A class that stores Coxeter triangulation of type \(\tilde{A}_d\). This triangulation has the greatest simplex quality out of all linear transformations of the Freudenthal-Kuhn triangulation.
More...
#include <include/gudhi/Coxeter_triangulation.h>
| | Coxeter_triangulation (std::size_t dimension) |
| | Constructor of Coxeter triangulation of a given dimension. More...
| | Freudenthal_triangulation (std::size_t dimension) |
| | Constructor of the Freudenthal-Kuhn triangulation of a given dimension. More...
| | Freudenthal_triangulation (std::size_t dimension, const Matrix &matrix) |
| | Constructor of the Freudenthal-Kuhn triangulation of a given dimension under a linear transformation by a given matrix. More...
| | Freudenthal_triangulation (unsigned dimension, const Matrix &matrix, const Vector &offset) |
| | Constructor of the Freudenthal-Kuhn triangulation of a given dimension under an affine transformation by a given matrix and a translation vector. More...
unsigned | dimension () const |
| | Dimension of the triangulation.
const Matrix & | matrix () const |
| | Matrix that defines the linear transformation of the triangulation.
const Vector & | offset () const |
| | Vector that defines the offset of the triangulation.
| void | change_matrix (const Eigen::MatrixXd &matrix) |
| | Change the linear transformation matrix to a given value. More...
| void | change_offset (const Eigen::VectorXd &offset) |
| | Change the offset vector to a given value. More...
| template<class Point_d > |
| Simplex_handle | locate_point (const Point_d &point, double scale=1) const |
| | Returns the permutahedral representation of the simplex in the triangulation that contains a given query point. More...
| Eigen::VectorXd | cartesian_coordinates (const Vertex_handle &vertex, double scale=1) const |
| | Returns the Cartesian coordinates of the given vertex. More...
| Eigen::VectorXd | barycenter (const Simplex_handle &simplex, double scale=1) const |
| | Returns the Cartesian coordinates of the barycenter of a given simplex. More...
using | Simplex_handle = Permutahedral_representation_ |
| | Type of the simplices in the triangulation.
using | Vertex_handle = typename Permutahedral_representation_::Vertex |
| | Type of the vertices in the triangulation.
template<class Permutahedral_representation_ = Permutahedral_representation<std::vector<int>, std::vector<std::vector<std::size_t> > >>
class Gudhi::coxeter_triangulation::Coxeter_triangulation< Permutahedral_representation_ >
- Template Parameters
- Examples
- cell_complex_from_basic_circle_manifold.cpp, manifold_tracing_custom_function.cpp, and manifold_tracing_flat_torus_with_boundary.cpp.
◆ Coxeter_triangulation()
- Parameters
| [in] | dimension | The dimension of the triangulation. |
The documentation for this class was generated from the following file:
