Options used for the Zigzag persistence module.
More...
template<Column_types column_type = Column_types::INTRUSIVE_LIST>
struct Gudhi::persistence_matrix::Zigzag_options< column_type >
- Template Parameters
| column_type | Column type for the matrix. |
The documentation for this struct was generated from the following file:
