Gudhi::persistence_matrix::Base_matrix< Master_matrix > Class Template Reference
A basic matrix structure allowing to easily manipulate and access entire columns and rows, but not individual cells. More...
Public Types
using index = typename Master_matrix::index
using dimension_type = typename Master_matrix::dimension_type
using Field_operators = typename Master_matrix::Field_operators
 Field operators class. Necessary only if PersistenceMatrixOptions::is_z2 is false.
using Field_element_type = typename Master_matrix::element_type
using Column_type = typename Master_matrix::Column_type
using container_type = typename Master_matrix::boundary_type
using Row_type = typename Master_matrix::Row_type
using Cell_constructor = typename Master_matrix::Cell_constructor
using Column_settings = typename Master_matrix::Column_settings
Public Member Functions
 Base_matrix (Column_settings *colSettings)
 Constructs an empty matrix. More...
template<class Container_type = container_type>
 Base_matrix (const std::vector< Container_type > &columns, Column_settings *colSettings)
 Constructs a matrix from the given ordered columns. The columns are inserted in the given order. More...
 Base_matrix (unsigned int numberOfColumns, Column_settings *colSettings)
 Constructs a new empty matrix and reserves space for the given number of columns. More...
 Base_matrix (const Base_matrix &matrixToCopy, Column_settings *colSettings=nullptr)
 Copy constructor. If colSettings is not a null pointer, its value is kept instead of the one in the copied matrix. More...
 Base_matrix (Base_matrix &&other) noexcept
 Move constructor. More...
void insert_column (const Container_type &column)
 Inserts a new ordered column at the end of the matrix by copying the given range of Matrix::cell_rep_type. The content of the range is assumed to be sorted by increasing ID value. More...
void insert_column (const Container_type &column, index columnIndex)
 Inserts a new ordered column at the given index by copying the given range of Matrix::cell_rep_type. There should not be any other column inserted at that index which was not explicitely removed before. The content of the range is assumed to be sorted by increasing ID value. Not available when row access is enabled. More...
template<class Boundary_type >
void insert_boundary (const Boundary_type &boundary, dimension_type dim=-1)
 Same as insert_column, only for interface purposes. The given dimension is ignored and not stored. More...
Column_type & get_column (index columnIndex)
 Returns the column at the given MatIdx index. The type of the column depends on the choosen options, see PersistenceMatrixOptions::column_type. More...
Row_type & get_row (index rowIndex)
 Only available if PersistenceMatrixOptions::has_row_access is true. Returns the row at the given row index of the matrix. The type of the row depends on the choosen options, see PersistenceMatrixOptions::has_intrusive_rows. More...
void remove_column (index columnIndex)
 Only available if PersistenceMatrixOptions::has_map_column_container is true. Otherwise, see remove_last. Erases the given column from the matrix. If the given column index corresponded to the last used column index, the "new last column index" will be columnIndex - 1, even if a column was never explicitely inserted at this index (possible when insert_column(column, columnIndex) was used). If the column didn't existed, it will simply be considered as an empty column. More...
void remove_last ()
 Removes the last column from the matrix. The last column is at index \( max(ins1, ins2, rem - 1) \), where: More...
void erase_empty_row (index rowIndex)
 If PersistenceMatrixOptions::has_row_access and PersistenceMatrixOptions::has_removable_rows are true: assumes that the row is empty and removes it. If PersistenceMatrixOptions::has_map_column_container and PersistenceMatrixOptions::has_column_and_row_swaps are true: cleans up maps used for the lazy row swaps. Otherwise, does nothing. More...
index get_number_of_columns () const
 Returns the current number of columns in the matrix. More...
template<class Cell_range_or_column_index >
void add_to (const Cell_range_or_column_index &sourceColumn, index targetColumnIndex)
 Adds column represented by sourceColumn onto the column at targetColumnIndex in the matrix. More...
void multiply_target_and_add_to (const Cell_range_or_column_index &sourceColumn, const Field_element_type &coefficient, index targetColumnIndex)
 Multiplies the target column with the coefficiant and then adds the source column to it. That is: targetColumn = (targetColumn * coefficient) + sourceColumn. More...
void multiply_source_and_add_to (const Field_element_type &coefficient, const Cell_range_or_column_index &sourceColumn, index targetColumnIndex)
 Multiplies the source column with the coefficiant before adding it to the target column. That is: targetColumn += (coefficient * sourceColumn). The source column will not be modified. More...
void zero_cell (index columnIndex, index rowIndex)
 Zeroes the cell at the given coordinates. More...
void zero_column (index columnIndex)
 Zeroes the column at the given index. More...
bool is_zero_cell (index columnIndex, index rowIndex) const
 Indicates if the cell at given coordinates has value zero. More...
bool is_zero_column (index columnIndex)
 Indicates if the column at given index has value zero. More...
void reset (Column_settings *colSettings)
 Resets the matrix to an empty matrix. More...
Base_matrix & operator= (const Base_matrix &other)
 Assign operator.
Friends
void swap (Base_matrix &matrix1, Base_matrix &matrix2)
 Swap operator.
Detailed Description
template<class Master_matrix>
class Gudhi::persistence_matrix::Base_matrix< Master_matrix >
Template Parameters
Master_matrixAn instanciation of Matrix from which all types and options are deduced.
Member Typedef Documentation
◆ Cell_constructor
template<class Master_matrix >
using Gudhi::persistence_matrix::Base_matrix< Master_matrix >::Cell_constructor = typename Master_matrix::Cell_constructor
Factory of Cell classes.
◆ Column_settings
using Gudhi::persistence_matrix::Base_matrix< Master_matrix >::Column_settings = typename Master_matrix::Column_settings
Structure giving access to the columns to necessary external classes.
◆ Column_type
using Gudhi::persistence_matrix::Base_matrix< Master_matrix >::Column_type = typename Master_matrix::Column_type
Column type.
◆ container_type
using Gudhi::persistence_matrix::Base_matrix< Master_matrix >::container_type = typename Master_matrix::boundary_type
Type of the column container.
◆ dimension_type
using Gudhi::persistence_matrix::Base_matrix< Master_matrix >::dimension_type = typename Master_matrix::dimension_type
Dimension value type.
◆ Field_element_type
using Gudhi::persistence_matrix::Base_matrix< Master_matrix >::Field_element_type = typename Master_matrix::element_type
Type of a field element.
◆ index
using Gudhi::persistence_matrix::Base_matrix< Master_matrix >::index = typename Master_matrix::index
Container index type.
◆ Row_type
using Gudhi::persistence_matrix::Base_matrix< Master_matrix >::Row_type = typename Master_matrix::Row_type
Row type, only necessary with row access option.
Constructor & Destructor Documentation
◆ Base_matrix() [1/5]
Gudhi::persistence_matrix::Base_matrix< Master_matrix >::Base_matrix ( Column_settings *  colSettings)
inline
Parameters
colSettingsPointer to an existing setting structure for the columns. The structure should contain all the necessary external classes specifically necessary for the choosen column type, such as custom allocators.
◆ Base_matrix() [2/5]
template<class Container_type >
Gudhi::persistence_matrix::Base_matrix< Master_matrix >::Base_matrix ( const std::vector< Container_type > &  columns,
inline
Template Parameters
Container_typeRange type for Matrix::cell_rep_type ranges. Assumed to have a begin(), end() and size() method.
Parameters
columnsA vector of Matrix::cell_rep_type ranges to construct the columns from. The content of the ranges are assumed to be sorted by increasing ID value.
◆ Base_matrix() [3/5]
Gudhi::persistence_matrix::Base_matrix< Master_matrix >::Base_matrix ( unsigned int  numberOfColumns,
inline
Parameters
numberOfColumnsNumber of columns to reserve space for.
◆ Base_matrix() [4/5]
Gudhi::persistence_matrix::Base_matrix< Master_matrix >::Base_matrix ( const Base_matrix< Master_matrix > &  matrixToCopy,
Column_settings *  colSettings = nullptr
inline
Parameters
matrixToCopyMatrix to copy.
colSettingsEither a pointer to an existing setting structure for the columns or a null pointer. The structure should contain all the necessary external classes specifically necessary for the choosen column type, such as custom allocators. If null pointer, the pointer stored in matrixToCopy is used instead.
◆ Base_matrix() [5/5]
Gudhi::persistence_matrix::Base_matrix< Master_matrix >::Base_matrix ( Base_matrix< Master_matrix > &&  other)
inlinenoexcept
Move constructor.
Parameters
otherMatrix to move.
Member Function Documentation
◆ add_to()
void Gudhi::persistence_matrix::Base_matrix< Master_matrix >::add_to ( const Cell_range_or_column_index &  sourceColumn,
inline
Template Parameters
Cell_range_or_column_indexEither a range of Cell with a begin() and end() method, or any integer type.
Parameters
sourceColumnEither a cell range or the MatIdx index of the column to add.
targetColumnIndexMatIdx index of the target column.
◆ erase_empty_row()
void Gudhi::persistence_matrix::Base_matrix< Master_matrix >::erase_empty_row ( index  rowIndex)
inline
Warning
The removed rows are always assumed to be empty. If it is not the case, the deleted row cells are not removed from their columns. And in the case of intrusive rows, this will generate a segmentation fault when the column cells are destroyed later. The row access is just meant as a "read only" access to the rows and the erase_empty_row method just as a way to specify that a row is empty and can therefore be removed from dictionnaries. This allows to avoid testing the emptiness of a row at each column cell removal, what can be quite frequent.
Parameters
rowIndexRow index of the empty row.
◆ get_column()
Base_matrix< Master_matrix >::Column_type & Gudhi::persistence_matrix::Base_matrix< Master_matrix >::get_column ( index  columnIndex)
inline
Note that before returning the column, all column cells can eventually be reordered, if lazy swaps occurred. It is therefore recommended to avoid calling get_column between column or row swaps, otherwise the benefits of the the lazyness is lost.
Parameters
columnIndexMatIdx index of the column to return.
Returns
Reference to the column.
◆ get_number_of_columns()
Base_matrix< Master_matrix >::index Gudhi::persistence_matrix::Base_matrix< Master_matrix >::get_number_of_columns
inline
Returns
The number of columns.
◆ get_row()
Base_matrix< Master_matrix >::Row_type & Gudhi::persistence_matrix::Base_matrix< Master_matrix >::get_row ( index  rowIndex)
inline
Note that before returning the row, all column cells can eventually be reordered, if lazy swaps occurred. It is therefore recommended to avoid calling get_row between column or row swaps, otherwise the benefits of the the lazyness is lost.
Parameters
rowIndexRow index of the row to return.
Returns
Reference to the row.
◆ insert_boundary()
void Gudhi::persistence_matrix::Base_matrix< Master_matrix >::insert_boundary ( const Boundary_type &  boundary,
dimension_type  dim = -1
inline
Template Parameters
Boundary_typeRange of Matrix::cell_rep_type. Assumed to have a begin(), end() and size() method.
Parameters
boundaryRange of Matrix::cell_rep_type from which the column has to be constructed. Assumed to be ordered by increasing ID value.
dimIgnored.
◆ insert_column() [1/2]
void Gudhi::persistence_matrix::Base_matrix< Master_matrix >::insert_column ( const Container_type &  column)
inline
Template Parameters
Container_typeRange of Matrix::cell_rep_type. Assumed to have a begin(), end() and size() method.
Parameters
columnRange of Matrix::cell_rep_type from which the column has to be constructed. Assumed to be ordered by increasing ID value.
◆ insert_column() [2/2]
void Gudhi::persistence_matrix::Base_matrix< Master_matrix >::insert_column ( const Container_type &  column,
index  columnIndex
inline
Template Parameters
Parameters
columnIndexMatIdx index to which the column has to be inserted.
◆ is_zero_cell()
bool Gudhi::persistence_matrix::Base_matrix< Master_matrix >::is_zero_cell ( index  columnIndex,
index  rowIndex
) const
inline
Parameters
columnIndexMatIdx index of the column of the cell.
rowIndexRow index of the row of the cell.
Returns
true If the cell has value zero.
false Otherwise.
◆ is_zero_column()
bool Gudhi::persistence_matrix::Base_matrix< Master_matrix >::is_zero_column ( index  columnIndex)
inline
Parameters
columnIndexMatIdx index of the column.
Returns
true If the column has value zero.
false Otherwise.
◆ multiply_source_and_add_to()
void Gudhi::persistence_matrix::Base_matrix< Master_matrix >::multiply_source_and_add_to ( const Field_element_type &  coefficient,
inline
Template Parameters
Parameters
coefficientValue to multiply.
◆ multiply_target_and_add_to()
void Gudhi::persistence_matrix::Base_matrix< Master_matrix >::multiply_target_and_add_to ( const Cell_range_or_column_index &  sourceColumn,
inline
Template Parameters
Parameters
◆ remove_column()
void Gudhi::persistence_matrix::Base_matrix< Master_matrix >::remove_column ( index  columnIndex)
inline
If PersistenceMatrixOptions::has_row_access is also true, the deleted column cells are also automatically removed from their respective rows.
Parameters
columnIndexMatIdx index of the column to remove.
◆ remove_last()
void Gudhi::persistence_matrix::Base_matrix< Master_matrix >::remove_last
inline
If \( max(ins1, ins2, rem - 1) = rem - 1 \) but no column was explicitely inserted at that index (possible by the use of insert_column(column, columnIndex)), the column is assumed to be an empty column.
See also remove_column.
◆ reset()
void Gudhi::persistence_matrix::Base_matrix< Master_matrix >::reset ( Column_settings *  colSettings)
inline
Parameters
◆ zero_cell()
void Gudhi::persistence_matrix::Base_matrix< Master_matrix >::zero_cell ( index  columnIndex,
index  rowIndex
inline
Parameters
◆ zero_column()
void Gudhi::persistence_matrix::Base_matrix< Master_matrix >::zero_column ( index  columnIndex)
inline
Parameters
columnIndexMatIdx index of the column to zero.
The documentation for this class was generated from the following file:
