Gudhi::persistence_fields::Multi_field_operators Class Reference
Class defining operators for a multi-field with "consecutive" charateristic range. More...
Public Types
using element_type = mpz_class
using characteristic_type = element_type
Public Member Functions
 Multi_field_operators ()
 Default constructor, sets the product of all characteristics to 0.
 Multi_field_operators (int minCharacteristic, int maxCharacteristic)
 Constructor setting the characteristics to all prime numbers between the two given integers. More...
 Multi_field_operators (const Multi_field_operators &toCopy)
 Copy constructor. More...
 Multi_field_operators (Multi_field_operators &&toMove) noexcept
 Move constructor. More...
void set_characteristic (int minimum, int maximum)
 Set the characteristics of the field, which are stored in a single value as a product of all of them. The characteristics will be all prime numbers in the given interval. More...
const characteristic_type & get_characteristic () const
 Returns the current characteristics as the product of all of them. More...
element_type get_value (element_type e) const
 Returns the value of an element in the field. That is the positive value of the integer modulo the current characteristic. More...
void get_value_inplace (element_type &e) const
 Stores in the given element the value of this element in the field. That is the positive value of the integer modulo the current characteristic. More...
element_type add (element_type e1, const element_type &e2) const
 Returns the sum of two elements in the field. More...
void add_inplace (element_type &e1, const element_type &e2) const
 Stores in the first element the sum of two given elements in the field, that is (e1 + e2) % productOfAllCharacteristics, such that the result is positive. More...
element_type substract (element_type e1, const element_type &e2) const
 Returns the substraction in the field of the first element by the second element. More...
void substract_inplace_front (element_type &e1, const element_type &e2) const
 Stores in the first element the substraction in the field of the first element by the second element, that is (e1 - e2) % productOfAllCharacteristics, such that the result is positive. More...
void substract_inplace_back (const element_type &e1, element_type &e2) const
 Stores in the second element the substraction in the field of the first element by the second element, that is (e1 - e2) % productOfAllCharacteristics, such that the result is positive. More...
element_type multiply (element_type e1, const element_type &e2) const
 Returns the multiplication of two elements in the field. More...
void multiply_inplace (element_type &e1, const element_type &e2) const
 Stores in the first element the multiplication of two given elements in the field, that is (e1 * e2) % productOfAllCharacteristics, such that the result is positive. More...
element_type multiply_and_add (element_type e, const element_type &m, const element_type &a) const
 Multiplies the first element with the second one and adds the third one. Returns the result in the field. More...
void multiply_and_add_inplace_front (element_type &e, const element_type &m, const element_type &a) const
 Multiplies the first element with the second one and adds the third one, that is (e * m + a) % productOfAllCharacteristics, such that the result is positive. Stores the result in the first element. More...
void multiply_and_add_inplace_back (const element_type &e, const element_type &m, element_type &a) const
 Multiplies the first element with the second one and adds the third one, that is (e * m + a) % productOfAllCharacteristics, such that the result is positive. Stores the result in the third element. More...
element_type add_and_multiply (element_type e, const element_type &a, const element_type &m) const
 Adds the first element to the second one and multiplies the third one with it. Returns the result in the field. More...
void add_and_multiply_inplace_front (element_type &e, const element_type &a, const element_type &m) const
 Adds the first element to the second one and multiplies the third one with it, that is ((e + a) * m) % productOfAllCharacteristics, such that the result is positive. Stores the result in the first element. More...
void add_and_multiply_inplace_back (const element_type &e, const element_type &a, element_type &m) const
 Adds the first element to the second one and multiplies the third one with it, that is ((e + a) * m) % productOfAllCharacteristics, such that the result is positive. Stores the result in the third element. More...
bool are_equal (const element_type &e1, const element_type &e2) const
 Returns true if the two given elements are equal in the field, false otherwise. More...
element_type get_inverse (const element_type &e) const
 Returns the inverse of the given element in the sense of [6] with respect to the product of all characteristics. More...
std::pair< element_type, characteristic_type > get_partial_inverse (const element_type &e, const characteristic_type &productOfCharacteristics) const
 Returns the inverse of the given element in the multi-field corresponding to the given sub-product of the product of all characteristics in the multi-field. See [6] for more details. More...
element_type get_partial_multiplicative_identity (const characteristic_type &productOfCharacteristics) const
 Returns the partial multiplicative identity of the multi-field from the given product. See [6] for more details. More...
Multi_field_operators & operator= (Multi_field_operators other)
 Assign operator.
Static Public Member Functions
static const element_type & get_additive_identity ()
 Returns the additive identity of a field. More...
static const element_type & get_multiplicative_identity ()
 Returns the multiplicative identity of a field. More...
Friends
void swap (Multi_field_operators &f1, Multi_field_operators &f2)
 Swap operator.
Detailed Description
Member Typedef Documentation
◆ characteristic_type
◆ element_type
Type for the elements in the field.
Constructor & Destructor Documentation
◆ Multi_field_operators() [1/3]
Gudhi::persistence_fields::Multi_field_operators::Multi_field_operators ( int  minCharacteristic,
inline
Parameters
minCharacteristicSmallest value of a prime.
maxCharacteristicHeighest value of a prime.
◆ Multi_field_operators() [2/3]
Gudhi::persistence_fields::Multi_field_operators::Multi_field_operators ( const Multi_field_operators &  toCopy)
inline
Copy constructor.
Parameters
toCopyOperators to copy.
◆ Multi_field_operators() [3/3]
Gudhi::persistence_fields::Multi_field_operators::Multi_field_operators ( Multi_field_operators &&  toMove)
inlinenoexcept
Move constructor.
Parameters
toMoveOperators to move.
Member Function Documentation
◆ add()
element_type Gudhi::persistence_fields::Multi_field_operators::add ( element_type  e1,
const element_type &  e2
) const
inline
Parameters
e1First element.
e2Second element.
Returns
◆ add_and_multiply()
element_type Gudhi::persistence_fields::Multi_field_operators::add_and_multiply ( element_type  e,
const element_type &  a,
const element_type &  m
) const
inline
Parameters
eFirst element.
aSecond element.
mThird element.
Returns
◆ add_and_multiply_inplace_back()
void Gudhi::persistence_fields::Multi_field_operators::add_and_multiply_inplace_back ( const element_type &  e,
element_type &  m
) const
inline
Parameters
eFirst element.
aSecond element.
mThird element.
◆ add_and_multiply_inplace_front()
void Gudhi::persistence_fields::Multi_field_operators::add_and_multiply_inplace_front ( element_type &  e,
) const
inline
Parameters
eFirst element.
aSecond element.
mThird element.
◆ add_inplace()
void Gudhi::persistence_fields::Multi_field_operators::add_inplace ( element_type &  e1,
) const
inline
Parameters
e1First element.
e2Second element.
◆ are_equal()
bool Gudhi::persistence_fields::Multi_field_operators::are_equal ( const element_type &  e1,
) const
inline
Parameters
e1First element to compare.
e2Second element to compare.
Returns
true If e1 % productOfAllCharacteristics == e2 % productOfAllCharacteristics.
false Otherwise.
◆ get_additive_identity()
static const element_type& Gudhi::persistence_fields::Multi_field_operators::get_additive_identity ( )
inlinestatic
Returns
The additive identity of a field.
◆ get_characteristic()
const characteristic_type& Gudhi::persistence_fields::Multi_field_operators::get_characteristic ( ) const
inline
Returns
The value of the current characteristic.
◆ get_inverse()
element_type Gudhi::persistence_fields::Multi_field_operators::get_inverse ( const element_type &  e) const
inline
Parameters
eElement to get the inverse from.
Returns
Inverse in the current field.
◆ get_multiplicative_identity()
static const element_type& Gudhi::persistence_fields::Multi_field_operators::get_multiplicative_identity ( )
inlinestatic
Returns
The multiplicative identity of a field.
◆ get_partial_inverse()
std::pair<element_type, characteristic_type> Gudhi::persistence_fields::Multi_field_operators::get_partial_inverse ( const element_type &  e,
const characteristic_type &  productOfCharacteristics
) const
inline
Parameters
productOfCharacteristicsProduct of the different characteristics to take into account in the multi-field.
Returns
Pair of the inverse of e and the characteristic the inverse is coming from.
◆ get_partial_multiplicative_identity()
element_type Gudhi::persistence_fields::Multi_field_operators::get_partial_multiplicative_identity ( const characteristic_type &  productOfCharacteristics) const
inline
Parameters
Returns
The partial multiplicative identity of the multi-field.
◆ get_value()
element_type Gudhi::persistence_fields::Multi_field_operators::get_value ( element_type  e) const
inline
Parameters
eElement to return the value from.
Returns
e modulo the current characteristic, such that the result is positive.
◆ get_value_inplace()
void Gudhi::persistence_fields::Multi_field_operators::get_value_inplace ( element_type &  e) const
inline
Parameters
◆ multiply()
element_type Gudhi::persistence_fields::Multi_field_operators::multiply ( element_type  e1,
) const
inline
Parameters
e1First element.
e2Second element.
Returns
◆ multiply_and_add()
element_type Gudhi::persistence_fields::Multi_field_operators::multiply_and_add ( element_type  e,
const element_type &  m,
) const
inline
Parameters
eFirst element.
mSecond element.
aThird element.
Returns
◆ multiply_and_add_inplace_back()
void Gudhi::persistence_fields::Multi_field_operators::multiply_and_add_inplace_back ( const element_type &  e,
element_type &  a
) const
inline
Parameters
eFirst element.
mSecond element.
aThird element.
◆ multiply_and_add_inplace_front()
void Gudhi::persistence_fields::Multi_field_operators::multiply_and_add_inplace_front ( element_type &  e,
) const
inline
Parameters
eFirst element.
mSecond element.
aThird element.
◆ multiply_inplace()
void Gudhi::persistence_fields::Multi_field_operators::multiply_inplace ( element_type &  e1,
) const
inline
Parameters
e1First element.
e2Second element.
◆ set_characteristic()
void Gudhi::persistence_fields::Multi_field_operators::set_characteristic ( int  minimum,
int  maximum
inline
Parameters
minimumSmallest value of a prime.
maximumHeighest value of a prime.
◆ substract()
element_type Gudhi::persistence_fields::Multi_field_operators::substract ( element_type  e1,
) const
inline
Parameters
e1First element.
e2Second element.
Returns
◆ substract_inplace_back()
void Gudhi::persistence_fields::Multi_field_operators::substract_inplace_back ( const element_type &  e1,
element_type &  e2
) const
inline
Parameters
e1First element.
e2Second element.
◆ substract_inplace_front()
void Gudhi::persistence_fields::Multi_field_operators::substract_inplace_front ( element_type &  e1,
) const
inline
Parameters
e1First element.
e2Second element.
The documentation for this class was generated from the following file:
