example_field_operations.cpp
/* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
* See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
* Author(s): Hannah Schreiber
* Copyright (C) 2024 Inria
* Modification(s):
* - YYYY/MM Author: Description of the modification
#include <iostream>
template<class Field_element>
void field_element_example(int ini){
Field_element e = ini;
std::cout << "Element e initialized with " << ini << "\n";
std::cout << "Characteristic: " << e.get_characteristic() << "\n";
std::cout << "e: " << e << "\n";
std::cout << "e + 3: " << (e + 3) << "\n";
std::cout << "3 + e: " << (3 + e) << "\n";
e += 3;
std::cout << "e += 3: " << e << "\n";
int t = 3;
t += e; //standard integer addition
std::cout << "3 += e: " << t << " //standard integer addition\n";
std::cout << "e - 4: " << (e - 4) << "\n";
std::cout << "4 - e: " << (4 - e) << "\n";
e -= 4;
std::cout << "e -= 4: " << e << "\n";
t = 4;
t -= e; //standard integer addition
std::cout << "4 -= e: " << t << " //standard integer subtraction\n";
std::cout << "e * 6: " << (e * 6) << "\n";
std::cout << "6 * e: " << (6 * e) << "\n";
e *= 6;
std::cout << "e *= 6: " << e << "\n";
t = 6;
t *= e; //standard integer addition
std::cout << "6 *= e: " << t << " //standard integer multiplication\n";
std::cout << "Inverse: " << e.get_inverse() << "\n";
template<class Field_operator>
void field_operator_example(const Field_operator& op){
std::cout << "Characteristic: " << op.get_characteristic() << "\n";
std::cout << "2 + 3: " << op.add(2u, 3u) << "\n";
std::cout << "3 + 2: " << op.add(3u, 2u) << "\n";
std::cout << "10 - 4: " << op.subtract(10u, 4u) << "\n";
std::cout << "4 - 10: " << op.subtract(4u, 10u) << "\n";
std::cout << "3 * 6: " << op.multiply(3u, 6u) << "\n";
std::cout << "6 * 3: " << op.multiply(6u, 3u) << "\n";
std::cout << "Value of 7: " << op.get_value(7u) << "\n";
std::cout << "Inverse of 7: " << op.get_inverse(7u) << "\n";
int main() {
std::cout << "=== Example for Z2 field elements ===\n\n";
field_element_example<Z2_field_element>(2);
std::cout << "\n=== Example for Z3 field elements ===\n\n";
field_element_example<Zp_field_element<3> >(5);
std::cout << "\n=== Example for Z5 field elements ===\n\n";
Shared_Zp_field_element<>::initialize(5);
field_element_example<Shared_Zp_field_element<> >(4);
std::cout << "\n+++ Example for Z2 field operator +++\n\n";
Z2_field_operators z2op;
field_operator_example(z2op);
std::cout << "\n+++ Example for Z3 field operator +++\n\n";
Zp_field_operators zpop;
zpop.set_characteristic(3);
field_operator_example(zpop);
std::cout << "\n+++ Example for Z5 field operator +++\n\n";
zpop.set_characteristic(5);
Contains the Gudhi::persistence_fields::Z2_field_element class.
Contains the Gudhi::persistence_fields::Z2_field_operators class.
Contains the Gudhi::persistence_fields::Zp_field_element class.
Contains the Gudhi::persistence_fields::Zp_field_operators class.
Contains the Gudhi::persistence_fields::Shared_Zp_field_element class.
Class representing an element of the field for any prime number . If each instantiation of the class...
Definition: Zp_field_shared.h:42
Class representing an element of the field.
Definition: Z2_field.h:32
Class defining operators for the field.
Definition: Z2_field_operators.h:32
Definition: Zp_field.h:39
Class defining operators for the field for any prime number .
Definition: Zp_field_operators.h:41
