A basic matrix structure allowing to easily manipulate and access entire columns and rows, but not individual entries. More...
#include <gudhi/Persistence_matrix/Base_matrix.h>
Public Types | |
| using | Index = typename Master_matrix::Index |
| using | Dimension = typename Master_matrix::Dimension |
| using | Field_operators = typename Master_matrix::Field_operators |
| Field operators class. Necessary only if PersistenceMatrixOptions::is_z2 is false. | |
| using | Field_element = typename Master_matrix::Element |
| using | Column = typename Master_matrix::Column |
| using | Boundary = typename Master_matrix::Boundary |
| using | Row = typename Master_matrix::Row |
| using | Entry_constructor = typename Master_matrix::Entry_constructor |
| using | Column_settings = typename Master_matrix::Column_settings |
Public Member Functions | |
| Base_matrix (Column_settings *colSettings) | |
| Constructs an empty matrix. More... | |
| template<class Container = Boundary> | |
| Base_matrix (const std::vector< Container > &columns, Column_settings *colSettings) | |
| Constructs a matrix from the given ordered columns. The columns are inserted in the given order. More... | |
| Base_matrix (unsigned int numberOfColumns, Column_settings *colSettings) | |
| Constructs a new empty matrix and reserves space for the given number of columns. More... | |
| Base_matrix (const Base_matrix &matrixToCopy, Column_settings *colSettings=nullptr) | |
Copy constructor. If colSettings is not a null pointer, its value is kept instead of the one in the copied matrix. More... | |
| Base_matrix (Base_matrix &&other) noexcept | |
| Move constructor. More... | |
| void | insert_column (const Container &column) |
| Inserts a new ordered column at the end of the matrix by copying the given range of Matrix::Entry_representative. The content of the range is assumed to be sorted by increasing ID value. More... | |
| void | insert_column (const Container &column, Index columnIndex) |
| Inserts a new ordered column at the given index by copying the given range of Matrix::Entry_representative. There should not be any other column inserted at that index which was not explicitly removed before. The content of the range is assumed to be sorted by increasing ID value. Not available when row access is enabled. More... | |
| template<class Boundary_range > | |
| void | insert_boundary (const Boundary_range &boundary, Dimension dim=Master_matrix::template get_null_value< Dimension >()) |
| Same as insert_column, only for interface purposes. The given dimension is ignored and not stored. More... | |
| Column & | get_column (Index columnIndex) |
| Returns the column at the given MatIdx index. The type of the column depends on the chosen options, see PersistenceMatrixOptions::column_type. More... | |
| Row & | get_row (Index rowIndex) |
| Only available if PersistenceMatrixOptions::has_row_access is true. Returns the row at the given row index of the matrix. The type of the row depends on the chosen options, see PersistenceMatrixOptions::has_intrusive_rows. More... | |
| void | remove_column (Index columnIndex) |
Only available if PersistenceMatrixOptions::has_map_column_container is true. Otherwise, see remove_last. Erases the given column from the matrix. If the given column index corresponded to the last used column index, the "new last column index" will be columnIndex - 1, even if a column was never explicitly inserted at this index (possible when insert_column(column, columnIndex) was used). If the column didn't existed, it will simply be considered as an empty column. More... | |
| void | remove_last () |
| Removes the last column from the matrix. The last column is at index \( max(ins1, ins2, rem - 1) \), where: More... | |
| void | erase_empty_row (Index rowIndex) |
| If PersistenceMatrixOptions::has_row_access and PersistenceMatrixOptions::has_removable_rows are true: assumes that the row is empty and removes it. If PersistenceMatrixOptions::has_map_column_container and PersistenceMatrixOptions::has_column_and_row_swaps are true: cleans up maps used for the lazy row swaps. Otherwise, does nothing. More... | |
| Index | get_number_of_columns () const |
| Returns the current number of columns in the matrix. More... | |
| template<class Entry_range_or_column_index > | |
| void | add_to (const Entry_range_or_column_index &sourceColumn, Index targetColumnIndex) |
Adds column represented by sourceColumn onto the column at targetColumnIndex in the matrix. More... | |
| void | multiply_target_and_add_to (const Entry_range_or_column_index &sourceColumn, const Field_element &coefficient, Index targetColumnIndex) |
Multiplies the target column with the coefficient and then adds the source column to it. That is: targetColumn = (targetColumn * coefficient) + sourceColumn. More... | |
| void | multiply_source_and_add_to (const Field_element &coefficient, const Entry_range_or_column_index &sourceColumn, Index targetColumnIndex) |
Multiplies the source column with the coefficient before adding it to the target column. That is: targetColumn += (coefficient * sourceColumn). The source column will not be modified. More... | |
| void | zero_entry (Index columnIndex, Index rowIndex) |
| Zeroes the entry at the given coordinates. More... | |
| void | zero_column (Index columnIndex) |
| Zeroes the column at the given index. More... | |
| bool | is_zero_entry (Index columnIndex, Index rowIndex) const |
| Indicates if the entry at given coordinates has value zero. More... | |
| bool | is_zero_column (Index columnIndex) |
| Indicates if the column at given index has value zero. More... | |
| void | reset (Column_settings *colSettings) |
| Resets the matrix to an empty matrix. More... | |
| Base_matrix & | operator= (const Base_matrix &other) |
| Assign operator. | |
Friends | |
| void | swap (Base_matrix &matrix1, Base_matrix &matrix2) |
| Swap operator. | |
| Master_matrix | An instantiation of Matrix from which all types and options are deduced. |
| using Gudhi::persistence_matrix::Base_matrix< Master_matrix >::Boundary = typename Master_matrix::Boundary |
Type of the column container.
| using Gudhi::persistence_matrix::Base_matrix< Master_matrix >::Column = typename Master_matrix::Column |
Column type.
| using Gudhi::persistence_matrix::Base_matrix< Master_matrix >::Column_settings = typename Master_matrix::Column_settings |
Structure giving access to the columns to necessary external classes.
| using Gudhi::persistence_matrix::Base_matrix< Master_matrix >::Dimension = typename Master_matrix::Dimension |
Dimension value type.
| using Gudhi::persistence_matrix::Base_matrix< Master_matrix >::Entry_constructor = typename Master_matrix::Entry_constructor |
Factory of Entry classes.
| using Gudhi::persistence_matrix::Base_matrix< Master_matrix >::Field_element = typename Master_matrix::Element |
Type of a field element.
| using Gudhi::persistence_matrix::Base_matrix< Master_matrix >::Index = typename Master_matrix::Index |
Container index type.
| using Gudhi::persistence_matrix::Base_matrix< Master_matrix >::Row = typename Master_matrix::Row |
Row type, only necessary with row access option.
inline |
| colSettings | Pointer to an existing setting structure for the columns. The structure should contain all the necessary external classes specifically necessary for the chosen column type, such as custom allocators. |
inline |
| Container | Range type for Matrix::Entry_representative ranges. Assumed to have a begin(), end() and size() method. |
| columns | A vector of Matrix::Entry_representative ranges to construct the columns from. The content of the ranges are assumed to be sorted by increasing ID value. |
inline |
| numberOfColumns | Number of columns to reserve space for. |
inline |
| matrixToCopy | Matrix to copy. |
| colSettings | Either a pointer to an existing setting structure for the columns or a null pointer. The structure should contain all the necessary external classes specifically necessary for the chosen column type, such as custom allocators. If null pointer, the pointer stored in matrixToCopy is used instead. |
inlinenoexcept |
Move constructor.
| other | Matrix to move. |
inline |
| Entry_range_or_column_index | Either a range of Entry with a begin() and end() method, or any integer type. |
inline |
| rowIndex | Row index of the empty row. |
inline |
Note that before returning the column, all column entries can eventually be reordered, if lazy swaps occurred. It is therefore recommended to avoid calling get_column between column or row swaps, otherwise the benefits of the the laziness is lost.
| columnIndex | MatIdx index of the column to return. |
inline |
inline |
Note that before returning the row, all column entries can eventually be reordered, if lazy swaps occurred. It is therefore recommended to avoid calling get_row between column or row swaps, otherwise the benefits of the the laziness is lost.
| rowIndex | Row index of the row to return. |
inline |
| Boundary_range | Range of Matrix::Entry_representative. Assumed to have a begin(), end() and size() method. |
| boundary | Range of Matrix::Entry_representative from which the column has to be constructed. Assumed to be ordered by increasing ID value. |
| dim | Ignored. |
inline |
| Container | Range of Matrix::Entry_representative. Assumed to have a begin(), end() and size() method. |
| column | Range of Matrix::Entry_representative from which the column has to be constructed. Assumed to be ordered by increasing ID value. |
inline |
| columnIndex | MatIdx index to which the column has to be inserted. |
inline |
| columnIndex | MatIdx index of the column. |
inline |
inline |
inline |
inline |
If PersistenceMatrixOptions::has_row_access is also true, the deleted column entries are also automatically removed from their respective rows.
| columnIndex | MatIdx index of the column to remove. |
inline |
If \( max(ins1, ins2, rem - 1) = rem - 1 \) but no column was explicitly inserted at that index (possible by the use of insert_column(column, columnIndex)), the column is assumed to be an empty column.
See also remove_column.
inline |
inline |
| columnIndex | MatIdx index of the column to zero. |
inline |
