Field namespace. More...
Classes | |
| class | Multi_field_element |
| Class representing an element of a multi-field. The characteristics will corresponds to all prime numbers in the interval given as template. More... | |
| class | Multi_field_element_with_small_characteristics |
Class representing an element of a multi-field, such that the product of all characteristics fits into the given Unsigned_integer_type template argument. The characteristics will corresponds to all prime numbers in the interval given as other template arguments. More... | |
| class | Multi_field_operators |
| Class defining operators for a multi-field with "consecutive" characteristic range. More... | |
| class | Multi_field_operators_with_small_characteristics |
Class defining operators for a multi-field with "consecutive" characteristic range, such that productOfAllCharacteristics ^ 2 fits into an unsigned int. More... | |
| class | Shared_multi_field_element |
| Class representing an element of a multi-field. If each instantiation of the class can represent another element, they all share the same characteristics. That is if the characteristics are set for one, they will be set for all the others. The characteristics can be set before instantiating the elements with the static Shared_multi_field_element::initialize method. More... | |
| class | Shared_multi_field_element_with_small_characteristics |
Class representing an element of a multi-field, such that productOfAllCharacteristics ^ 2 fits into the given Unsigned_integer_type template argument. If each instantiation of the class can represent another element, they all share the same characteristics. That is if the characteristics are set for one, they will be set for all the others. The characteristics can be set before instantiating the elements with the static Shared_multi_field_element_with_small_characteristics::initialize method. More... | |
| class | Shared_Zp_field_element |
| Class representing an element of the \( \mathbb{F}_p \) field for any prime number \( p \). If each instantiation of the class can represent another element, they all share the same characteristics. That is if the characteristics are set for one, they will be set for all the others. The characteristics can be set before instantiating the elements with the static Shared_Zp_field_element::initialize method. More... | |
| class | Z2_field_element |
| Class representing an element of the \( \mathbb{F}_2 \) field. More... | |
| class | Z2_field_operators |
| Class defining operators for the \( \mathbb{F}_2 \) field. More... | |
| class | Zp_field_element |
| Class representing an element of the \( \mathbb{F}_p \) field for any prime number \( p \). More... | |
| class | Zp_field_operators |
| Class defining operators for the \( \mathbb{F}_p \) field for any prime number \( p \). More... | |
Field namespace.
