Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type > Class Template Reference
Overlay for chain matrices replacing all input and output MatIdx indices of the original methods with PosIdx indices. The overlay is useless for boundary matrices as MatIdx == PosIdx for them. More...
Public Types
using index = typename Master_matrix_type::index
using id_index = typename Master_matrix_type::id_index
using pos_index = typename Master_matrix_type::pos_index
using dimension_type = typename Master_matrix_type::dimension_type
using Field_operators = typename Master_matrix_type::Field_operators
 Field operators class. Necessary only if PersistenceMatrixOptions::is_z2 is false.
using Field_element_type = typename Master_matrix_type::element_type
using boundary_type = typename Master_matrix_type::boundary_type
using Column_type = typename Master_matrix_type::Column_type
using Row_type = typename Master_matrix_type::Row_type
using bar_type = typename Master_matrix_type::Bar
using barcode_type = typename Master_matrix_type::barcode_type
using cycle_type = typename Master_matrix_type::cycle_type
using cell_rep_type = typename Master_matrix_type::cell_rep_type
using Cell_constructor = typename Master_matrix_type::Cell_constructor
using Column_settings = typename Master_matrix_type::Column_settings
Public Member Functions
 Position_to_index_overlay (Column_settings *colSettings)
 Constructs an empty matrix. More...
template<class Boundary_type = boundary_type>
 Position_to_index_overlay (const std::vector< Boundary_type > &orderedBoundaries, Column_settings *colSettings)
 Constructs a new matrix from the given ranges of Matrix::cell_rep_type. Each range corresponds to a column (the order of the ranges are preserved). The content of the ranges is assumed to be sorted by increasing IDs. The IDs of the simplices are also assumed to be consecutifs, ordered by filtration value, starting with 0. More...
 Position_to_index_overlay (unsigned int numberOfColumns, Column_settings *colSettings)
 Constructs a new empty matrix and reserves space for the given number of columns. More...
template<typename BirthComparatorFunction , typename DeathComparatorFunction >
 Position_to_index_overlay (Column_settings *colSettings, const BirthComparatorFunction &birthComparator, const DeathComparatorFunction &deathComparator)
 Only available for chain matrices. Constructs an empty matrix and stores the given comparators. More...
template<typename BirthComparatorFunction , typename DeathComparatorFunction , class Boundary_type >
 Position_to_index_overlay (const std::vector< Boundary_type > &orderedBoundaries, Column_settings *colSettings, const BirthComparatorFunction &birthComparator, const DeathComparatorFunction &deathComparator)
 Only available for chain matrices. Constructs a new matrix from the given ranges of Matrix::cell_rep_type. Each range corresponds to a column (the order of the ranges are preserved). The content of the ranges is assumed to be sorted by increasing IDs. The IDs of the simplices are also assumed to be consecutifs, ordered by filtration value, starting with 0. More...
 Position_to_index_overlay (unsigned int numberOfColumns, Column_settings *colSettings, const BirthComparatorFunction &birthComparator, const DeathComparatorFunction &deathComparator)
 Only available for chain matrices. Constructs a new empty matrix and reserves space for the given number of columns. More...
 Position_to_index_overlay (const Position_to_index_overlay &matrixToCopy, Column_settings *colSettings=nullptr)
 Copy constructor. If colSettings is not a null pointer, its value is kept instead of the one in the copied matrix. More...
 Position_to_index_overlay (Position_to_index_overlay &&other) noexcept
 Move constructor. More...
void insert_boundary (const Boundary_type &boundary, dimension_type dim=-1)
 Inserts at the end of the matrix a new ordered column corresponding to the given boundary. This means that it is assumed that this method is called on boundaries in the order of the filtration. It also assumes that the faces in the given boundary are identified by their relative position in the filtration, starting at 0. If it is not the case, use the other insert_boundary instead by indicating the face ID used in the boundaries when the face is inserted. More...
void insert_boundary (id_index faceIndex, const Boundary_type &boundary, dimension_type dim=-1)
 It does the same as the other version, but allows the boundary faces to be identified without restrictions except that all IDs have to be strictly increasing in the order of filtration. Note that you should avoid then to use the other insertion method to avoid overwriting IDs. More...
Column_typeget_column (pos_index position)
 Returns the column at the given PosIdx index. The type of the column depends on the choosen options, see PersistenceMatrixOptions::column_type. More...
const Column_typeget_column (pos_index position) const
Row_typeget_row (id_index rowIndex)
 Only available if PersistenceMatrixOptions::has_row_access is true. Returns the row at the given row index. The type of the row depends on the choosen options, see PersistenceMatrixOptions::has_intrusive_rows. More...
const Row_typeget_row (id_index rowIndex) const
void erase_empty_row (id_index rowIndex)
 Only available if PersistenceMatrixOptions::has_row_access and PersistenceMatrixOptions::has_removable_rows are true. Assumes that the row is empty and removes it. More...
void remove_maximal_face (pos_index position)
 Only available if PersistenceMatrixOptions::has_removable_columns, PersistenceMatrixOptions::has_vine_update and PersistenceMatrixOptions::has_map_column_container are true. Assumes that the face is maximal in the current complex and removes it such that the matrix remains consistent (i.e., the matrix is still a compatible bases of the chain complex in the sense of [41]). The maximality of the face is not verified. Also updates the barcode if it was computed. More...
void remove_last ()
 Only available if PersistenceMatrixOptions::has_removable_columns is true and, if PersistenceMatrixOptions::has_map_column_container is true or PersistenceMatrixOptions::has_vine_update is false. Removes the last face in the filtration from the matrix and updates the barcode if it is stored. More...
dimension_type get_max_dimension () const
 Returns the maximal dimension of a face stored in the matrix. Only available if PersistenceMatrixOptions::has_matrix_maximal_dimension_access is true. More...
index get_number_of_columns () const
 Returns the current number of columns in the matrix. More...
dimension_type get_column_dimension (pos_index position) const
 Returns the dimension of the given face. More...
void add_to (pos_index sourcePosition, pos_index targetPosition)
 Adds column corresponding to sourcePosition onto the column corresponding to targetPosition. More...
void multiply_target_and_add_to (pos_index sourcePosition, const Field_element_type &coefficient, pos_index targetPosition)
 Multiplies the target column with the coefficiant and then adds the source column to it. That is: targetColumn = (targetColumn * coefficient) + sourceColumn. More...
void multiply_source_and_add_to (const Field_element_type &coefficient, pos_index sourcePosition, pos_index targetPosition)
 Multiplies the source column with the coefficiant before adding it to the target column. That is: targetColumn += (coefficient * sourceColumn). The source column will not be modified. More...
bool is_zero_cell (pos_index position, id_index rowIndex) const
 Indicates if the cell at given coordinates has value zero. More...
bool is_zero_column (pos_index position)
 Indicates if the column at given index has value zero. More...
pos_index get_column_with_pivot (id_index faceIndex) const
 Returns the PosIdx index of the column which has the given row index as pivot. Assumes that the pivot exists. More...
id_index get_pivot (pos_index position)
 Returns the row index of the pivot of the given column. More...
void reset (Column_settings *colSettings)
 Resets the matrix to an empty matrix. More...
Position_to_index_overlayoperator= (const Position_to_index_overlay &other)
 Assign operator.
const barcode_typeget_current_barcode () const
 Returns the current barcode of the matrix. Available only if PersistenceMatrixOptions::has_column_pairings is true. More...
void update_representative_cycles ()
 Only available if PersistenceMatrixOptions::can_retrieve_representative_cycles is true. Precomputes the representative cycles of the current state of the filtration represented by the matrix. It does not need to be called before get_representative_cycles is called for the first time, but needs to be called before calling get_representative_cycles again if the matrix was modified in between. Otherwise the old cycles will be returned.
const std::vector< cycle_type > & get_representative_cycles ()
 Only available if PersistenceMatrixOptions::can_retrieve_representative_cycles is true. Returns all representative cycles of the current filtration. More...
const cycle_typeget_representative_cycle (const bar_type &bar)
 Only available if PersistenceMatrixOptions::can_retrieve_representative_cycles is true. Returns the cycle representing the given bar. More...
bool vine_swap_with_z_eq_1_case (pos_index position)
 Only available if PersistenceMatrixOptions::has_vine_update is true. Does the same than vine_swap, but assumes that the swap is non trivial and therefore skips a part of the case study. More...
bool vine_swap (pos_index position)
 Only available if PersistenceMatrixOptions::has_vine_update is true. Does a vine swap between two faces which are consecutives in the filtration. Roughly, if \( F \) is the current filtration represented by the matrix, the method modifies the matrix such that the new state corresponds to a valid state for the filtration \( F' \) equal to \( F \) but with the two faces at position position and position + 1 swapped. Of course, the two faces should not have a face/coface relation which each other ; \( F' \) has to be a valid filtration. See [21] for more information about vine and vineyards. More...
Friends
void swap (Position_to_index_overlay &matrix1, Position_to_index_overlay &matrix2)
 Swap operator.
Detailed Description
template<class Matrix_type, class Master_matrix_type>
class Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >
Template Parameters
%Matrix_typeMatrix type taking the overlay.
Master_matrix_typeAn instanciation of Matrix from which all types and options are deduced.
Member Typedef Documentation
◆ bar_type
template<class Matrix_type , class Master_matrix_type >
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::bar_type = typename Master_matrix_type::Bar
Bar type.
◆ barcode_type
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::barcode_type = typename Master_matrix_type::barcode_type
Barcode type.
◆ boundary_type
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::boundary_type = typename Master_matrix_type::boundary_type
Type of an input column.
◆ Cell_constructor
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::Cell_constructor = typename Master_matrix_type::Cell_constructor
Factory of Cell classes.
◆ cell_rep_type
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::cell_rep_type = typename Master_matrix_type::cell_rep_type
Cell content representative.
◆ Column_settings
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::Column_settings = typename Master_matrix_type::Column_settings
Structure giving access to the columns to necessary external classes.
◆ Column_type
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::Column_type = typename Master_matrix_type::Column_type
Column type.
◆ cycle_type
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::cycle_type = typename Master_matrix_type::cycle_type
Cycle type.
◆ dimension_type
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::dimension_type = typename Master_matrix_type::dimension_type
Dimension value type.
◆ Field_element_type
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::Field_element_type = typename Master_matrix_type::element_type
Type of an field element.
◆ id_index
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::id_index = typename Master_matrix_type::id_index
IDIdx index type.
◆ index
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::index = typename Master_matrix_type::index
MatIdx index type.
◆ pos_index
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::pos_index = typename Master_matrix_type::pos_index
PosIdx index type.
◆ Row_type
using Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::Row_type = typename Master_matrix_type::Row_type
Row type, only necessary with row access option.
Constructor & Destructor Documentation
◆ Position_to_index_overlay() [1/8]
Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::Position_to_index_overlay ( Column_settings colSettings)
inline
Parameters
colSettingsPointer to an existing setting structure for the columns. The structure should contain all the necessary external classes specifically necessary for the choosen column type, such as custom allocators.
◆ Position_to_index_overlay() [2/8]
template<class Boundary_type >
Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::Position_to_index_overlay ( const std::vector< Boundary_type > &  orderedBoundaries,
inline
Template Parameters
Boundary_typeRange type for Matrix::cell_rep_type ranges. Assumed to have a begin(), end() and size() method.
Parameters
orderedBoundariesRange of boundaries: orderedBoundaries is interpreted as a boundary matrix of a filtered simplicial complex, whose boundaries are ordered by filtration order. Therefore, orderedBoundaries[i] should store the boundary of the \( i^{th} \) simplex in the filtration, as an ordered list of indices of its facets (again those indices correspond to their respective position in the matrix). That is why the indices of the simplices are assumed to be consecutifs and starting with 0 (an empty boundary is interpreted as a vertex boundary and not as a non existing simplex). All dimensions up to the maximal dimension of interest have to be present. If only a higher dimension is of interest and not everything should be stored, then use the insert_boundary method instead (after creating the matrix with the Position_to_index_overlay(unsigned int, Column_settings*) constructor preferably).
◆ Position_to_index_overlay() [3/8]
Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::Position_to_index_overlay ( unsigned int  numberOfColumns,
inline
Parameters
numberOfColumnsNumber of columns to reserve space for.
◆ Position_to_index_overlay() [4/8]
Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::Position_to_index_overlay ( Column_settings colSettings,
const BirthComparatorFunction &  birthComparator,
const DeathComparatorFunction &  deathComparator
inline
Warning
If PersistenceMatrixOptions::has_vine_update is false, the comparators are not used. And if PersistenceMatrixOptions::has_vine_update is true, but PersistenceMatrixOptions::has_column_pairings is also true, the comparators are ignored and the current barcode is used to compare birth and deaths. Therefore it is useless to provide them in those cases.
Template Parameters
BirthComparatorFunctionType of the birth comparator: (pos_index, pos_index) -> bool
DeathComparatorFunctionType of the death comparator: (pos_index, pos_index) -> bool
Parameters
birthComparatorMethod taking two PosIdx indices as input and returning true if and only if the birth associated to the first position is strictly less than birth associated to the second one with respect to some self defined order. It is used while swapping two unpaired or two negative columns.
deathComparatorMethod taking two PosIdx indices as input and returning true if and only if the death associated to the first position is strictly less than death associated to the second one with respect to some self defined order. It is used while swapping two positive but paired columns.
◆ Position_to_index_overlay() [5/8]
inline
Warning
Template Parameters
Parameters
orderedBoundariesRange of boundaries: orderedBoundaries is interpreted as a boundary matrix of a filtered simplicial complex, whose boundaries are ordered by filtration order. Therefore, orderedBoundaries[i] should store the boundary of the \( i^{th} \) simplex in the filtration, as an ordered list of indices of its facets (again those indices correspond to their respective position in the matrix). That is why the indices of the simplices are assumed to be consecutifs and starting with 0 (an empty boundary is interpreted as a vertex boundary and not as a non existing simplex). All dimensions up to the maximal dimension of interest have to be present. If only a higher dimension is of interest and not everything should be stored, then use the insert_boundary method instead (after creating the matrix with the Position_to_index_overlay(unsigned int, Column_settings*, const BirthComparatorFunction&, const DeathComparatorFunction&) constructor preferably).
◆ Position_to_index_overlay() [6/8]
inline
Warning
Template Parameters
Parameters
◆ Position_to_index_overlay() [7/8]
Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::Position_to_index_overlay ( const Position_to_index_overlay< Matrix_type, Master_matrix_type > &  matrixToCopy,
Column_settings colSettings = nullptr
inline
Parameters
matrixToCopyMatrix to copy.
colSettingsEither a pointer to an existing setting structure for the columns or a null pointer. The structure should contain all the necessary external classes specifically necessary for the choosen column type, such as custom allocators. If null pointer, the pointer stored in matrixToCopy is used instead.
◆ Position_to_index_overlay() [8/8]
Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::Position_to_index_overlay ( Position_to_index_overlay< Matrix_type, Master_matrix_type > &&  other)
inlinenoexcept
Move constructor.
Parameters
otherMatrix to move.
Member Function Documentation
◆ add_to()
void Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::add_to ( pos_index  sourcePosition,
inline
Warning
They will be no verification to ensure that the addition makes sense for the validity of the matrix. For example, a right-to-left addition could corrupt the computation of the barcode if done blindly. So should be used with care.
Parameters
sourcePositionPosIdx index of the source column.
targetPositionPosIdx index of the target column.
◆ erase_empty_row()
void Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::erase_empty_row ( id_index  rowIndex)
inline
Warning
The removed rows are always assumed to be empty. If it is not the case, the deleted row cells are not removed from their columns. And in the case of intrusive rows, this will generate a segmentation fault when the column cells are destroyed later. The row access is just meant as a "read only" access to the rows and the erase_empty_row method just as a way to specify that a row is empty and can therefore be removed from dictionnaries. This allows to avoid testing the emptiness of a row at each column cell removal, what can be quite frequent.
Parameters
rowIndexRow index of the empty row to remove.
◆ get_column() [1/2]
Position_to_index_overlay< Matrix_type, Master_matrix_type >::Column_type & Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::get_column ( pos_index  position)
inline
Parameters
positionPosIdx index of the column to return.
Returns
Reference to the column.
◆ get_column() [2/2]
const Position_to_index_overlay< Matrix_type, Master_matrix_type >::Column_type & Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::get_column ( pos_index  position) const
inline
Parameters
Returns
Const reference to the column.
◆ get_column_dimension()
Position_to_index_overlay< Matrix_type, Master_matrix_type >::dimension_type Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::get_column_dimension ( pos_index  position) const
inline
Parameters
positionPosIdx index of the face.
Returns
Dimension of the face.
◆ get_column_with_pivot()
Position_to_index_overlay< Matrix_type, Master_matrix_type >::pos_index Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::get_column_with_pivot ( id_index  faceIndex) const
inline
Parameters
faceIndexRow index of the pivot.
Returns
PosIdx index of the column with the given pivot.
◆ get_current_barcode()
const Position_to_index_overlay< Matrix_type, Master_matrix_type >::barcode_type & Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::get_current_barcode
inline
Recall that we assume that the boundaries were inserted in the order of filtration for the barcode to be valid.
Returns
A reference to the barcode. The barcode is a vector of Matrix::Bar. A bar stores three informations: the PosIdx birth index, the PosIdx death index and the dimension of the bar.
◆ get_max_dimension()
Position_to_index_overlay< Matrix_type, Master_matrix_type >::dimension_type Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::get_max_dimension
inline
Returns
The maximal dimension.
◆ get_number_of_columns()
Position_to_index_overlay< Matrix_type, Master_matrix_type >::index Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::get_number_of_columns
inline
Returns
The number of columns.
◆ get_pivot()
Position_to_index_overlay< Matrix_type, Master_matrix_type >::id_index Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::get_pivot ( pos_index  position)
inline
Parameters
positionPosIdx index of the face corresponding to the column.
Returns
The row index of the pivot.
◆ get_representative_cycle()
const Position_to_index_overlay< Matrix_type, Master_matrix_type >::cycle_type & Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::get_representative_cycle ( const bar_type bar)
inline
Parameters
barA bar from the current barcode.
Returns
A const reference to the cycle representing bar.
◆ get_representative_cycles()
const std::vector< typename Position_to_index_overlay< Matrix_type, Master_matrix_type >::cycle_type > & Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::get_representative_cycles
inline
Returns
A const reference to the vector of representative cycles.
◆ get_row() [1/2]
Position_to_index_overlay< Matrix_type, Master_matrix_type >::Row_type & Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::get_row ( id_index  rowIndex)
inline
Parameters
rowIndexRow index of the row to return.
Returns
Reference to the row.
◆ get_row() [2/2]
const Position_to_index_overlay< Matrix_type, Master_matrix_type >::Row_type & Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::get_row ( id_index  rowIndex) const
inline
Parameters
Returns
Const reference to the row.
◆ insert_boundary() [1/2]
void Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::insert_boundary ( const Boundary_type &  boundary,
dimension_type  dim = -1
inline
Different to the constructor, the boundaries do not have to come from a simplicial complex, but also from a more general cell complex. This includes cubical complexes or Morse complexes for example.
When inserted, the given boundary is reduced and from the reduction process, the column is deduced in the form of: IDIdx + linear combination of older column IDIdxs. If the barcode is stored, it will be updated.
Template Parameters
Boundary_typeRange of Matrix::cell_rep_type. Assumed to have a begin(), end() and size() method.
Parameters
boundaryBoundary generating the new column. The content should be ordered by ID.
dimDimension of the face whose boundary is given. If the complex is simplicial, this parameter can be omitted as it can be deduced from the size of the boundary.
◆ insert_boundary() [2/2]
void Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::insert_boundary ( id_index  faceIndex,
inline
As a face has to be inserted before one of its cofaces in a valid filtration (recall that it is assumed that the faces are inserted by order of filtration), it is sufficient to indicate the ID of the face being inserted.
Template Parameters
Parameters
faceIDIDIdx index to use to indentify the new face.
boundaryBoundary generating the new column. The indices of the boundary have to correspond to the faceID values of precedent calls of the method for the corresponding faces and should be ordered in increasing order.
◆ is_zero_cell()
bool Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::is_zero_cell ( pos_index  position,
id_index  rowIndex
) const
inline
Parameters
positionPosIdx index of the face corresponding to the column of the cell.
rowIndexRow index of the row of the cell.
Returns
true If the cell has value zero.
false Otherwise.
◆ is_zero_column()
bool Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::is_zero_column ( pos_index  position)
inline
Note that this method should always return false, as a valid chain matrix never has empty columns.
Parameters
Returns
true If the column has value zero.
false Otherwise.
◆ multiply_source_and_add_to()
void Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::multiply_source_and_add_to ( const Field_element_type coefficient,
inline
Warning
Parameters
coefficientValue to multiply.
◆ multiply_target_and_add_to()
void Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::multiply_target_and_add_to ( pos_index  sourcePosition,
inline
Warning
Parameters
◆ remove_last()
void Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::remove_last
inline
See also remove_maximal_face.
◆ remove_maximal_face()
void Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::remove_maximal_face ( pos_index  position)
inline
See also remove_last.
Parameters
positionPosIdx index of the face to remove.
◆ reset()
void Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::reset ( Column_settings colSettings)
inline
Parameters
◆ vine_swap()
bool Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::vine_swap ( pos_index  position)
inline
Parameters
positionPosIdx index of the first face to swap. The second one has to be at position + 1.
Returns
true If the barcode changed from the swap.
false Otherwise.
◆ vine_swap_with_z_eq_1_case()
bool Gudhi::persistence_matrix::Position_to_index_overlay< Matrix_type, Master_matrix_type >::vine_swap_with_z_eq_1_case ( pos_index  position)
inline
Parameters
Returns
false Otherwise.
The documentation for this class was generated from the following file:
