Options used by the cohomology module.
More...
template<Column_types column_type = Column_types::INTRUSIVE_LIST, bool is_z2_only = true, class FieldOperators = persistence_fields::Zp_field_operators<>>
struct Gudhi::persistence_matrix::Cohomology_persistence_options< column_type, is_z2_only, FieldOperators >
- Template Parameters
column_type | Column type for the matrix. |
is_z2_only | True if Z2. |
FieldOperators | Field operator. |
The documentation for this struct was generated from the following file:
