristic (characteristic_type characteristic) |
| Sets the characteristic of the coefficient field if PersistenceMatrixOptions::is_z2 is false, does nothing otherwise. Should be used if no characteristic could be specified at the creation of the empty matrix. Do not change the value of the characteristic once used. More... | |
| template<class Container_type > | |
| void | insert_column (const Container_type &column) |
| Inserts a new ordered column at the end of the matrix by copying the given range of cell_rep_type. The content of the range is assumed to be sorted by increasing ID value. More... | |
| void | insert_column (const Container_type &column, index columnIndex) |
| Inserts a new ordered column at the given index by copying the given range of cell_rep_type. There should not be any other column inserted at that index which was not explicitely removed before. The content of the range is assumed to be sorted by increasing ID value. More... | |
| insertion_return_type | insert_boundary (const Boundary_type &boundary, dimension_type dim=-1) |
| Inserts at the end of the matrix a new ordered column corresponding to the given boundary. This means that it is assumed that this method is called on boundaries in the order of the filtration. It also assumes that the faces in the given boundary are identified by their relative position in the filtration, starting at 0. If it is not the case, use the other insert_boundary instead by indicating the face ID used in the boundaries when the face is inserted. More... | |
| template<class Boundary_type > | |
| insertion_return_type | insert_boundary (id_index faceIndex, const Boundary_type &boundary, dimension_type dim=-1) |
| Only avalaible for non-basic matrices. It does the same as the other version, but allows the boundary faces to be identified without restrictions except that all IDs have to be strictly increasing in the order of filtration. Note that you should avoid then to use the other insertion method to avoid overwriting IDs. More... | |
| returned_column_type & | get_column (index columnIndex) |
| Returns the column at the given MatIdx index. For RU matrices, is equivalent to get_column(columnIndex, true). The type of the column depends on the choosen options, see PersistenceMatrixOptions::column_type. More... | |
| const Column_type & | get_column (index columnIndex) const |
| Only available for chain matrices. Returns the column at the given MatIdx index. The type of the column depends on the choosen options, see PersistenceMatrixOptions::column_type. More... | |
| const Column_type & | get_column (index columnIndex, bool inR) |
Only available for RU matrices without Column_indexation_types::IDENTIFIER indexing. Returns the column at the given MatIdx index in \( R \) if inR is true and in \( U \) if inR is false. The type of the column depends on the choosen options, see PersistenceMatrixOptions::column_type. More... | |
| returned_row_type & | get_row (id_index rowIndex) |
| Only available if PersistenceMatrixOptions::has_row_access is true. Returns the row at the given row index. For RU matrices, is equivalent to get_row(columnIndex, true). The type of the row depends on the choosen options, see PersistenceMatrixOptions::has_intrusive_rows. More... | |
| const Row_type & | get_row (id_index rowIndex) const |
| Only available for chain matrices and matrices with column compression. Returns the row at the given row index. The type of the row depends on the choosen options, see PersistenceMatrixOptions::has_intrusive_rows. More... | |
| const Row_type & | get_row (id_index rowIndex, bool inR) |
Only available for RU matrices without Column_indexation_types::IDENTIFIER indexing. Returns the row at the given row index in \( R \) if inR is true and in \( U \) if inR is false. The type of the row depends on the choosen options, see PersistenceMatrixOptions::has_intrusive_rows. More... | |
| void | remove_column (index columnIndex) |
| Only available for base matrices without column compression and if PersistenceMatrixOptions::has_map_column_container is true. Otherwise, see remove_last. Erases the given column from the matrix. If PersistenceMatrixOptions::has_row_access is also true, the deleted column cells are also automatically removed from their respective rows. More... | |
| void | erase_empty_row (id_index rowIndex) |
| The effect varies depending on the matrices and the options: More... | |
| void | remove_maximal_face (index columnIndex) |
| Only available for RU and chain matrices and if PersistenceMatrixOptions::has_removable_columns and PersistenceMatrixOptions::has_vine_update are true. For chain matrices, PersistenceMatrixOptions::has_map_column_container and PersistenceMatrixOptions::has_column_pairings also need to be true. Assumes that the face is maximal in the current complex and removes it such that the matrix remains consistent (i.e., RU is still an upper triangular decomposition of the boundary matrix and chain is still a compatible bases of the chain complex in the sense of [41]). The maximality of the face is not verified. Also updates the barcode if it was computed. More... | |
| void | remove_maximal_face (id_index faceIndex, const std::vector< id_index > &columnsToSwap) |
| Only available for chain matrices and if PersistenceMatrixOptions::has_removable_columns, PersistenceMatrixOptions::has_vine_update and PersistenceMatrixOptions::has_map_column_container are true. Assumes that the face is maximal in the current complex and removes it such that the matrix remains consistent (i.e., it is still a compatible bases of the chain complex in the sense of [41]). The maximality of the face is not verified. Also updates the barcode if it was computed. More... | |
| void | remove_last () |
| Removes the last inserted column/face from the matrix. If the matrix is non basic, PersistenceMatrixOptions::has_removable_columns has to be true for the method to be available. Additionnaly, if the matrix is a chain matrix, either PersistenceMatrixOptions::has_map_column_container has to be true or PersistenceMatrixOptions::has_vine_update has to be false. And if the matrix is a base matrix it should be without column compression. More... | |
| dimension_type | get_max_dimension () const |
| Returns the maximal dimension of a face stored in the matrix. Only available for non-basic matrices and if PersistenceMatrixOptions::has_matrix_maximal_dimension_access is true. More... | |
| index | get_number_of_columns () const |
| Returns the current number of columns in the matrix. More... | |
| dimension_type | get_column_dimension (index columnIndex) const |
| Returns the dimension of the given face. Only available for non-basic matrices. More... | |
| template<typename Index_type > | |
| std::enable_if_t< std::is_integral_v< Index_type > > | add_to (Index_type sourceColumnIndex, Index_type targetColumnIndex) |
Adds column at sourceColumnIndex onto the column at targetColumnIndex in the matrix. Is available for every matrix type, but should be used with care with non-basic matrices, as they will be no verification to ensure that the addition makes sense for the meaning of the underlying object. For example, a right-to-left addition could corrupt the computation of the barcode or the representative cycles if done blindly. More... | |
| template<class Cell_range > | |
| std::enable_if_t<!std::is_integral_v< Cell_range > > | add_to (const Cell_range &sourceColumn, index targetColumnIndex) |
Adds the given range of Cell onto the column at targetColumnIndex in the matrix. Only available for basic matrices. More... | |
| std::enable_if_t< std::is_integral_v< Index_type > > | multiply_target_and_add_to (Index_type sourceColumnIndex, int coefficient, Index_type targetColumnIndex) |
Multiplies the target column with the coefficient and then adds the source column to it. That is: targetColumn = (targetColumn * coefficient) + sourceColumn. Is available for every matrix type, but should be used with care with non-basic matrices, as they will be no verification to ensure that the addition makes sense for the meaning of the underlying object. For example, a right-to-left addition could corrupt the computation of the barcode or the representative cycles if done blindly. More... | |
| std::enable_if_t<!std::is_integral_v< Cell_range > > | multiply_target_and_add_to (const Cell_range &sourceColumn, int coefficient, index targetColumnIndex) |
Multiplies the target column with the coefficient and then adds the given range of Cell to it. That is: targetColumn = (targetColumn * coefficient) + sourceColumn. Only available for basic matrices. More... | |
| std::enable_if_t< std::is_integral_v< Index_type > > | multiply_source_and_add_to (int coefficient, Index_type sourceColumnIndex, Index_type targetColumnIndex) |
Multiplies the source column with the coefficient before adding it to the target column. That is: targetColumn += (coefficient * sourceColumn). The source column will not be modified. Is available for every matrix type, but should be used with care with non-basic matrices, as they will be no verification to ensure that the addition makes sense for the meaning of the underlying object. For example, a right-to-left addition could corrupt the computation of the barcode or the representative cycles if done blindly. More... | |
| std::enable_if_t<!std::is_integral_v< Cell_range > > | multiply_source_and_add_to (int coefficient, const Cell_range &sourceColumn, index targetColumnIndex) |
Multiplies the source column with the coefficient before adding it to the target column. That is: targetColumn += (coefficient * sourceColumn). The source column will not be modified. Only available for basic matrices. More... | |
| void | zero_cell (index columnIndex, id_index rowIndex) |
| Zeroes the cell at the given coordinates. Not available for chain matrices and for base matrices with column compression. In general, should be used with care with non-basic matrices to not destroy the validity of the persistence related properties of the matrix. More... | |
| void | zero_cell (index columnIndex, id_index rowIndex, bool inR) |
Only available for RU matrices. Zeroes the cell at the given coordinates in \( R \) if inR is true or in \( U \) if inR is false. Should be used with care to not destroy the validity of the persistence related properties of the matrix. More... | |
| void | zero_column (index columnIndex) |
| Zeroes the column at the given index. Not available for chain matrices and for base matrices with column compression. In general, should be used with care with non-basic matrices to not destroy the validity of the persistence related properties of the matrix. More... | |
| void | zero_column (index columnIndex, bool inR) |
Only available for RU matrices. Zeroes the column at the given index in \( R \) if inR is true or in \( U \) if inR is false. Should be used with care to not destroy the validity of the persistence related properties of the matrix. More... | |
| bool | is_zero_cell (index columnIndex, id_index rowIndex) |
| Indicates if the cell at given coordinates has value zero. More... | |
| bool | is_zero_cell (index columnIndex, id_index rowIndex, bool inR) const |
Only available for RU matrices. Indicates if the cell at given coordinates has value zero in \( R \) if inR is true or in \( U \) if inR is false. More... | |
| bool | is_zero_column (index columnIndex) |
| Indicates if the column at given index has value zero. More... | |
| bool | is_zero_column (index columnIndex, bool inR) |
Only available for RU matrices. Indicates if the column at given index has value zero in \( R \) if inR is true or in \( U \) if inR is false. More... | |
| index | get_column_with_pivot (id_index faceIndex) const |
| Returns the MatIdx index of the column which has the given row index as pivot. Only available for RU and chain matrices. Assumes that the pivot exists. For RU matrices, the column is returned from \( R \). More... | |
| id_index | get_pivot (index columnIndex) |
| Returns the row index of the pivot of the given column. Only available for non-basic matrices. More... | |
| Matrix & | operator= (Matrix other) |
| Assign operator. More... | |
| const barcode_type & | get_current_barcode () |
| Returns the current barcode of the matrix. Available only if PersistenceMatrixOptions::has_column_pairings is true. More... | |
| const barcode_type & | get_current_barcode () const |
| void | swap_columns (index columnIndex1, index columnIndex2) |
| Only available for base matrices without column compression and simple boundary matrices (only storing \( R \)) and if PersistenceMatrixOptions::has_column_and_row_swaps is true. Swaps the two given columns. Note for boundary matrices, that it really just swaps two columns and does not update anything else, nor performs additions to maintain some properties on the matrix. More... | |
| void | swap_rows (index rowIndex1, index rowIndex2) |
| Only available for base matrices without column compression and simple boundary matrices (only storing \( R \)) and if PersistenceMatrixOptions::has_column_and_row_swaps is true. Swaps the two given rows. Note for boundary matrices, that it really just swaps two rows and does not update anything else, nor performs additions to maintain some properties on the matrix. More... | |
| bool | vine_swap_with_z_eq_1_case (pos_index index) |
| Only available if PersistenceMatrixOptions::has_vine_update is true and if it is either a bounary matrix or PersistenceMatrixOptions::column_indexation_type is set to Column_indexation_types::POSITION. Does the same than vine_swap, but assumes that the swap is non trivial and therefore skips a part of the case study. More... | |
| index | vine_swap_with_z_eq_1_case (index columnIndex1, index columnIndex2) |
| Only available if PersistenceMatrixOptions::has_vine_update is true and if it is either a chain matrix or PersistenceMatrixOptions::column_indexation_type is set to Column_indexation_types::IDENTIFIER. Does the same than vine_swap, but assumes that the swap is non-trivial and therefore skips a part of the case study. More... | |
| bool | vine_swap (pos_index index) |
Only available if PersistenceMatrixOptions::has_vine_update is true and if it is either a boundary matrix or PersistenceMatrixOptions::column_indexation_type is set to Column_indexation_types::POSITION. Does a vine swap between two faces which are consecutives in the filtration. Roughly, if \( F \) is the current filtration represented by the matrix, the method modifies the matrix such that the new state corresponds to a valid state for the filtration \( F' \) equal to \( F \) but with the two faces at position index and index + 1 swapped. Of course, the two faces should not have a face/coface relation which each other ; \( F' \) has to be a valid filtration. See [21] for more information about vine and vineyards. More... | |
| index | vine_swap (index columnIndex1, index columnIndex2) |
| Only available if PersistenceMatrixOptions::has_vine_update is true and if it is either a chain matrix or PersistenceMatrixOptions::column_indexation_type is set to Column_indexation_types::IDENTIFIER. Does a vine swap between two faces which are consecutives in the filtration. Roughly, if \( F \) is the current filtration represented by the matrix, the method modifies the matrix such that the new state corresponds to a valid state for the filtration \( F' \) equal to \( F \) but with the two given faces at swapped positions. Of course, the two faces should not have a face/coface relation which each other ; \( F' \) has to be a valid filtration. See [21] for more information about vine and vineyards. More... | |
| void | update_representative_cycles () |
| Only available if PersistenceMatrixOptions::can_retrieve_representative_cycles is true. Precomputes the representative cycles of the current state of the filtration represented by the matrix. It does not need to be called before get_representative_cycles is called for the first time, but needs to be called before calling get_representative_cycles again if the matrix was modified in between. Otherwise the old cycles will be returned. | |
| const std::vector< cycle_type > & | get_representative_cycles () |
| Only available if PersistenceMatrixOptions::can_retrieve_representative_cycles is true. Returns all representative cycles of the current filtration. More... | |
| const cycle_type & | get_representative_cycle (const Bar &bar) |
| Only available if PersistenceMatrixOptions::can_retrieve_representative_cycles is true. Returns the cycle representing the given bar. More... | |
Static Public Attributes | |
| static New_cell_constructor< Cell_type > | defaultCellConstructor |
| Default cell constructor/destructor, using classic new and delete. For now, only used as default value for columns constructed independently outside of the matrix by the user. Could be used in the futur when parallel options are implemented, as usual pools are not thread safe. | |
Friends | |
| void | swap (Matrix &matrix1, Matrix &matrix2) |
| Swap operator for two matrices. More... | |
The are roughly three types of matrices available and one is selected automatically depending on the options chosen:
The indexation system for columns of the different matrix types can be a bit tricky and different methods will not always take the same type of index as input (for optimization purposes). So, to avoid confusion, we will name and define here the different possibilities, such that we can directly refer to it in the descriptions of the methods. Note that every column and row in a boundary or chain matrix is always associated to a single simplex/face, so in order to avoid repeating formulations like "of the simplex associated to the column" all the time, we will amalgamate both notions together.
Let \( c \) be a column.
In conclusion, with default values, if no vine swaps or removals occurs, all three indexing schemes are the same.
Let \( r \) be a row. Rows are indexed in two ways depending only if the matrix is a chain matrix or not. If the matrix is a chain matrix, \( r \) is always indexed by its ID, so it correspond to the IDIdx indexing scheme. If the matrix is not a chain matrix, \( r \) will originaly also be indexed by the ID, but when a swap occurs, the rows also swap IDs and the new ID has to be used to access \( r \). This means that when the default IDIdx scheme is used (the faces are numerated in order of appearence in the filtration starting at 0), the indexation of the rows correspond to PosIdx.
| PersistenceMatrixOptions | Structure encoding all the options of the matrix. See description of PersistenceMatrixOptions for more details. |
| using Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions >::dimension_type = typename PersistenceMatrixOptions::dimension_type |
Type for dimension value.
| using Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions >::id_index = typename PersistenceMatrixOptions::index_type |
Type of IDIdx index.
| using Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions >::index = typename PersistenceMatrixOptions::index_type |
Type of MatIdx index.
| using Gudhi::persistence_matrix::Matrix< PersistenceMatrixOptions >::pos_index = typename PersistenceMatrixOptions::index_type |
Type of PosIdx index.
inline |
See matrix descriptions for futher details on how the given matrix is handled.
| Container_type | Range type for cell_rep_type ranges. Assumed to have a begin(), end() and size() method. |
| columns | For a base matrix, the columns are copied as is. If options related to homology are activated, columns is interpreted as a boundary matrix of a simplicial complex. In this case, columns[i] should store the boundary of simplex i as an ordered list of indices of its facets (again those indices correspond to their respective position in the matrix). Therefore the indices of the simplices are assumed to be consecutifs and starting with 0 (an empty boundary is interpreted as a vertex boundary and not as a non existing simplex). All dimensions up to the maximal dimension of interest have to be present. If only a higher dimension is of interest and not everything should be stored, then use the insert_boundary method instead (after creating the matrix with the Matrix(int numberOfColumns, characteristic_type characteristic) constructor preferably). If the persistence barcode has to be computed from this matrix, the simplices are also assumed to be ordered by appearance order in the filtration. Also, depending of the options, the matrix is eventually reduced on the fly or converted into a chain complex base, so the new matrix is not always identical to the old one. |
| characteristic | Characteristic of the coefficient field. Has to be specified if PersistenceMatrixOptions::is_z2 is false. Default value is 11. Ignored if PersistenceMatrixOptions::is_z2 is true. |
inline |
| numberOfColumns | Number of columns to reserve space for. |
| characteristic | Characteristic of the coefficient field. If not specified and PersistenceMatrixOptions::is_z2 is false, the characteristic has to be set later with the use of set_characteristic before calling for the first time a method needing it. Ignored if PersistenceMatrixOptions::is_z2 is true. |
inline |
That is, when all following options have following values:
Those comparators are necesseray to distinguish cases in a vine update. When the matrix is of boundary type or if the column pairing is activated (i.e., the barcode is stored), the comparators can be easily deduced without overhead. If neither are true, we assume that one has additional information outside of the matrix about the barcode to provide a better suited comparator adapted to the situation (as in the implementation of the Zigzag algorithm [41] for example.)
| birthComparator | Method taking two PosIdx indices as parameter and returns true if and only if the first face is associated to a bar with strictly smaller birth than the bar associated to the second one. |
| deathComparator | Method taking two PosIdx indices as parameter and returns true if and only if the first face is associated to a bar with strictly smaller death than the bar associated to the second one. |
inline |
See description of Matrix(const std::vector<Container_type>& columns, characteristic_type characteristic) for more information about orderedBoundaries and Matrix(const std::function<bool(pos_index,pos_index)>&, const std::function<bool(pos_index,pos_index)>&) for more information about the comparators.
| Boundary_type | Range type for cell_rep_type ranges. Assumed to have a begin(), end() and size() method. |
| orderedBoundaries | Vector of ordered boundaries in filtration order. Indexed continously starting at 0. |
inline |
See description of Matrix(const std::function<bool(pos_index,pos_index)>&, const std::function<bool(pos_index,pos_index)>&) for more information about the comparators.
inline |
Copy constructor.
| matrixToCopy | Matrix to copy. |
inlinenoexcept |
| other | Matrix to move. |
inline |
For basic matrices with column compression, the range is summed onto the representative, which means that all column compressed together with the target column are affected by the change, not only the target.
| Cell_range | Range of Cell. Needs a begin() and end() method. A column index does not need to be stored in the cells, even if PersistenceMatrixOptions::has_row_access is true. |
inline |
For basic matrices with column compression, the representatives are summed together, which means that all column compressed together with the target column are affected by the change, not only the target.
| Index_type | Any signed or unsigned integer type. |
inline |
| rowIndex | Row index of the empty row to remove. |
inline |
| columnIndex | MatIdx index of the column to return. |
const if the matrix has column compression.
inline |
inline |
| inR | If true, returns the column in \( R \), if false, returns the column in \( U \). |
inline |
| columnIndex | MatIdx index of the column representing the face. |
inline |
Recall that the row indices for chain matrices correspond to the IDIdx indices and that the row indices for a RU matrix correspond to the updated IDIdx indices which got potentially swapped by a vine swap.
| faceIndex | Row index of the pivot. |
inline |
Recall that we assume that the boundaries were inserted in the order of filtration for the barcode to be valid.
inline |
inline |
inline |
inline |
| columnIndex | MatIdx index of the column |
inline |
| bar | A bar from the current barcode. |
bar.
inline |
inline |
| rowIndex | Row index of the row to return: IDIdx for chain matrices or updated IDIdx for boundary matrices if swaps occured. |
inline |
inline |
| rowIndex | Row index of the row to return: updated IDIdx if swaps occured. |
| inR | If true, returns the row in \( R \), if false, returns the row in \( U \). |
inline |
Different to the constructor, the boundaries do not have to come from a simplicial complex, but also from a more general cell complex. This includes cubical complexes or Morse complexes for example.
The content of the new column will vary depending on the underlying type of the matrix:
IDIdx + linear combination of older column IDIdxs, where the combination is deduced while reducing the given boundary. If the barcode is stored, it will also be updated.| Boundary_type | Range of cell_rep_type. Assumed to have a begin(), end() and size() method. |
| boundary | Boundary generating the new column. The content should be ordered by ID. |
| dim | Dimension of the face whose boundary is given. If the complex is simplicial, this parameter can be omitted as it can be deduced from the size of the boundary. |
inline |
As a face has to be inserted before one of its cofaces in a valid filtration (recall that it is assumed that for non-basic matrices, the faces are inserted by order of filtration), it is sufficient to indicate the ID of the face being inserted.
| faceIndex | IDIdx index to use to indentify the new face. |
| boundary | Boundary generating the new column. The indices of the boundary have to correspond to the faceIndex values of precedent calls of the method for the corresponding faces and should be ordered in increasing order. |
inline |
Only available for base matrices. Otherwise use insert_boundary which will deduce a new column from the boundary given.
| Container_type | Range of cell_rep_type. Assumed to have a begin(), end() and size() method. |
| column | Column to be inserted. |
inline |
Only available for base matrices without column compression and without row access.
| columnIndex | MatIdx index to which the column has to be inserted. |
inline |
For RU matrices, equivalent to is_zero_cell(columnIndex, rowIndex, true).
| columnIndex | MatIdx index of the column of the cell. |
| rowIndex | Row index of the row of the cell. |
inline |
| inR | Boolean indicating in which matrix to look: if true in \( R \) and if false in \( U \). |
inline |
For RU matrices, equivalent to is_zero_column(columnIndex, true).
Note that for chain matrices, this method should always return false, as a valid chain matrix never has empty columns.
| columnIndex | MatIdx index of the column. |
inline |
Note that if inR is false, this method should usually return false.
inline |
inline |
inline |
inline |
inline |
Assign operator.
| other | Matrix to copy |
inline |
| columnIndex | MatIdx index of the column to remove. |
inline |
See also remove_maximal_face and remove_column.
For chain matrices, if PersistenceMatrixOptions::has_vine_update is true, the last face does not have to be at the end of the matrix and therefore has to be searched first. In this case, if the user already knows the IDIdx of the last face, calling remove_maximal_face(faceID, {}) instead allows to skip the search.
inline |
To maintain the compatibility, vine swaps are done to move the face up to the end of the filtration. Once at the end, the removal is trivial. But for chain matrices, swaps do not actually swap the position of the column every time, so the faces appearing after faceIndex in the filtration have to be searched first within the matrix. If the user has an easy access to the IDIdx of the faces in the order of filtration, passing them by argument with columnsToSwap allows to skip a linear search process. Typically, if the user knows that the face he wants to remove is already the last face of the filtration, calling remove_maximal_face(faceID, {}) will be faster than remove_last().
See also remove_last.
inline |
For chain matrices, using the other version of the method could perform better depending on how the data is maintained on the side of the user. Then, PersistenceMatrixOptions::has_column_pairings also do not need to be true.
See also remove_last and remove_column.
| columnIndex | If boundary matrix, MatIdx index of the face to remove, otherwise the IDIdx index. |
inline |
| characteristic | The characteristic to set. |
inline |
inline |
inline |
inline |
| index | PosIdx index of the first face to swap. The second one has to be at index + 1. Recall that for boundary matrices, PosIdx == MatIdx. |
inline |
inline |
inline |
For RU matrices, equivalent to zero_cell(columnIndex, rowIndex, true).
inline |
inline |
For RU matrices, equivalent to zero_column(columnIndex, true).
| columnIndex | MatIdx index of the column to zero. |
inline |
| inR | Boolean indicating in which matrix to zero: if true in \( R \) and if false in \( U \). |
friend |
| matrix1 | First matrix to swap. |
| matrix2 | Second matrix to swap. |
