The concept SimplexInCoxeterTriangulation describes the requirements for a type to implement a representation of simplices in Freudenthal_triangulation or in Coxeter_triangulation. More...
#include <concept/Coxeter_triangulation/SimplexInCoxeterTriangulation.h>
Public Types | |
| typedef Vertex_ | Vertex |
| Type of the vertex. | |
| typedef Ordered_set_partition_ | OrderedSetPartition |
| Type of the ordered partition. | |
Public Member Functions | |
| unsigned | dimension () const |
| Dimension of the simplex. | |
| Vertex_range | vertex_range () const |
| Returns a range of vertices of the simplex. | |
| Face_range | face_range (std::size_t k) const |
| Returns a range of permutahedral representations of k-dimensional faces of the simplex for some given integer parameter 'k'. | |
| Face_range | facet_range () const |
| Returns a range of permutahedral representations of facets of the simplex. The dimension of the simplex must be strictly positive. | |
| Coface_range | coface_range (std::size_t k) const |
| Returns a range of permutahedral representations of k-dimensional cofaces of the simplex for some given integer parameter 'k'. | |
| Coface_range | cofacet_range () const |
| Returns a range of permutahedral representations of cofacets of the simplex. The dimension of the simplex must be strictly different from the ambient dimension. | |
| bool | is_face_of (const Permutahedral_representation &other) const |
| Returns true, if the simplex is a face of other simplex. | |
Public Attributes | |
| typedef | Vertex_range |
| Type of a range of vertices, each of type Vertex. | |
| typedef | Face_range |
| Type of a range of faces, each of type that is a model of the concept SimplexInCoxeterTriangulation. | |
| typedef | Coface_range |
| Type of a range of cofaces, each of type that is a model of the concept SimplexInCoxeterTriangulation. | |
