Class managing the column and row swaps in Base_matrix and Boundary_matrix.
More...
#include <gudhi/Persistence_matrix/base_swap.h>
| using | Column_container = typename Master_matrix::Column_container |
| using | Index = typename Master_matrix::Index |
| using | ID_index = typename Master_matrix::ID_index |
| Base_swap () |
| | Default constructor.
| | Base_swap (unsigned int numberOfColumns) |
| | As default constructor, but reserves spaces for numberOfColumns columns. More...
| | Base_swap (const Base_swap &matrixToCopy)=default |
| | Copy constructor. More...
| | Base_swap (Base_swap &&other) noexcept |
| | Move constructor. More...
| void | swap_columns (Index columnIndex1, Index columnIndex2) |
| | Swaps the two columns at given indices in the column container. Does not updates the column index value, potentially stored in the entries. This will be done when calling _orderRows(). More...
| void | swap_rows (ID_index rowIndex1, ID_index rowIndex2) |
| | Swaps the two rows at the given indices, but in a lazy manner. That is, the swap is registered but not executed. The reordering will be done when calling _orderRows(). More...
Base_swap & | operator= (Base_swap other) |
| | Assign operator.
template<class Master_matrix, class
Base_matrix>
class Gudhi::persistence_matrix::Base_swap< Master_matrix, Base_matrix >
- Template Parameters
◆ Column_container
◆ ID_index
◆ Index
◆ Base_swap() [1/3]
- Parameters
| numberOfColumns | Number of columns to reserve space for. |
◆ Base_swap() [2/3]
Copy constructor.
- Parameters
◆ Base_swap() [3/3]
Move constructor.
- Parameters
◆ swap_columns()
- Parameters
| columnIndex1 | First MatIdx column index. |
| columnIndex2 | Second MatIdx column index. |
◆ swap_rows()
- Parameters
| rowIndex1 | First row index. |
| rowIndex2 | Second row index. |
The documentation for this class was generated from the following file:
