Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class > Class Template Reference
Class defining operators for the \( \mathbb{F}_p \) field for any prime number \( p \). More...
Public Types
using element_type = Unsigned_integer_type
using characteristic_type = element_type
Public Member Functions
 Zp_field_operators (characteristic_type characteristic=0)
 Default constructor. If a non-zero characteristic is given, initializes the field with it. The characteristic can later be changed again or initialized with set_characteristic. More...
 Zp_field_operators (const Zp_field_operators &toCopy)
 Copy constructor. More...
 Zp_field_operators (Zp_field_operators &&toMove) noexcept
 Move constructor. More...
void set_characteristic (characteristic_type characteristic)
 Sets the characteristic of the field. More...
const characteristic_typeget_characteristic () const
 Returns the current characteristic. More...
element_type get_value (element_type e) const
 Returns the value of an integer in the field. That is the positive value of the integer modulo the current characteristic. More...
template<typename Signed_integer_type , class = isSignedInteger<Signed_integer_type>>
element_type get_value (Signed_integer_type e) const
element_type add (element_type e1, element_type e2) const
 Returns the sum of two elements in the field. More...
void add_inplace (element_type &e1, element_type e2) const
 Stores in the first element the sum of two given elements in the field, that is (e1 + e2) % characteristic, such that the result is positive. More...
element_type substract (element_type e1, element_type e2) const
 Returns the substraction in the field of the first element by the second element. More...
void substract_inplace_front (element_type &e1, element_type e2) const
 Stores in the first element the substraction in the field of the first element by the second element, that is (e1 - e2) % 2, such that the result is positive. More...
void substract_inplace_back (element_type e1, element_type &e2) const
 Stores in the second element the substraction in the field of the first element by the second element, that is (e1 - e2) % 2, such that the result is positive. More...
element_type multiply (element_type e1, element_type e2) const
 Returns the multiplication of two elements in the field. More...
void multiply_inplace (element_type &e1, element_type e2) const
 Stores in the first element the multiplication of two given elements in the field, that is (e1 * e2) % characteristic, such that the result is positive. More...
element_type multiply_and_add (element_type e, element_type m, element_type a) const
 Multiplies the first element with the second one and adds the third one. Returns the result in the field. More...
void multiply_and_add_inplace_front (element_type &e, element_type m, element_type a) const
 Multiplies the first element with the second one and adds the third one, that is (e * m + a) % characteristic, such that the result is positive. Stores the result in the first element. More...
void multiply_and_add_inplace_back (element_type e, element_type m, element_type &a) const
 Multiplies the first element with the second one and adds the third one, that is (e * m + a) % characteristic, such that the result is positive. Stores the result in the third element. More...
element_type add_and_multiply (element_type e, element_type a, element_type m) const
 Adds the first element to the second one and multiplies the third one with it. Returns the result in the field. More...
void add_and_multiply_inplace_front (element_type &e, element_type a, element_type m) const
 Adds the first element to the second one and multiplies the third one with it, that is ((e + a) * m) % characteristic, such that the result is positive. Stores the result in the first element. More...
void add_and_multiply_inplace_back (element_type e, element_type a, element_type &m) const
 Adds the first element to the second one and multiplies the third one with it, that is ((e + a) * m) % characteristic, such that the result is positive. Stores the result in the third element. More...
bool are_equal (element_type e1, element_type e2) const
 Returns true if the two given elements are equal in the field, false otherwise. More...
element_type get_inverse (element_type e) const
 Returns the inverse of the given element in the field. More...
std::pair< element_type, characteristic_typeget_partial_inverse (element_type e, characteristic_type productOfCharacteristics) const
 For interface purposes with multi-fields. Returns the inverse together with the second argument. More...
Zp_field_operatorsoperator= (Zp_field_operators other)
 Assign operator.
Static Public Member Functions
static constexpr element_type get_additive_identity ()
 Returns the additive identity of the field. More...
static constexpr element_type get_multiplicative_identity ()
 Returns the multiplicative identity of the field. More...
static constexpr element_type get_partial_multiplicative_identity ([[maybe_unused]] characteristic_type productOfCharacteristics)
 For interface purposes with multi-fields. Returns the multiplicative identity of the field. More...
Friends
void swap (Zp_field_operators &f1, Zp_field_operators &f2)
 Swap operator.
Detailed Description
template<typename Unsigned_integer_type = unsigned int, class = std::enable_if_t<std::is_unsigned_v<Unsigned_integer_type> >>
class Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >
Template Parameters
Unsigned_integer_typeA native unsigned integer type: unsigned int, long unsigned int, etc. Will be used as the field element type.
Examples
example_field_operations.cpp.
Member Typedef Documentation
◆ characteristic_type
using Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::characteristic_type = element_type
Type for the field characteristic.
◆ element_type
using Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::element_type = Unsigned_integer_type
Type for the elements in the field.
Constructor & Destructor Documentation
◆ Zp_field_operators() [1/3]
Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::Zp_field_operators ( characteristic_type  characteristic = 0)
inline
Parameters
characteristicPrime number corresponding to the desired characteristic of the field.
◆ Zp_field_operators() [2/3]
Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::Zp_field_operators ( const Zp_field_operators< Unsigned_integer_type, class > &  toCopy)
inline
Copy constructor.
Parameters
toCopyOperators to copy.
◆ Zp_field_operators() [3/3]
Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::Zp_field_operators ( Zp_field_operators< Unsigned_integer_type, class > &&  toMove)
inlinenoexcept
Move constructor.
Parameters
toMoveOperators to move.
Member Function Documentation
◆ add()
element_type Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::add ( element_type  e1,
element_type  e2
) const
inline
Parameters
e1First element.
e2Second element.
Returns
◆ add_and_multiply()
element_type Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::add_and_multiply ( element_type  e,
element_type  a,
element_type  m
) const
inline
Warning
Not overflow safe.
Parameters
eFirst element.
aSecond element.
mThird element.
Returns
◆ add_and_multiply_inplace_back()
void Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::add_and_multiply_inplace_back ( element_type  e,
element_type  a,
element_type m
) const
inline
Warning
Not overflow safe.
Parameters
eFirst element.
aSecond element.
mThird element.
◆ add_and_multiply_inplace_front()
void Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::add_and_multiply_inplace_front ( element_type e,
element_type  a,
element_type  m
) const
inline
Warning
Not overflow safe.
Parameters
eFirst element.
aSecond element.
mThird element.
◆ add_inplace()
void Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::add_inplace ( element_type e1,
element_type  e2
) const
inline
Parameters
e1First element.
e2Second element.
◆ are_equal()
bool Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::are_equal ( element_type  e1,
element_type  e2
) const
inline
Parameters
e1First element to compare.
e2Second element to compare.
Returns
true If e1 % characteristic == e2 % characteristic.
false Otherwise.
◆ get_additive_identity()
static constexpr element_type Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::get_additive_identity ( )
inlinestaticconstexpr
Returns
0.
◆ get_characteristic()
const characteristic_type& Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::get_characteristic ( ) const
inline
Returns
The value of the current characteristic.
◆ get_inverse()
element_type Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::get_inverse ( element_type  e) const
inline
Parameters
eElement to get the inverse from.
Returns
Inverse in the current field of e % characteristic.
◆ get_multiplicative_identity()
static constexpr element_type Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::get_multiplicative_identity ( )
Returns
1.
◆ get_partial_inverse()
std::pair<element_type, characteristic_type> Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::get_partial_inverse ( element_type  e,
) const
inline
Parameters
productOfCharacteristicsSome value.
Returns
Pair whose first element is the inverse of e and the second element is productOfCharacteristics.
◆ get_partial_multiplicative_identity()
static constexpr element_type Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::get_partial_multiplicative_identity ( [[maybe_unused] ] characteristic_type  productOfCharacteristics)
Parameters
Returns
1.
◆ get_value() [1/2]
element_type Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::get_value ( element_type  e) const
inline
Parameters
eUnsigned integer to return the value from.
Returns
e modulo the current characteristic, such that the result is positive.
◆ get_value() [2/2]
element_type Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::get_value ( Signed_integer_type  e) const
inline
Template Parameters
Signed_integer_typeA native signed integer type: int, long int, etc.
Parameters
eInteger to return the value from.
Returns
◆ multiply()
element_type Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::multiply ( element_type  e1,
element_type  e2
) const
inline
Parameters
e1First element.
e2Second element.
Returns
◆ multiply_and_add()
element_type Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::multiply_and_add ( element_type  e,
element_type  m,
element_type  a
) const
inline
Warning
Not overflow safe.
Parameters
eFirst element.
mSecond element.
aThird element.
Returns
◆ multiply_and_add_inplace_back()
void Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::multiply_and_add_inplace_back ( element_type  e,
element_type  m,
element_type a
) const
inline
Warning
Not overflow safe.
Parameters
eFirst element.
mSecond element.
aThird element.
◆ multiply_and_add_inplace_front()
void Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::multiply_and_add_inplace_front ( element_type e,
element_type  m,
element_type  a
) const
inline
Warning
Not overflow safe.
Parameters
eFirst element.
mSecond element.
aThird element.
◆ multiply_inplace()
void Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::multiply_inplace ( element_type e1,
element_type  e2
) const
inline
Parameters
e1First element.
e2Second element.
◆ set_characteristic()
void Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::set_characteristic ( characteristic_type  characteristic)
inline
Parameters
◆ substract()
element_type Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::substract ( element_type  e1,
element_type  e2
) const
inline
Parameters
e1First element.
e2Second element.
Returns
(e1 - e2) % characteristic, such that the result is positive.
◆ substract_inplace_back()
void Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::substract_inplace_back ( element_type  e1,
element_type e2
) const
inline
Parameters
e1First element.
e2Second element.
◆ substract_inplace_front()
void Gudhi::persistence_fields::Zp_field_operators< Unsigned_integer_type, class >::substract_inplace_front ( element_type e1,
element_type  e2
) const
inline
Parameters
e1First element.
e2Second element.
The documentation for this class was generated from the following file:
