chain_vine_swap.h
Go to the documentation of this file.
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Hannah Schreiber
4  *
5  * Copyright (C) 2022-24 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
18 #ifndef PM_CHAIN_VINE_SWAP_H
19 #define PM_CHAIN_VINE_SWAP_H
20
21 #include <utility> //std::swap & std::move
22 #include <cassert>
23 #include <functional> //std::function
24 #include <stdexcept> //std::invalid_argument
25
26 #include "chain_pairing.h"
27
28 namespace Gudhi {
29 namespace persistence_matrix {
30
41 constexpr bool _no_G_death_comparator([[maybe_unused]] unsigned int columnIndex1,
42  [[maybe_unused]] unsigned int columnIndex2)
43 {
44  return false;
45 }
46
54  friend void swap([[maybe_unused]] Dummy_chain_vine_swap& d1, [[maybe_unused]] Dummy_chain_vine_swap& d2) {}
55
57  template <typename BirthComparatorFunction, typename DeathComparatorFunction>
58  Dummy_chain_vine_swap([[maybe_unused]] const BirthComparatorFunction& birthComparator,
59  [[maybe_unused]] const DeathComparatorFunction& deathComparator) {}
60 };
61
69  friend void swap([[maybe_unused]] Dummy_chain_vine_pairing& d1, [[maybe_unused]] Dummy_chain_vine_pairing& d2) {}
70 };
71
79 template <typename Master_matrix>
80 class Chain_barcode_swap : public Chain_pairing<Master_matrix>
81 {
82  public:
83  using id_index = typename Master_matrix::id_index;
84  using pos_index = typename Master_matrix::pos_index;
86
97  : CP(static_cast<const CP&>(toCopy)), pivotToPosition_(toCopy.pivotToPosition_){};
104  : CP(std::move(static_cast<CP&>(other))), pivotToPosition_(std::move(other.pivotToPosition_)){};
105
106  protected:
107  using dictionnary_type = typename Master_matrix::template dictionnary_type<pos_index>;
108
109  dictionnary_type pivotToPosition_; // necessary to keep track of the barcode changes
110
111  void swap_positions(id_index pivot1, id_index pivot2) {
112  if constexpr (Master_matrix::Option_list::has_map_column_container) {
113  std::swap(pivotToPosition_.at(pivot1), pivotToPosition_.at(pivot2));
114  } else {
115  std::swap(pivotToPosition_[pivot1], pivotToPosition_[pivot2]);
116  }
117  }
118
119  bool is_negative_in_pair(id_index pivot) const {
120  pos_index pos = _get_pivot_position(pivot);
121  return death(pivot) == pos;
122  }
123
124  void positive_transpose(id_index pivot1, id_index pivot2) {
125  pos_index pos1 = _get_pivot_position(pivot1);
126  pos_index pos2 = _get_pivot_position(pivot2);
127
128  _birth(pos1) = pos2;
129  _birth(pos2) = pos1;
130  std::swap(CP::indexToBar_.at(pos1), CP::indexToBar_.at(pos2));
131  }
132
133  void negative_transpose(id_index pivot1, id_index pivot2) {
134  pos_index pos1 = _get_pivot_position(pivot1);
135  pos_index pos2 = _get_pivot_position(pivot2);
136
137  _death(pos1) = pos2;
138  _death(pos2) = pos1;
139  std::swap(CP::indexToBar_.at(pos1), CP::indexToBar_.at(pos2));
140  }
141
142  void positive_negative_transpose(id_index pivot1, id_index pivot2) {
143  pos_index pos1 = _get_pivot_position(pivot1);
144  pos_index pos2 = _get_pivot_position(pivot2);
145
146  _birth(pos1) = pos2;
147  _death(pos2) = pos1;
148  std::swap(CP::indexToBar_.at(pos1), CP::indexToBar_.at(pos2));
149  }
150
151  void negative_positive_transpose(id_index pivot1, id_index pivot2) {
152  pos_index pos1 = _get_pivot_position(pivot1);
153  pos_index pos2 = _get_pivot_position(pivot2);
154
155  _death(pos1) = pos2;
156  _birth(pos2) = pos1;
157  std::swap(CP::indexToBar_.at(pos1), CP::indexToBar_.at(pos2));
158  }
159
160  bool are_adjacent(id_index pivot1, id_index pivot2) const {
161  pos_index pos1 = _get_pivot_position(pivot1);
162  pos_index pos2 = _get_pivot_position(pivot2);
163  return pos1 < pos2 ? (pos2 - pos1) == 1 : (pos1 - pos2) == 1;
164  }
165
166  Chain_barcode_swap& operator=(Chain_barcode_swap other) {
168  pivotToPosition_.swap(other.pivotToPosition_);
169  }
170  friend void swap(Chain_barcode_swap& swap1, Chain_barcode_swap& swap2) {
171  swap(static_cast<Chain_pairing<Master_matrix>&>(swap1), static_cast<Chain_pairing<Master_matrix>&>(swap2));
172  swap1.pivotToPosition_.swap(swap2.pivotToPosition_);
173  }
174
175  pos_index death(id_index pivot) const {
176  pos_index simplexIndex = _get_pivot_position(pivot);
177
178  if constexpr (Master_matrix::Option_list::has_removable_columns) {
179  return CP::indexToBar_.at(simplexIndex)->death;
180  } else {
181  return CP::barcode_.at(CP::indexToBar_.at(simplexIndex)).death;
182  }
183  }
184
185  pos_index birth(id_index pivot) const {
186  pos_index simplexIndex = _get_pivot_position(pivot);
187
188  if constexpr (Master_matrix::Option_list::has_removable_columns) {
189  return CP::indexToBar_.at(simplexIndex)->birth;
190  } else {
191  return CP::barcode_.at(CP::indexToBar_.at(simplexIndex)).birth;
192  }
193  }
194
195  private:
196  pos_index _get_pivot_position(id_index pivot) const {
197  if constexpr (Master_matrix::Option_list::has_map_column_container) {
198  return pivotToPosition_.at(
199  pivot); // quite often called, make public and pass position instead of pivot to avoid find() everytime?
200  } else {
201  return pivotToPosition_[pivot];
202  }
203  }
204
205  pos_index& _death(pos_index simplexIndex) {
206  if constexpr (Master_matrix::Option_list::has_removable_columns) {
207  return CP::indexToBar_.at(simplexIndex)->death;
208  } else {
209  return CP::barcode_.at(CP::indexToBar_.at(simplexIndex)).death;
210  }
211  }
212
213  pos_index& _birth(pos_index simplexIndex) {
214  if constexpr (Master_matrix::Option_list::has_removable_columns) {
215  return CP::indexToBar_.at(simplexIndex)->birth;
216  } else {
217  return CP::barcode_.at(CP::indexToBar_.at(simplexIndex)).birth;
218  }
219  }
220 };
221
230 template <class Master_matrix>
231 class Chain_vine_swap : public std::conditional<Master_matrix::Option_list::has_column_pairings,
232  Chain_barcode_swap<Master_matrix>,
233  Dummy_chain_vine_pairing
234  >::type
235 {
236  public:
237  using index = typename Master_matrix::index;
238  using id_index = typename Master_matrix::id_index;
239  using pos_index = typename Master_matrix::pos_index;
240  using matrix_type = typename Master_matrix::column_container_type;
241  using Column_type = typename Master_matrix::Column_type;
247  Chain_vine_swap();
260  Chain_vine_swap(std::function<bool(pos_index,pos_index)> birthComparator,
261  std::function<bool(pos_index,pos_index)> deathComparator = _no_G_death_comparator);
267  Chain_vine_swap(const Chain_vine_swap& matrixToCopy);
273  Chain_vine_swap(Chain_vine_swap&& other) noexcept;
274
285  index vine_swap_with_z_eq_1_case(index columnIndex1, index columnIndex2);
301  index vine_swap(index columnIndex1, index columnIndex2);
302
310  friend void swap(Chain_vine_swap& swap1, Chain_vine_swap& swap2) {
311  if constexpr (Master_matrix::Option_list::has_column_pairings) {
312  swap(static_cast<Chain_barcode_swap<Master_matrix>&>(swap1),
313  static_cast<Chain_barcode_swap<Master_matrix>&>(swap2));
314  }
315  std::swap(swap1.birthComp_, swap2.birthComp_);
316  std::swap(swap1.deathComp_, swap2.deathComp_);
317  }
318
319  protected:
320  using CP = typename std::conditional<Master_matrix::Option_list::has_column_pairings,
323  >::type;
324
325  private:
326  using chain_matrix = typename Master_matrix::Chain_matrix_type;
327
328  std::function<bool(pos_index,pos_index)> birthComp_;
329  std::function<bool(pos_index,pos_index)> deathComp_;
331  bool _is_negative_in_pair(index columnIndex);
332
333  index _positive_vine_swap(index columnIndex1, index columnIndex2);
334  index _positive_negative_vine_swap(index columnIndex1, index columnIndex2);
335  index _negative_positive_vine_swap(index columnIndex1, index columnIndex2);
336  index _negative_vine_swap(index columnIndex1, index columnIndex2);
337
338  constexpr chain_matrix* _matrix() { return static_cast<chain_matrix*>(this); }
339  constexpr const chain_matrix* _matrix() const { return static_cast<const chain_matrix*>(this); }
340 };
341
342 template <class Master_matrix>
343 inline Chain_vine_swap<Master_matrix>::Chain_vine_swap() : CP(), birthComp_(), deathComp_()
344 {
345  static_assert(Master_matrix::Option_list::has_column_pairings,
346  "If barcode is not stored, at least a birth comparator has to be specified.");
347 }
348
349 template <class Master_matrix>
350 inline Chain_vine_swap<Master_matrix>::Chain_vine_swap(std::function<bool(pos_index,pos_index)> birthComparator,
351  std::function<bool(pos_index,pos_index)> deathComparator)
352  : CP(), birthComp_(std::move(birthComparator)), deathComp_(std::move(deathComparator))
353 {}
354
355 template <class Master_matrix>
357  : CP(static_cast<const CP&>(matrixToCopy)),
358  birthComp_(matrixToCopy.birthComp_),
359  deathComp_(matrixToCopy.deathComp_)
360 {}
361
362 template <class Master_matrix>
364  : CP(std::move(static_cast<CP&>(other))),
365  birthComp_(std::move(other.birthComp_)),
366  deathComp_(std::move(other.deathComp_))
367 {}
368
369 template <class Master_matrix>
371  index columnIndex1, index columnIndex2)
372 {
373  const bool col1IsNeg = _is_negative_in_pair(columnIndex1);
374  const bool col2IsNeg = _is_negative_in_pair(columnIndex2);
375
376  if (col1IsNeg && col2IsNeg) return _negative_vine_swap(columnIndex1, columnIndex2);
377
378  if (col1IsNeg) return _negative_positive_vine_swap(columnIndex1, columnIndex2);
379
380  if (col2IsNeg) return _positive_negative_vine_swap(columnIndex1, columnIndex2);
381
382  return _positive_vine_swap(columnIndex1, columnIndex2);
383 }
384
385 template <class Master_matrix>
387  index columnIndex2)
388 {
389  if constexpr (Master_matrix::Option_list::has_column_pairings) {
390  GUDHI_CHECK(CP::are_adjacent(_matrix()->get_pivot(columnIndex1), _matrix()->get_pivot(columnIndex2)),
391  std::invalid_argument(
392  "Chain_vine_swap::vine_swap - Columns to be swaped need to be adjacent in the 'real' matrix."));
393  }
394
395  const bool col1IsNeg = _is_negative_in_pair(columnIndex1);
396  const bool col2IsNeg = _is_negative_in_pair(columnIndex2);
397
398  if (col1IsNeg && col2IsNeg) {
399  if (_matrix()->is_zero_cell(columnIndex2, _matrix()->get_pivot(columnIndex1))) {
400  if constexpr (Master_matrix::Option_list::has_column_pairings) {
401  id_index pivot1 = _matrix()->get_pivot(columnIndex1);
402  id_index pivot2 = _matrix()->get_pivot(columnIndex2);
403
404  CP::negative_transpose(pivot1, pivot2);
405  CP::swap_positions(pivot1, pivot2);
406  }
407  return columnIndex1;
408  }
409  return _negative_vine_swap(columnIndex1, columnIndex2);
410  }
411
412  if (col1IsNeg) {
413  if (_matrix()->is_zero_cell(columnIndex2, _matrix()->get_pivot(columnIndex1))) {
414  if constexpr (Master_matrix::Option_list::has_column_pairings) {
415  id_index pivot1 = _matrix()->get_pivot(columnIndex1);
416  id_index pivot2 = _matrix()->get_pivot(columnIndex2);
417
418  CP::negative_positive_transpose(pivot1, pivot2);
419  CP::swap_positions(pivot1, pivot2);
420  }
421  return columnIndex1;
422  }
423  return _negative_positive_vine_swap(columnIndex1, columnIndex2);
424  }
425
426  if (col2IsNeg) {
427  if (_matrix()->is_zero_cell(columnIndex2, _matrix()->get_pivot(columnIndex1))) {
428  if constexpr (Master_matrix::Option_list::has_column_pairings) {
429  id_index pivot1 = _matrix()->get_pivot(columnIndex1);
430  id_index pivot2 = _matrix()->get_pivot(columnIndex2);
431
432  CP::positive_negative_transpose(pivot1, pivot2);
433  CP::swap_positions(pivot1, pivot2);
434  }
435  return columnIndex1;
436  }
437  return _positive_negative_vine_swap(columnIndex1, columnIndex2);
438  }
439
440  if (_matrix()->is_zero_cell(columnIndex2, _matrix()->get_pivot(columnIndex1))) {
441  if constexpr (Master_matrix::Option_list::has_column_pairings) {
442  id_index pivot1 = _matrix()->get_pivot(columnIndex1);
443  id_index pivot2 = _matrix()->get_pivot(columnIndex2);
444
445  CP::positive_transpose(pivot1, pivot2);
446  CP::swap_positions(pivot1, pivot2);
447  }
448  return columnIndex1;
449  }
450  return _positive_vine_swap(columnIndex1, columnIndex2);
451 }
452
453 template <class Master_matrix>
455 {
456  CP::operator=(other);
457  std::swap(birthComp_, other.birthComp_);
458  std::swap(deathComp_, other.deathComp_);
459  return *this;
460 }
461
462 template <class Master_matrix>
463 inline bool Chain_vine_swap<Master_matrix>::_is_negative_in_pair(index columnIndex)
464 {
465  if constexpr (Master_matrix::Option_list::has_column_pairings) {
466  return CP::is_negative_in_pair(_matrix()->get_pivot(columnIndex));
467  } else {
468  auto& col = _matrix()->get_column(columnIndex);
469  if (!col.is_paired()) return false;
470  return col.get_pivot() > _matrix()->get_pivot(col.get_paired_chain_index());
471  }
472 }
473
474 template <class Master_matrix>
475 inline typename Chain_vine_swap<Master_matrix>::index Chain_vine_swap<Master_matrix>::_positive_vine_swap(
476  index columnIndex1, index columnIndex2)
477 {
478  auto& col1 = _matrix()->get_column(columnIndex1);
479  auto& col2 = _matrix()->get_column(columnIndex2);
480
481  if constexpr (Master_matrix::Option_list::has_column_pairings) {
482  CP::swap_positions(col1.get_pivot(), col2.get_pivot());
483  }
484  // TODO: factorize the cases. But for debug it is much more easier to understand what is happening splitted like this
485  if (!col1.is_paired()) { // F x *
486  bool hasSmallerBirth;
487  if constexpr (Master_matrix::Option_list::has_column_pairings) {
488  // this order because position were swapped with CP::swap_positions
489  hasSmallerBirth = (CP::birth(col2.get_pivot()) < CP::birth(col1.get_pivot()));
490  } else {
491  hasSmallerBirth = birthComp_(columnIndex1, columnIndex2);
492  }
493
494  if (!col2.is_paired() && hasSmallerBirth) {
495  _matrix()->add_to(columnIndex1, columnIndex2);
496  if constexpr (Master_matrix::Option_list::has_column_pairings) {
497  CP::positive_transpose(col1.get_pivot(), col2.get_pivot());
498  }
499  return columnIndex1;
500  }
501  _matrix()->add_to(columnIndex2, columnIndex1);
502
503  return columnIndex2;
504  }
505
506  if (!col2.is_paired()) { // G x F
507  static_cast<chain_matrix*>(this)->add_to(columnIndex1, columnIndex2);
508  if constexpr (Master_matrix::Option_list::has_column_pairings) {
509  CP::positive_transpose(col1.get_pivot(), col2.get_pivot());
510  }
511  return columnIndex1;
512  }
513
514  bool hasSmallerDeath;
515  if constexpr (Master_matrix::Option_list::has_column_pairings) {
516  // this order because position were swapped with CP::swap_positions
517  hasSmallerDeath = (CP::death(col2.get_pivot()) < CP::death(col1.get_pivot()));
518  } else {
519  hasSmallerDeath = deathComp_(columnIndex1, columnIndex2);
520  }
521
522  // G x G
523  if (hasSmallerDeath)
524  {
525  _matrix()->add_to(col1.get_paired_chain_index(), col2.get_paired_chain_index());
526  _matrix()->add_to(columnIndex1, columnIndex2);
527  if constexpr (Master_matrix::Option_list::has_column_pairings) {
528  CP::positive_transpose(col1.get_pivot(), col2.get_pivot());
529  }
530  return columnIndex1;
531  }
532
533  _matrix()->add_to(col2.get_paired_chain_index(), col1.get_paired_chain_index());
534  _matrix()->add_to(columnIndex2, columnIndex1);
535
536  return columnIndex2;
537 }
538
539 template <class Master_matrix>
540 inline typename Chain_vine_swap<Master_matrix>::index Chain_vine_swap<Master_matrix>::_positive_negative_vine_swap(
541  index columnIndex1, index columnIndex2)
542 {
543  _matrix()->add_to(columnIndex1, columnIndex2);
544
545  if constexpr (Master_matrix::Option_list::has_column_pairings) {
546  id_index pivot1 = _matrix()->get_pivot(columnIndex1);
547  id_index pivot2 = _matrix()->get_pivot(columnIndex2);
548
549  CP::positive_negative_transpose(pivot1, pivot2);
550  CP::swap_positions(pivot1, pivot2);
551  }
552
553  return columnIndex1;
554 }
555
556 template <class Master_matrix>
557 inline typename Chain_vine_swap<Master_matrix>::index Chain_vine_swap<Master_matrix>::_negative_positive_vine_swap(
558  index columnIndex1, index columnIndex2)
559 {
560  _matrix()->add_to(columnIndex2, columnIndex1);
561
562  if constexpr (Master_matrix::Option_list::has_column_pairings) {
563  CP::swap_positions(_matrix()->get_pivot(columnIndex1), _matrix()->get_pivot(columnIndex2));
564  }
565
566  return columnIndex2;
567 }
568
569 template <class Master_matrix>
570 inline typename Chain_vine_swap<Master_matrix>::index Chain_vine_swap<Master_matrix>::_negative_vine_swap(
571  index columnIndex1, index columnIndex2)
572 {
573  auto& col1 = _matrix()->get_column(columnIndex1);
574  auto& col2 = _matrix()->get_column(columnIndex2);
575
576  index pairedIndex1 = col1.get_paired_chain_index();
577  index pairedIndex2 = col2.get_paired_chain_index();
578
579  bool hasSmallerBirth;
580  if constexpr (Master_matrix::Option_list::has_column_pairings) {
581  hasSmallerBirth = (CP::birth(col1.get_pivot()) < CP::birth(col2.get_pivot()));
582  } else {
583  hasSmallerBirth = birthComp_(pairedIndex1, pairedIndex2);
584  }
585
586  if constexpr (Master_matrix::Option_list::has_column_pairings) {
587  CP::swap_positions(col1.get_pivot(), col2.get_pivot());
588  }
589
590  if (hasSmallerBirth)
591  {
592  _matrix()->add_to(pairedIndex1, pairedIndex2);
593  _matrix()->add_to(columnIndex1, columnIndex2);
594
595  if constexpr (Master_matrix::Option_list::has_column_pairings) {
596  CP::negative_transpose(col1.get_pivot(), col2.get_pivot());
597  }
598
599  return columnIndex1;
600  }
601
602  _matrix()->add_to(pairedIndex2, pairedIndex1);
603  _matrix()->add_to(columnIndex2, columnIndex1);
604
605  return columnIndex2;
606 }
607
608 } // namespace persistence_matrix
609 } // namespace Gudhi
610
611 #endif // PM_CHAIN_VINE_SWAP_H
Contains the Chain_pairing class and Dummy_chain_pairing structure.
Class managing the barcode for Chain_vine_swap.
Definition: chain_vine_swap.h:81
typename Master_matrix::pos_index pos_index
Definition: chain_vine_swap.h:84
Chain_barcode_swap()
Default constructor.
Definition: chain_vine_swap.h:90
typename Master_matrix::id_index id_index
Definition: chain_vine_swap.h:83
Chain_barcode_swap(const Chain_barcode_swap &toCopy)
Copy constructor.
Definition: chain_vine_swap.h:96
Chain_barcode_swap(Chain_barcode_swap &&other)
Move constructor.
Definition: chain_vine_swap.h:103
Class managing the barcode for Chain_matrix if the option was enabled.
Definition: chain_pairing.h:46
Chain_pairing & operator=(Chain_pairing other)
Assign operator.
Definition: chain_pairing.h:123
Class managing the vine swaps for Chain_matrix.
Definition: chain_vine_swap.h:235
Chain_vine_swap()
Default constructor. Only available if PersistenceMatrixOptions::has_column_pairings is true.
Definition: chain_vine_swap.h:343
Does the same than vine_swap, but assumes that the swap is non trivial and therefore skips a part of ...
Definition: chain_vine_swap.h:370
Chain_vine_swap & operator=(Chain_vine_swap other)
Assign operator.
Definition: chain_vine_swap.h:454
Does a vine swap between two faces which are consecutives in the filtration. Roughly,...
Definition: chain_vine_swap.h:386
friend void swap(Chain_vine_swap &swap1, Chain_vine_swap &swap2)
Swap operator.
Definition: chain_vine_swap.h:310
typename Master_matrix::column_container_type matrix_type
Definition: chain_vine_swap.h:240
typename Master_matrix::Column_type Column_type
Definition: chain_vine_swap.h:241
Definition: chain_vine_swap.h:238
Definition: chain_vine_swap.h:239
typename Master_matrix::index index
Definition: chain_vine_swap.h:237
bool(* EventCompFuncPointer)(pos_index, pos_index)
Definition: chain_vine_swap.h:242
constexpr bool _no_G_death_comparator([[maybe_unused]] unsigned int columnIndex1, [[maybe_unused]] unsigned int columnIndex2)
Default death comparator. Simply assumes that two positive paired columns are never swapped....
Definition: chain_vine_swap.h:41
Gudhi namespace.
Definition: SimplicialComplexForAlpha.h:14
Empty structure. Inheritated instead of Chain_barcode_swap, when the barcode is not stored.
Definition: chain_vine_swap.h:68
Empty structure. Inheritated instead of Chain_vine_swap, when vine swappes are not enabled.
Definition: chain_vine_swap.h:53
