Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::persistence_matrix::Base_swap< Master_matrix, Base_matrix > Class Template Reference
Class managing the column and row swaps in Base_matrix and Boundary_matrix. More...
Public Types
using matrix_type = typename Master_matrix::column_container_type
using index = typename Master_matrix::index
using id_index = typename Master_matrix::id_index
Public Member Functions
 Base_swap ()
 Default constructor.
 Base_swap (unsigned int numberOfColumns)
 As default constructor, but reserves spaces for numberOfColumns columns. More...
 Base_swap (const Base_swap &matrixToCopy)
 Copy constructor. More...
 Base_swap (Base_swap &&other) noexcept
 Move constructor. More...
void swap_columns (index columnIndex1, index columnIndex2)
 Swaps the two columns at given indices in the column container. Does not updates the column index value, potentially stored in the cells. This will be done when calling _orderRows(). More...
void swap_rows (id_index rowIndex1, id_index rowIndex2)
 Swaps the two rows at the given indices, but in a lazy manner. That is, the swap is registered but not executed. The reordering will be done when calling _orderRows(). More...
Base_swapoperator= (Base_swap other)
 Assign operator.
Friends
void swap (Base_swap &base1, Base_swap &base2)
 Swap operator.
Detailed Description
template<class Master_matrix, class Base_matrix>
class Gudhi::persistence_matrix::Base_swap< Master_matrix, Base_matrix >
Template Parameters
Master_matrixAn instanciation of Matrix from which all types and options are deduced.
Base_matrixEither Base_matrix or Boundary_matrix.
Member Typedef Documentation
◆ id_index
template<class Master_matrix , class Base_matrix >
using Gudhi::persistence_matrix::Base_swap< Master_matrix, Base_matrix >::id_index = typename Master_matrix::id_index
IDIdx index type.
◆ index
using Gudhi::persistence_matrix::Base_swap< Master_matrix, Base_matrix >::index = typename Master_matrix::index
Container index type.
◆ matrix_type
using Gudhi::persistence_matrix::Base_swap< Master_matrix, Base_matrix >::matrix_type = typename Master_matrix::column_container_type
Column container type.
Constructor & Destructor Documentation
◆ Base_swap() [1/3]
Gudhi::persistence_matrix::Base_swap< Master_matrix, Base_matrix >::Base_swap ( unsigned int  numberOfColumns)
inline
Parameters
numberOfColumnsNumber of columns to reserve space for.
◆ Base_swap() [2/3]
Gudhi::persistence_matrix::Base_swap< Master_matrix, Base_matrix >::Base_swap ( const Base_swap< Master_matrix, Base_matrix > &  matrixToCopy)
Copy constructor.
Parameters
matrixToCopyMatrix to copy.
◆ Base_swap() [3/3]
Gudhi::persistence_matrix::Base_swap< Master_matrix, Base_matrix >::Base_swap ( Base_swap< Master_matrix, Base_matrix > &&  other)
noexcept
Move constructor.
Parameters
otherMatrix to move.
Member Function Documentation
◆ swap_columns()
void Gudhi::persistence_matrix::Base_swap< Master_matrix, Base_matrix >::swap_columns ( index  columnIndex1,
index  columnIndex2
inline
Parameters
columnIndex1First MatIdx column index.
columnIndex2Second MatIdx column index.
◆ swap_rows()
void Gudhi::persistence_matrix::Base_swap< Master_matrix, Base_matrix >::swap_rows ( id_index  rowIndex1,
id_index  rowIndex2
inline
Parameters
rowIndex1First row index.
rowIndex2Second row index.
The documentation for this class was generated from the following file:
