Gudhi::persistence_fields::Multi_field_operators Class Reference
Class defining operators for a multi-field with "consecutive" characteristic range. More...
#include <gudhi/Fields/Multi_field_operators.h>
Public Types
using Element = mpz_class
using Characteristic = Element
Public Member Functions
 Multi_field_operators ()
 Default constructor, sets the product of all characteristics to 0.
 Multi_field_operators (int minCharacteristic, int maxCharacteristic)
 Constructor setting the characteristics to all prime numbers between the two given integers. More...
 Multi_field_operators (const Multi_field_operators &toCopy)
 Copy constructor. More...
 Multi_field_operators (Multi_field_operators &&toMove) noexcept
 Move constructor. More...
void set_characteristic (int minimum, int maximum)
 Set the characteristics of the field, which are stored in a single value as a product of all of them. The characteristics will be all prime numbers in the given interval. More...
const Characteristic & get_characteristic () const
 Returns the current characteristics as the product of all of them. More...
Element get_value (Element e) const
 Returns the value of an element in the field. That is the positive value of the integer modulo the current characteristic. More...
void get_value_inplace (Element &e) const
 Stores in the given element the value of this element in the field. That is the positive value of the integer modulo the current characteristic. More...
Element add (Element e1, const Element &e2) const
 Returns the sum of two elements in the field. More...
void add_inplace (Element &e1, const Element &e2) const
 Stores in the first element the sum of two given elements in the field, that is (e1 + e2) % productOfAllCharacteristics, such that the result is positive. More...
Element subtract (Element e1, const Element &e2) const
 Returns the subtraction in the field of the first element by the second element. More...
void subtract_inplace_front (Element &e1, const Element &e2) const
 Stores in the first element the subtraction in the field of the first element by the second element, that is (e1 - e2) % productOfAllCharacteristics, such that the result is positive. More...
void subtract_inplace_back (const Element &e1, Element &e2) const
 Stores in the second element the subtraction in the field of the first element by the second element, that is (e1 - e2) % productOfAllCharacteristics, such that the result is positive. More...
Element multiply (Element e1, const Element &e2) const
 Returns the multiplication of two elements in the field. More...
void multiply_inplace (Element &e1, const Element &e2) const
 Stores in the first element the multiplication of two given elements in the field, that is (e1 * e2) % productOfAllCharacteristics, such that the result is positive. More...
Element multiply_and_add (Element e, const Element &m, const Element &a) const
 Multiplies the first element with the second one and adds the third one. Returns the result in the field. More...
void multiply_and_add_inplace_front (Element &e, const Element &m, const Element &a) const
 Multiplies the first element with the second one and adds the third one, that is (e * m + a) % productOfAllCharacteristics, such that the result is positive. Stores the result in the first element. More...
void multiply_and_add_inplace_back (const Element &e, const Element &m, Element &a) const
 Multiplies the first element with the second one and adds the third one, that is (e * m + a) % productOfAllCharacteristics, such that the result is positive. Stores the result in the third element. More...
Element add_and_multiply (Element e, const Element &a, const Element &m) const
 Adds the first element to the second one and multiplies the third one with it. Returns the result in the field. More...
void add_and_multiply_inplace_front (Element &e, const Element &a, const Element &m) const
 Adds the first element to the second one and multiplies the third one with it, that is ((e + a) * m) % productOfAllCharacteristics, such that the result is positive. Stores the result in the first element. More...
void add_and_multiply_inplace_back (const Element &e, const Element &a, Element &m) const
 Adds the first element to the second one and multiplies the third one with it, that is ((e + a) * m) % productOfAllCharacteristics, such that the result is positive. Stores the result in the third element. More...
bool are_equal (const Element &e1, const Element &e2) const
 Returns true if the two given elements are equal in the field, false otherwise. More...
Element get_inverse (const Element &e) const
 Returns the inverse of the given element in the sense of [6] with respect to the product of all characteristics. More...
std::pair< Element, Characteristic > get_partial_inverse (const Element &e, const Characteristic &productOfCharacteristics) const
 Returns the inverse of the given element in the multi-field corresponding to the given sub-product of the product of all characteristics in the multi-field. See [6] for more details. More...
Element get_partial_multiplicative_identity (const Characteristic &productOfCharacteristics) const
 Returns the partial multiplicative identity of the multi-field from the given product. See [6] for more details. More...
Multi_field_operators & operator= (Multi_field_operators other)
 Assign operator.
Static Public Member Functions
static const Element & get_additive_identity ()
 Returns the additive identity of a field. More...
static const Element & get_multiplicative_identity ()
 Returns the multiplicative identity of a field. More...
Friends
void swap (Multi_field_operators &f1, Multi_field_operators &f2)
 Swap operator.
Detailed Description
Member Typedef Documentation
◆ Characteristic
◆ Element
Type for the elements in the field.
Constructor & Destructor Documentation
◆ Multi_field_operators() [1/3]
Gudhi::persistence_fields::Multi_field_operators::Multi_field_operators ( int  minCharacteristic,
inline
Parameters
minCharacteristicSmallest value of a prime.
maxCharacteristicHighest value of a prime.
◆ Multi_field_operators() [2/3]
Gudhi::persistence_fields::Multi_field_operators::Multi_field_operators ( const Multi_field_operators &  toCopy)
inline
Copy constructor.
Parameters
toCopyOperators to copy.
◆ Multi_field_operators() [3/3]
Gudhi::persistence_fields::Multi_field_operators::Multi_field_operators ( Multi_field_operators &&  toMove)
inlinenoexcept
Move constructor.
Parameters
toMoveOperators to move.
Member Function Documentation
◆ add()
Element Gudhi::persistence_fields::Multi_field_operators::add ( Element  e1,
const Element &  e2
) const
inline
Parameters
e1First element.
e2Second element.
Returns
◆ add_and_multiply()
Element Gudhi::persistence_fields::Multi_field_operators::add_and_multiply ( Element  e,
const Element &  a,
const Element &  m
) const
inline
Parameters
eFirst element.
aSecond element.
mThird element.
Returns
◆ add_and_multiply_inplace_back()
void Gudhi::persistence_fields::Multi_field_operators::add_and_multiply_inplace_back ( const Element &  e,
const Element &  a,
Element &  m
) const
inline
Parameters
eFirst element.
aSecond element.
mThird element.
◆ add_and_multiply_inplace_front()
void Gudhi::persistence_fields::Multi_field_operators::add_and_multiply_inplace_front ( Element &  e,
const Element &  a,
const Element &  m
) const
inline
Parameters
eFirst element.
aSecond element.
mThird element.
◆ add_inplace()
void Gudhi::persistence_fields::Multi_field_operators::add_inplace ( Element &  e1,
const Element &  e2
) const
inline
Parameters
e1First element.
e2Second element.
◆ are_equal()
bool Gudhi::persistence_fields::Multi_field_operators::are_equal ( const Element &  e1,
const Element &  e2
) const
inline
Parameters
e1First element to compare.
e2Second element to compare.
Returns
true If e1 % productOfAllCharacteristics == e2 % productOfAllCharacteristics.
false Otherwise.
◆ get_additive_identity()
static const Element & Gudhi::persistence_fields::Multi_field_operators::get_additive_identity ( )
inlinestatic
Returns
The additive identity of a field.
◆ get_characteristic()
const Characteristic & Gudhi::persistence_fields::Multi_field_operators::get_characteristic ( ) const
inline
Returns
The value of the current characteristic.
◆ get_inverse()
Element Gudhi::persistence_fields::Multi_field_operators::get_inverse ( const Element &  e) const
inline
Parameters
eElement to get the inverse from.
Returns
Inverse in the current field.
◆ get_multiplicative_identity()
static const Element & Gudhi::persistence_fields::Multi_field_operators::get_multiplicative_identity ( )
inlinestatic
Returns
The multiplicative identity of a field.
◆ get_partial_inverse()
std::pair< Element, Characteristic > Gudhi::persistence_fields::Multi_field_operators::get_partial_inverse ( const Element &  e,
const Characteristic &  productOfCharacteristics
) const
inline
Parameters
productOfCharacteristicsProduct of the different characteristics to take into account in the multi-field.
Returns
Pair of the inverse of e and the characteristic the inverse is coming from.
◆ get_partial_multiplicative_identity()
Element Gudhi::persistence_fields::Multi_field_operators::get_partial_multiplicative_identity ( const Characteristic &  productOfCharacteristics) const
inline
Parameters
Returns
The partial multiplicative identity of the multi-field.
◆ get_value()
Element Gudhi::persistence_fields::Multi_field_operators::get_value ( Element  e) const
inline
Parameters
eElement to return the value from.
Returns
e modulo the current characteristic, such that the result is positive.
◆ get_value_inplace()
void Gudhi::persistence_fields::Multi_field_operators::get_value_inplace ( Element &  e) const
inline
Parameters
◆ multiply()
Element Gudhi::persistence_fields::Multi_field_operators::multiply ( Element  e1,
const Element &  e2
) const
inline
Parameters
e1First element.
e2Second element.
Returns
◆ multiply_and_add()
Element Gudhi::persistence_fields::Multi_field_operators::multiply_and_add ( Element  e,
const Element &  m,
const Element &  a
) const
inline
Parameters
eFirst element.
mSecond element.
aThird element.
Returns
◆ multiply_and_add_inplace_back()
void Gudhi::persistence_fields::Multi_field_operators::multiply_and_add_inplace_back ( const Element &  e,
const Element &  m,
Element &  a
) const
inline
Parameters
eFirst element.
mSecond element.
aThird element.
◆ multiply_and_add_inplace_front()
void Gudhi::persistence_fields::Multi_field_operators::multiply_and_add_inplace_front ( Element &  e,
const Element &  m,
const Element &  a
) const
inline
Parameters
eFirst element.
mSecond element.
aThird element.
◆ multiply_inplace()
void Gudhi::persistence_fields::Multi_field_operators::multiply_inplace ( Element &  e1,
const Element &  e2
) const
inline
Parameters
e1First element.
e2Second element.
◆ set_characteristic()
void Gudhi::persistence_fields::Multi_field_operators::set_characteristic ( int  minimum,
int  maximum
inline
Parameters
minimumSmallest value of a prime.
maximumHighest value of a prime.
◆ subtract()
Element Gudhi::persistence_fields::Multi_field_operators::subtract ( Element  e1,
const Element &  e2
) const
inline
Parameters
e1First element.
e2Second element.
Returns
◆ subtract_inplace_back()
void Gudhi::persistence_fields::Multi_field_operators::subtract_inplace_back ( const Element &  e1,
Element &  e2
) const
inline
Parameters
e1First element.
e2Second element.
◆ subtract_inplace_front()
void Gudhi::persistence_fields::Multi_field_operators::subtract_inplace_front ( Element &  e1,
const Element &  e2
) const
inline
Parameters
e1First element.
e2Second element.
The documentation for this class was generated from the following file:
