Concept of the field operator classes needed for the class Matrix.
More...
| | FieldOperators (characteristic_type characteristic=0) |
| | Default constructor. If a non-zero characteristic is given, initializes the field with it. The characteristic can later be changed again or initialized with set_characteristic. More...
| void | set_characteristic (const characteristic_type &characteristic) |
| | Sets the characteristic of the field. Can eventually be omitted if the characteristic of the class is fixed. More...
| const characteristic_type & | get_characteristic () const |
| | Returns the current characteristic. More...
| template<typename Integer_type > |
| element_type | get_value (Integer_type e) const |
| | Returns the value of an integer in the field. That is the positive value of the integer modulo the current characteristic. More...
| void | add_inplace (element_type &e1, const element_type &e2) const |
| | Stores in the first element the sum of two given elements in the field, that is (e1 + e2) % characteristic, such that the result is positive. More...
| void | multiply_inplace (element_type &e1, const element_type &e2) const |
| | Stores in the first element the multiplication of two given elements in the field, that is (e1 * e2) % characteristic, such that the result is positive. More...
| void | multiply_and_add_inplace_front (element_type &e, const element_type &m, const element_type &a) const |
| | Multiplies the first element with the second one and adds the third one, that is (e * m + a) % characteristic, such that the result is positive. Stores the result in the first element. More...
| void | multiply_and_add_inplace_back (const element_type &e, const element_type &m, element_type &a) const |
| | Multiplies the first element with the second one and adds the third one, that is (e * m + a) % characteristic, such that the result is positive. Stores the result in the third element. More...
| element_type | get_inverse (const element_type &e) const |
| | Returns the inverse of the given element in the field. More...
FieldOperators & | operator= (FieldOperators other) |
| | Assign operator.
◆ characteristic_type
Type for the field characteristic.
◆ element_type
Type for the elements in the field.
◆ FieldOperators()
| Gudhi::persistence_matrix::FieldOperators::FieldOperators |
characteristic_type |
characteristic = 0 | ) |
- Parameters
| characteristic | Prime number corresponding to the desired characteristic of the field. |
◆ add_inplace()
- Parameters
| e1 | First element. |
| e2 | Second element. |
◆ get_additive_identity()
| static const element_type& Gudhi::persistence_matrix::FieldOperators::get_additive_identity |
static |
Returns the additive identity of the field.
- Returns
- The additive identity of the field.
◆ get_characteristic()
| const characteristic_type& Gudhi::persistence_matrix::FieldOperators::get_characteristic |
const |
- Returns
- The value of the current characteristic.
◆ get_inverse()
- Parameters
| e | Element to get the inverse from. |
- Returns
- Inverse in the current field of
e % characteristic.
◆ get_multiplicative_identity()
| static const element_type& Gudhi::persistence_matrix::FieldOperators::get_multiplicative_identity |
static |
Returns the multiplicative identity of the field.
- Returns
- The multiplicative identity of the field.
◆ get_value()
| element_type Gudhi::persistence_matrix::FieldOperators::get_value |
Integer_type |
e | ) |
const |
- Template Parameters
| Integer_type | A native integer type: int, unsigned int, long int, bool, etc. |
- Parameters
| e | Integer to return the value from. |
- Returns
e modulo the current characteristic, such that the result is positive.
◆ multiply_and_add_inplace_back()
- Parameters
| e | First element. |
| m | Second element. |
| a | Third element. |
◆ multiply_and_add_inplace_front()
- Parameters
◆ multiply_inplace()
- Parameters
◆ set_characteristic()
| void Gudhi::persistence_matrix::FieldOperators::set_characteristic |
characteristic | ) |
- Parameters
The documentation for this class was generated from the following file:
