Gudhi::persistence_fields::Shared_multi_field_element Class Reference
Class representing an element of a multi-field. If each instantiation of the class can represent another element, they all share the same characteristics. That is if the characteristics are set for one, they will be set for all the others. The characteristics can be set before instantiating the elements with the static Shared_multi_field_element::initialize method. More...
#include <gudhi/Fields/Multi_field_shared.h>
Public Types
using Element = mpz_class
using Characteristic = Element
Public Member Functions
 Shared_multi_field_element ()
 Default constructor. Sets the element to 0.
 Shared_multi_field_element (Element element)
 Constructor setting the element to the given value. More...
 Shared_multi_field_element (const Shared_multi_field_element &toCopy)
 Copy constructor. More...
 Shared_multi_field_element (Shared_multi_field_element &&toMove) noexcept
 Move constructor. More...
Shared_multi_field_element & operator= (Shared_multi_field_element other)
 Assign operator.
Shared_multi_field_element & operator= (const Element &value)
 Assign operator.
 operator unsigned int () const
 Casts the element into an unsigned int.
 operator mpz_class () const
 Casts the element into a mpz_class.
Shared_multi_field_element get_inverse () const
 Returns the inverse of the element in the multi-field, see [6]. More...
std::pair< Shared_multi_field_element, Characteristic > get_partial_inverse (const Characteristic &productOfCharacteristics) const
 Returns the inverse of the element with respect to a sub-product of the characteristics in the multi-field, see [6]. More...
Element get_value () const
 Returns the value of the element. More...
Static Public Member Functions
static void initialize (unsigned int minimum, unsigned int maximum)
 Initialize the multi-field to the characteristics (primes) contained in the given interval. Should be called first before constructing the field elements. More...
static Shared_multi_field_element get_additive_identity ()
 Returns the additive identity of a field. More...
static Shared_multi_field_element get_multiplicative_identity ()
 Returns the multiplicative identity of a field. More...
static Shared_multi_field_element get_partial_multiplicative_identity (const Characteristic &productOfCharacteristics)
 Returns the partial multiplicative identity of the multi-field from the given product. See [6] for more details. More...
static Characteristic get_characteristic ()
 Returns the product of all characteristics. More...
Friends
void operator+= (Shared_multi_field_element &f1, Shared_multi_field_element const &f2)
 operator+=
Shared_multi_field_element operator+ (Shared_multi_field_element f1, Shared_multi_field_element const &f2)
 operator+
void operator+= (Shared_multi_field_element &f, Element const v)
 operator+=
Shared_multi_field_element operator+ (Shared_multi_field_element f, Element const v)
 operator+
Element operator+ (Element v, Shared_multi_field_element const &f)
 operator+
void operator-= (Shared_multi_field_element &f1, Shared_multi_field_element const &f2)
 operator-=
Shared_multi_field_element operator- (Shared_multi_field_element f1, Shared_multi_field_element const &f2)
 operator-
void operator-= (Shared_multi_field_element &f, Element const v)
 operator-=
Shared_multi_field_element operator- (Shared_multi_field_element f, Element const v)
 operator-
Element operator- (Element v, Shared_multi_field_element const &f)
 operator-
void operator*= (Shared_multi_field_element &f1, Shared_multi_field_element const &f2)
 operator*=
Shared_multi_field_element operator* (Shared_multi_field_element f1, Shared_multi_field_element const &f2)
 operator*
void operator*= (Shared_multi_field_element &f, Element const v)
 operator*=
Shared_multi_field_element operator* (Shared_multi_field_element f, Element const v)
 operator*
Element operator* (Element v, Shared_multi_field_element const &f)
 operator*
bool operator== (const Shared_multi_field_element &f1, const Shared_multi_field_element &f2)
 operator==
bool operator== (const Element &v, const Shared_multi_field_element &f)
 operator==
bool operator== (const Shared_multi_field_element &f, const Element &v)
 operator==
bool operator!= (const Shared_multi_field_element &f1, const Shared_multi_field_element &f2)
 operator!=
bool operator!= (const Element &v, const Shared_multi_field_element &f)
 operator!=
bool operator!= (const Shared_multi_field_element &f, const Element &v)
 operator!=
void swap (Shared_multi_field_element &f1, Shared_multi_field_element &f2)
 Swap operator.
Detailed Description
Member Typedef Documentation
◆ Characteristic
◆ Element
Type for the elements in the field.
Constructor & Destructor Documentation
◆ Shared_multi_field_element() [1/3]
Gudhi::persistence_fields::Shared_multi_field_element::Shared_multi_field_element ( Element  element)
inline
Parameters
elementValue of the element.
◆ Shared_multi_field_element() [2/3]
Gudhi::persistence_fields::Shared_multi_field_element::Shared_multi_field_element ( const Shared_multi_field_element &  toCopy)
inline
Copy constructor.
Parameters
toCopyElement to copy.
◆ Shared_multi_field_element() [3/3]
Gudhi::persistence_fields::Shared_multi_field_element::Shared_multi_field_element ( Shared_multi_field_element &&  toMove)
inlinenoexcept
Move constructor.
Parameters
toMoveElement to move.
Member Function Documentation
◆ get_additive_identity()
Shared_multi_field_element Gudhi::persistence_fields::Shared_multi_field_element::get_additive_identity ( )
inlinestatic
Returns
The additive identity of a field.
◆ get_characteristic()
Shared_multi_field_element::Characteristic Gudhi::persistence_fields::Shared_multi_field_element::get_characteristic ( )
inlinestatic
Returns
The product of all characteristics.
◆ get_inverse()
Shared_multi_field_element Gudhi::persistence_fields::Shared_multi_field_element::get_inverse ( ) const
inline
Returns
The inverse.
◆ get_multiplicative_identity()
Shared_multi_field_element Gudhi::persistence_fields::Shared_multi_field_element::get_multiplicative_identity ( )
inlinestatic
Returns
The multiplicative identity of a field.
◆ get_partial_inverse()
std::pair< Shared_multi_field_element, Shared_multi_field_element::Characteristic > Gudhi::persistence_fields::Shared_multi_field_element::get_partial_inverse ( const Characteristic &  productOfCharacteristics) const
inline
Parameters
productOfCharacteristicsSub-product of the characteristics.
Returns
Pair of the inverse and the characteristic the inverse corresponds to.
◆ get_partial_multiplicative_identity()
Shared_multi_field_element Gudhi::persistence_fields::Shared_multi_field_element::get_partial_multiplicative_identity ( const Characteristic &  productOfCharacteristics)
inlinestatic
Parameters
productOfCharacteristicsProduct of the different characteristics to take into account in the multi-field.
Returns
The partial multiplicative identity of the multi-field.
◆ get_value()
Shared_multi_field_element::Element Gudhi::persistence_fields::Shared_multi_field_element::get_value ( ) const
inline
Returns
◆ initialize()
void Gudhi::persistence_fields::Shared_multi_field_element::initialize ( unsigned int  minimum,
inlinestatic
Parameters
minimumLowest value in the interval.
maximumHighest value in the interval.
The documentation for this class was generated from the following file:
