#include <iostream>
#include <gudhi/Coxeter_triangulation.h>
#include <gudhi/Functions/Function_Sm_in_Rd.h>
#include <gudhi/Implicit_manifold_intersection_oracle.h>
#include <gudhi/Manifold_tracing.h>
#include <gudhi/Coxeter_triangulation/Cell_complex/Cell_complex.h>
#include <gudhi/Functions/Linear_transformation.h>
#include <gudhi/IO/build_mesh_from_cell_complex.h>
#include <gudhi/IO/output_meshes_to_medit.h>
using namespace Gudhi::coxeter_triangulation;
struct Function_surface_on_CP2_in_R4 {
  Eigen::VectorXd operator()(const Eigen::VectorXd& p) const {
    double xr = p(0), xi = p(1), yr = p(2), yi = p(3);
    Eigen::VectorXd result(cod_d());
    double xr2 = xr * xr, xi2 = xi * xi, yr2 = yr * yr, yi2 = yi * yi, xr3 = xr2 * xr, xi3 = xi2 * xi, yr3 = yr2 * yr,
           yi3 = yi2 * yi;
    result(0) = xr3 * yr - 3 * xr * xi2 * yr - 3 * xr2 * xi * yi + xi3 * yi + yr3 - 3 * yr * yi2 + xr;
    result(1) = 3 * xr2 * xi * yr + xr3 * yi - 3 * xr * xi2 * yi - xi3 * yr + 3 * yr2 * yi - yi3 + xi;
    return result;
  std::size_t amb_d() const { return 4; };
  std::size_t cod_d() const { return 2; };
  Eigen::VectorXd seed() const {
    Eigen::VectorXd result = Eigen::VectorXd::Zero(4);
    return result;
  Function_surface_on_CP2_in_R4() {}
int main(int argc, char** argv) {
  Function_surface_on_CP2_in_R4 fun;
  Eigen::VectorXd seed = fun.seed();
  double radius = 3.0;
  auto oracle = make_oracle(fun, fun_sph);
  double lambda = 0.2;
  cox_tr.change_offset(Eigen::VectorXd::Random(oracle.amb_d()));
  cox_tr.change_matrix(lambda * cox_tr.matrix());
  using Out_simplex_map = typename MT::Out_simplex_map;
  std::vector<Eigen::VectorXd> seed_points(1, seed);
  Out_simplex_map interior_simplex_map, boundary_simplex_map;
  manifold_tracing_algorithm(seed_points, cox_tr, oracle, interior_simplex_map, boundary_simplex_map);
  std::size_t intr_d = oracle.amb_d() - oracle.cod_d();
  cell_complex.construct_complex(interior_simplex_map, boundary_simplex_map);
  output_meshes_to_medit(3, "manifold_on_CP2_with_boundary",
                         build_mesh_from_cell_complex(cell_complex, Configuration(true, true, true, 1, 5, 3),
                                                      Configuration(true, true, true, 2, 13, 14)));
  return 0;
A class that constructs the cell complex from the output provided by the class Gudhi::coxeter_triangu...
Definition: Cell_complex.h:38
A class that stores Coxeter triangulation of type . This triangulation has the greatest simplex quali...
Definition: Coxeter_triangulation.h:45
A class that assembles methods for manifold tracing algorithm.
Definition: Manifold_tracing.h:39
A class for the function that defines an m-dimensional implicit sphere embedded in the d-dimensional ...
Definition: Function_Sm_in_Rd.h:27
