Gudhi::persistence_fields::Shared_Zp_field_element< Unsigned_integer_type, class > Class Template Reference
Class representing an element of the \( \mathbb{F}_p \) field for any prime number \( p \). If each instantiation of the class can represent another element, they all share the same characteristics. That is if the characteristics are set for one, they will be set for all the others. The characteristics can be set before instantiating the elements with the static Shared_Zp_field_element::initialize method. More...
#include <gudhi/Fields/Zp_field_shared.h>
Public Types
using Element = Unsigned_integer_type
using Characteristic = Element
Public Member Functions
 Shared_Zp_field_element ()
 Default constructor. Sets the element to 0.
template<typename Integer_type , class = isInteger<Integer_type>>
 Shared_Zp_field_element (Integer_type element)
 Constructor setting the element to the given value. More...
 Shared_Zp_field_element (const Shared_Zp_field_element &toCopy)
 Copy constructor. More...
 Shared_Zp_field_element (Shared_Zp_field_element &&toMove) noexcept
 Move constructor. More...
Element get_value () const
 Returns the value of the element. More...
Shared_Zp_field_element & operator= (Shared_Zp_field_element other)
 Assign operator.
Shared_Zp_field_element & operator= (const Integer_type &value)
 Assign operator. More...
 operator unsigned int () const
 Casts the element into an unsigned int.
Shared_Zp_field_element get_inverse () const
 Returns the inverse of the element in the field. More...
std::pair< Shared_Zp_field_element, Characteristic > get_partial_inverse (Characteristic productOfCharacteristics) const
 For interface purposes with multi-fields. Returns the inverse together with the argument. More...
Static Public Member Functions
static void initialize (Characteristic characteristic)
 Initialize the field to the given characteristic. Should be called first before constructing the field elements. More...
static Shared_Zp_field_element get_additive_identity ()
 Returns the additive identity of the field. More...
static Shared_Zp_field_element get_multiplicative_identity ()
 Returns the multiplicative identity of the field. More...
static Shared_Zp_field_element get_partial_multiplicative_identity (Characteristic productOfCharacteristics)
 For interface purposes with multi-fields. Returns the multiplicative identity of the field. More...
static Characteristic get_characteristic ()
 Returns the current characteristic. More...
Friends
void operator+= (Shared_Zp_field_element &f1, const Shared_Zp_field_element &f2)
 operator+=
Shared_Zp_field_element operator+ (Shared_Zp_field_element f1, const Shared_Zp_field_element &f2)
 operator+
void operator+= (Shared_Zp_field_element &f, const Integer_type &v)
 operator+= More...
Shared_Zp_field_element operator+ (Shared_Zp_field_element f, const Integer_type &v)
 operator+ More...
Integer_type operator+ (const Integer_type &v, Shared_Zp_field_element f)
 operator+ More...
void operator-= (Shared_Zp_field_element &f1, const Shared_Zp_field_element &f2)
 operator-=
Shared_Zp_field_element operator- (Shared_Zp_field_element f1, const Shared_Zp_field_element &f2)
 operator-
void operator-= (Shared_Zp_field_element &f, const Integer_type &v)
 operator-= More...
Shared_Zp_field_element operator- (Shared_Zp_field_element f, const Integer_type &v)
 operator- More...
Integer_type operator- (const Integer_type &v, const Shared_Zp_field_element &f)
 operator- More...
void operator*= (Shared_Zp_field_element &f1, const Shared_Zp_field_element &f2)
 operator*=
Shared_Zp_field_element operator* (Shared_Zp_field_element f1, const Shared_Zp_field_element &f2)
 operator*
void operator*= (Shared_Zp_field_element &f, const Integer_type &v)
 operator*= More...
Shared_Zp_field_element operator* (Shared_Zp_field_element f, const Integer_type &v)
 operator* More...
Integer_type operator* (const Integer_type &v, Shared_Zp_field_element f)
 operator* More...
bool operator== (const Shared_Zp_field_element &f1, const Shared_Zp_field_element &f2)
 operator==
bool operator== (const Integer_type &v, const Shared_Zp_field_element &f)
 operator== More...
bool operator== (const Shared_Zp_field_element &f, const Integer_type &v)
 operator== More...
bool operator!= (const Shared_Zp_field_element &f1, const Shared_Zp_field_element &f2)
 operator!=
bool operator!= (const Integer_type &v, const Shared_Zp_field_element &f)
 operator!= More...
bool operator!= (const Shared_Zp_field_element &f, const Integer_type &v)
 operator!= More...
void swap (Shared_Zp_field_element &f1, Shared_Zp_field_element &f2)
 Swap operator.
Detailed Description
template<typename Unsigned_integer_type = unsigned int, class = std::enable_if_t<std::is_unsigned_v<Unsigned_integer_type> >>
class Gudhi::persistence_fields::Shared_Zp_field_element< Unsigned_integer_type, class >
Template Parameters
Unsigned_integer_typeA native unsigned integer type: unsigned int, long unsigned int, etc. Will be used as the field element type.
Examples
example_field_operations.cpp.
Member Typedef Documentation
◆ Characteristic
using Gudhi::persistence_fields::Shared_Zp_field_element< Unsigned_integer_type, class >::Characteristic = Element
Type for the field characteristic.
◆ Element
using Gudhi::persistence_fields::Shared_Zp_field_element< Unsigned_integer_type, class >::Element = Unsigned_integer_type
Type for the elements in the field.
Constructor & Destructor Documentation
◆ Shared_Zp_field_element() [1/3]
Gudhi::persistence_fields::Shared_Zp_field_element< Unsigned_integer_type, class >::Shared_Zp_field_element ( Integer_type  element)
inline
Template Parameters
Integer_typeA native integer type. Should be able to contain the characteristic if signed.
Parameters
elementValue of the element.
◆ Shared_Zp_field_element() [2/3]
Gudhi::persistence_fields::Shared_Zp_field_element< Unsigned_integer_type, class >::Shared_Zp_field_element ( const Shared_Zp_field_element< Unsigned_integer_type, class > &  toCopy)
inline
Copy constructor.
Parameters
toCopyElement to copy.
◆ Shared_Zp_field_element() [3/3]
Gudhi::persistence_fields::Shared_Zp_field_element< Unsigned_integer_type, class >::Shared_Zp_field_element ( Shared_Zp_field_element< Unsigned_integer_type, class > &&  toMove)
inlinenoexcept
Move constructor.
Parameters
toMoveElement to move.
Member Function Documentation
◆ get_additive_identity()
static Shared_Zp_field_element Gudhi::persistence_fields::Shared_Zp_field_element< Unsigned_integer_type, class >::get_additive_identity ( )
inlinestatic
Returns
0.
◆ get_characteristic()
static Characteristic Gudhi::persistence_fields::Shared_Zp_field_element< Unsigned_integer_type, class >::get_characteristic ( )
inlinestatic
Returns
The value of the current characteristic.
◆ get_inverse()
Shared_Zp_field_element Gudhi::persistence_fields::Shared_Zp_field_element< Unsigned_integer_type, class >::get_inverse ( ) const
inline
Returns
The inverse.
◆ get_multiplicative_identity()
static Shared_Zp_field_element Gudhi::persistence_fields::Shared_Zp_field_element< Unsigned_integer_type, class >::get_multiplicative_identity ( )
inlinestatic
Returns
1.
◆ get_partial_inverse()
std::pair< Shared_Zp_field_element, Characteristic > Gudhi::persistence_fields::Shared_Zp_field_element< Unsigned_integer_type, class >::get_partial_inverse ( Characteristic  productOfCharacteristics) const
inline
Parameters
productOfCharacteristicsSome value.
Returns
Pair whose first element is the inverse and the second element is productOfCharacteristics.
◆ get_partial_multiplicative_identity()
static Shared_Zp_field_element Gudhi::persistence_fields::Shared_Zp_field_element< Unsigned_integer_type, class >::get_partial_multiplicative_identity ( Characteristic  productOfCharacteristics)
inlinestatic
Parameters
Returns
1.
◆ get_value()
Element Gudhi::persistence_fields::Shared_Zp_field_element< Unsigned_integer_type, class >::get_value ( ) const
inline
Returns
◆ initialize()
static void Gudhi::persistence_fields::Shared_Zp_field_element< Unsigned_integer_type, class >::initialize ( Characteristic  characteristic)
inlinestatic
Parameters
characteristicCharacteristic of the field. A positive prime number.
◆ operator=()
Shared_Zp_field_element & Gudhi::persistence_fields::Shared_Zp_field_element< Unsigned_integer_type, class >::operator= ( const Integer_type &  value)
inline
Assign operator.
Template Parameters
Friends And Related Function Documentation
◆ operator!= [1/2]
bool operator!= ( const Integer_type &  v,
const Shared_Zp_field_element< Unsigned_integer_type, class > &  f
friend
operator!=
Template Parameters
◆ operator!= [2/2]
bool operator!= ( const Shared_Zp_field_element< Unsigned_integer_type, class > &  f,
friend
operator!=
Template Parameters
◆ operator* [1/2]
Integer_type operator* ( const Integer_type &  v,
Shared_Zp_field_element< Unsigned_integer_type, class >  f
friend
operator*
Template Parameters
Integer_typeA native integer type. Should be able to contain the characteristic. if signed.
◆ operator* [2/2]
Shared_Zp_field_element operator* ( Shared_Zp_field_element< Unsigned_integer_type, class >  f,
friend
operator*
Template Parameters
◆ operator*=
void operator*= ( Shared_Zp_field_element< Unsigned_integer_type, class > &  f,
friend
operator*=
Template Parameters
◆ operator+ [1/2]
Integer_type operator+ ( const Integer_type &  v,
friend
operator+
Template Parameters
◆ operator+ [2/2]
Shared_Zp_field_element operator+ ( Shared_Zp_field_element< Unsigned_integer_type, class >  f,
friend
operator+
Template Parameters
◆ operator+=
void operator+= ( Shared_Zp_field_element< Unsigned_integer_type, class > &  f,
friend
operator+=
Template Parameters
◆ operator- [1/2]
Integer_type operator- ( const Integer_type &  v,
friend
operator-
Template Parameters
◆ operator- [2/2]
Shared_Zp_field_element operator- ( Shared_Zp_field_element< Unsigned_integer_type, class >  f,
friend
operator-
Template Parameters
◆ operator-=
void operator-= ( Shared_Zp_field_element< Unsigned_integer_type, class > &  f,
friend
operator-=
Template Parameters
◆ operator== [1/2]
bool operator== ( const Integer_type &  v,
friend
operator==
Template Parameters
◆ operator== [2/2]
bool operator== ( const Shared_Zp_field_element< Unsigned_integer_type, class > &  f,
friend
operator==
Template Parameters
The documentation for this class was generated from the following file:
