Contains the options for the matrix template. More...
Go to the source code of this file.
Classes | |
| struct | Gudhi::persistence_matrix::Default_options< col_type, is_z2_only, FieldOperators > |
| Default option structure for Matrix class. See the PersistenceMatrixOptions concept for a more detailed description of the fields. Produces a base matrix with no enabled option. More... | |
| struct | Gudhi::persistence_matrix::Zigzag_options< column_type > |
| Options used for the Zigzag persistence module. More... | |
| struct | Gudhi::persistence_matrix::Representative_cycles_options< col_type > |
| Options needed to use the representative cycles. More... | |
| struct | Gudhi::persistence_matrix::Multi_persistence_options< column_type > |
| Options used by the Multipersistence module. More... | |
| struct | Gudhi::persistence_matrix::Cohomology_persistence_options< column_type, is_z2_only, FieldOperators > |
| Options used by the cohomology module. More... | |
Namespaces | |
| Gudhi | |
| Gudhi namespace. | |
| Gudhi::persistence_matrix | |
| Persistence matrix namespace. | |
Enumerations | |
| enum | Gudhi::persistence_matrix::Column_types { Gudhi::persistence_matrix::LIST , Gudhi::persistence_matrix::SET , Gudhi::persistence_matrix::HEAP , Gudhi::persistence_matrix::VECTOR , Gudhi::persistence_matrix::NAIVE_VECTOR , Gudhi::persistence_matrix::UNORDERED_SET , Gudhi::persistence_matrix::INTRUSIVE_LIST , Gudhi::persistence_matrix::INTRUSIVE_SET } |
| List of column types. More... | |
| enum | Gudhi::persistence_matrix::Column_indexation_types { Gudhi::persistence_matrix::CONTAINER , Gudhi::persistence_matrix::POSITION , Gudhi::persistence_matrix::IDENTIFIER } |
| List if indexation schemes. See description of indexation schemes for more details about the meaning of the indexation types. More... | |
