Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::persistence_matrix::Column_dimension_holder< Master_matrix > Class Template Reference
Class managing the dimension access of a column. More...
Public Types
using dimension_type = typename Master_matrix::dimension_type
Public Member Functions
 Column_dimension_holder ()
 Default constructor. Sets the dimension to 0 for boundary matrices and to -1 for chain matrices.
 Column_dimension_holder (dimension_type dim)
 Constructor setting the dimension to the given value. More...
 Column_dimension_holder (const Column_dimension_holder &col)
 Copy constructor. More...
 Column_dimension_holder (Column_dimension_holder &&col)
 Move constructor. More...
dimension_type get_dimension () const
 Returns the dimension of the column. More...
Column_dimension_holderoperator= (const Column_dimension_holder &other)
 Assign operator.
Friends
void swap (Column_dimension_holder &col1, Column_dimension_holder &col2)
 Swap operator.
Detailed Description
template<class Master_matrix>
class Gudhi::persistence_matrix::Column_dimension_holder< Master_matrix >
Template Parameters
Master_matrixAn instanciation of Matrix from which all types and options are deduced.
Member Typedef Documentation
◆ dimension_type
template<class Master_matrix >
using Gudhi::persistence_matrix::Column_dimension_holder< Master_matrix >::dimension_type = typename Master_matrix::dimension_type
Dimension value type.
Constructor & Destructor Documentation
◆ Column_dimension_holder() [1/3]
Gudhi::persistence_matrix::Column_dimension_holder< Master_matrix >::Column_dimension_holder ( dimension_type  dim)
inline
Parameters
dimDimension of the column.
◆ Column_dimension_holder() [2/3]
Gudhi::persistence_matrix::Column_dimension_holder< Master_matrix >::Column_dimension_holder ( const Column_dimension_holder< Master_matrix > &  col)
inline
Copy constructor.
Parameters
colColumn to copy.
◆ Column_dimension_holder() [3/3]
Gudhi::persistence_matrix::Column_dimension_holder< Master_matrix >::Column_dimension_holder ( Column_dimension_holder< Master_matrix > &&  col)
inline
Move constructor.
Parameters
colColumn to move.
Member Function Documentation
◆ get_dimension()
dimension_type Gudhi::persistence_matrix::Column_dimension_holder< Master_matrix >::get_dimension ( ) const
inline
Returns
The dimension of the column.
The documentation for this class was generated from the following file:
