Options needed to use the representative cycles.
More...
template<Column_types col_type = Column_types::INTRUSIVE_SET>
struct Gudhi::persistence_matrix::Representative_cycles_options< col_type >
- Template Parameters
| col_type | Column type for the matrix. |
The documentation for this struct was generated from the following file:
