| add_to(const Entry_range_or_column_index &sourceColumn, Index targetColumnIndex) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| Base_matrix(Column_settings *colSettings) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| Base_matrix(const std::vector< Container > &columns, Column_settings *colSettings) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| Base_matrix(unsigned int numberOfColumns, Column_settings *colSettings) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| Base_matrix(const Base_matrix &matrixToCopy, Column_settings *colSettings=nullptr) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| Base_matrix(Base_matrix &&other) noexcept | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| Boundary typedef | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | |
| Column typedef | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | |
| Column_settings typedef | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | |
| Dimension typedef | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | |
| Entry_constructor typedef | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | |
| erase_empty_row(Index rowIndex) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| Field_element typedef | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | |
| Field_operators typedef | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | |
| get_column(Index columnIndex) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| get_number_of_columns() const | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| get_row(Index rowIndex) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| Index typedef | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | |
| insert_boundary(const Boundary_range &boundary, Dimension dim=Master_matrix::template get_null_value< Dimension >()) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| insert_column(const Container &column) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| insert_column(const Container &column, Index columnIndex) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| is_zero_column(Index columnIndex) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| is_zero_entry(Index columnIndex, Index rowIndex) const | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| multiply_source_and_add_to(const Field_element &coefficient, const Entry_range_or_column_index &sourceColumn, Index targetColumnIndex) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| multiply_target_and_add_to(const Entry_range_or_column_index &sourceColumn, const Field_element &coefficient, Index targetColumnIndex) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| operator=(const Base_matrix &other) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| remove_column(Index columnIndex) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| remove_last() | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| reset(Column_settings *colSettings) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
| Row typedef | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | |
| swap | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | friend |
| zero_entry(Index columnIndex, Index rowIndex) | Gudhi::persistence_matrix::Base_matrix< Master_matrix > | inline |
