Loading [MathJax]/extensions/tex2jax.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::persistence_matrix::Unordered_set_column< Master_matrix > Class Template Reference
Column class following the PersistenceMatrixColumn concept. More...
Detailed Description
template<class Master_matrix>
class Gudhi::persistence_matrix::Unordered_set_column< Master_matrix >
Column based on an unordered set structure. The cells are not ordered, but only non-zero values are stored uniquely in the underlying container. When adding a cell range into it, the given cell range also does not need to be ordered (contrary to most other column types).
Template Parameters
Master_matrixAn instanciation of Matrix from which all types and options are deduced.
Cell_constructorFactory of Cell classes.
The documentation for this class was generated from the following file:
