Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::persistence_matrix::Chain_vine_swap< Master_matrix > Class Template Reference
Class managing the vine swaps for Chain_matrix. More...
Public Types
using index = typename Master_matrix::index
using id_index = typename Master_matrix::id_index
using pos_index = typename Master_matrix::pos_index
using matrix_type = typename Master_matrix::column_container_type
using Column_type = typename Master_matrix::Column_type
typedef bool(* EventCompFuncPointer) (pos_index, pos_index)
Public Member Functions
 Chain_vine_swap ()
 Default constructor. Only available if PersistenceMatrixOptions::has_column_pairings is true.
 Chain_vine_swap (std::function< bool(pos_index, pos_index)> birthComparator, std::function< bool(pos_index, pos_index)> deathComparator=_no_G_death_comparator)
 Constructor storing the given comparators. More...
 Chain_vine_swap (const Chain_vine_swap &matrixToCopy)
 Copy constructor. More...
 Chain_vine_swap (Chain_vine_swap &&other) noexcept
 Move constructor. More...
index vine_swap_with_z_eq_1_case (index columnIndex1, index columnIndex2)
 Does the same than vine_swap, but assumes that the swap is non trivial and therefore skips a part of the case study. More...
index vine_swap (index columnIndex1, index columnIndex2)
 Does a vine swap between two faces which are consecutives in the filtration. Roughly, if \( F \) is the current filtration represented by the matrix, the method modifies the matrix such that the new state corresponds to a valid state for the filtration \( F' \) equal to \( F \) but with the two given faces at swapped positions. Of course, the two faces should not have a face/coface relation which each other ; \( F' \) has to be a valid filtration. See [21] for more information about vine and vineyards. More...
Chain_vine_swapoperator= (Chain_vine_swap other)
 Assign operator.
Friends
void swap (Chain_vine_swap &swap1, Chain_vine_swap &swap2)
 Swap operator.
Detailed Description
template<class Master_matrix>
class Gudhi::persistence_matrix::Chain_vine_swap< Master_matrix >
Template Parameters
Master_matrixAn instanciation of Matrix from which all types and options are deduced.
Member Typedef Documentation
◆ Column_type
template<class Master_matrix >
using Gudhi::persistence_matrix::Chain_vine_swap< Master_matrix >::Column_type = typename Master_matrix::Column_type
Column type.
◆ EventCompFuncPointer
typedef bool(* Gudhi::persistence_matrix::Chain_vine_swap< Master_matrix >::EventCompFuncPointer) (pos_index, pos_index)
Pointer type for birth/death comparators.
◆ id_index
using Gudhi::persistence_matrix::Chain_vine_swap< Master_matrix >::id_index = typename Master_matrix::id_index
IDIdx index type.
◆ index
using Gudhi::persistence_matrix::Chain_vine_swap< Master_matrix >::index = typename Master_matrix::index
MatIdx index type.
◆ matrix_type
using Gudhi::persistence_matrix::Chain_vine_swap< Master_matrix >::matrix_type = typename Master_matrix::column_container_type
Column container type.
◆ pos_index
using Gudhi::persistence_matrix::Chain_vine_swap< Master_matrix >::pos_index = typename Master_matrix::pos_index
PosIdx index type.
Constructor & Destructor Documentation
◆ Chain_vine_swap() [1/3]
Gudhi::persistence_matrix::Chain_vine_swap< Master_matrix >::Chain_vine_swap ( std::function< bool(pos_index, pos_index)>  birthComparator,
std::function< bool(pos_index, pos_index)>  deathComparator = _no_G_death_comparator
inline
Parameters
birthComparatorMethod taking two PosIdx indices as input and returning true if and only if the birth associated to the first position is strictly less than birth associated to the second one with respect to some self defined order. It is used while swapping two unpaired or two negative columns.
deathComparatorMethod taking two PosIdx indices as input and returning true if and only if the death associated to the first position is strictly less than death associated to the second one with respect to some self defined order. It is used while swapping two positive but paired columns. Default value: _no_G_death_comparator.
◆ Chain_vine_swap() [2/3]
Gudhi::persistence_matrix::Chain_vine_swap< Master_matrix >::Chain_vine_swap ( const Chain_vine_swap< Master_matrix > &  matrixToCopy)
inline
Copy constructor.
Parameters
matrixToCopyMatrix to copy.
◆ Chain_vine_swap() [3/3]
Gudhi::persistence_matrix::Chain_vine_swap< Master_matrix >::Chain_vine_swap ( Chain_vine_swap< Master_matrix > &&  other)
inlinenoexcept
Move constructor.
Parameters
otherMatrix to move.
Member Function Documentation
◆ vine_swap()
Chain_vine_swap< Master_matrix >::index Gudhi::persistence_matrix::Chain_vine_swap< Master_matrix >::vine_swap ( index  columnIndex1,
index  columnIndex2
inline
Parameters
columnIndex1MatIdx index of the first face.
columnIndex2MatIdx index of the second face. It is assumed that the PosIdx of both only differs by one if the barcode is maintained.
Returns
Let \( pos1 \) be the PosIdx index of columnIndex1 and \( pos2 \) be the PosIdx index of columnIndex2. The method returns the MatIdx of the column which has now, after the swap, the PosIdx \( max(pos1, pos2) \).
◆ vine_swap_with_z_eq_1_case()
Chain_vine_swap< Master_matrix >::index Gudhi::persistence_matrix::Chain_vine_swap< Master_matrix >::vine_swap_with_z_eq_1_case ( index  columnIndex1,
index  columnIndex2
inline
Parameters
Returns
The documentation for this class was generated from the following file:
