A class that stores the permutahedral representation of a simplex in a Coxeter triangulation or a Freudenthal-Kuhn triangulation.
More...
| | Permutahedral_representation (const Vertex &vertex, const OrderedSetPartition &partition) |
| | Permutahedral_representation constructor from a vertex and an ordered set partition. More...
| Permutahedral_representation () |
| | Constructor for an empty permutahedral representation that does not correspond to any simplex.
std::size_t | dimension () const |
| | Dimension of the simplex.
Vertex & | vertex () |
| | Lexicographically-minimal vertex.
const Vertex & | vertex () const |
OrderedSetPartition & | partition () |
| | Ordered set partition.
const OrderedSetPartition & | partition () const |
| | Identifying vertex.
bool | operator== (const Permutahedral_representation &other) const |
| | Equality operator. Returns true if an only if both vertex and the ordered set partition coincide.
bool | operator!= (const Permutahedral_representation &other) const |
| | Inequality operator. Returns true if an only if either vertex or the ordered set partition are different.
Vertex_range | vertex_range () const |
| | Returns a range of vertices of the simplex. The type of vertices is Vertex.
| Face_range | face_range (std::size_t value_dim) const |
| | Returns a range of permutahedral representations of faces of the simplex. More...
Face_range | facet_range () const |
| | Returns a range of permutahedral representations of facets of the simplex. The dimension of the simplex must be strictly positive.
| Coface_range | coface_range (std::size_t value_dim) const |
| | Returns a range of permutahedral representations of cofaces of the simplex. More...
Coface_range | cofacet_range () const |
| | Returns a range of permutahedral representations of cofacets of the simplex. The dimension of the simplex must be strictly different from the ambient dimension (the size of the vertex).
| bool | is_face_of (const Permutahedral_representation &other) const |
| | Returns true, if the simplex is a face of other simplex. More...
template<class Vertex_, class Ordered_set_partition_>
class Gudhi::coxeter_triangulation::Permutahedral_representation< Vertex_, Ordered_set_partition_ >
The data structure is a record consisting of a range that represents the vertex and a range that represents the ordered set partition, both of which identify the simplex in the triangulation.
- Template Parameters
| Vertex_ | needs to be a random-access range. |
| Ordered_set_partition_ | needs to be a a random-access range that consists of random-access ranges. |
