Matrix structure to store the ordered boundary matrix \( R \) of a filtered complex in order to compute its persistent homology. Provides an access to its columns and rows as well as the possibility to remove the last cells of the filtration while maintaining a valid barcode. More...
#include <gudhi/Persistence_matrix/Boundary_matrix.h>
Public Types | |
| using | Index = typename Master_matrix::Index |
| using | ID_index = typename Master_matrix::ID_index |
| using | Dimension = typename Master_matrix::Dimension |
| using | Field_operators = typename Master_matrix::Field_operators |
| Field operators class. Necessary only if PersistenceMatrixOptions::is_z2 is false. | |
| using | Field_element = typename Master_matrix::Element |
| using | Column = typename Master_matrix::Column |
| using | Boundary = typename Master_matrix::Boundary |
| using | Row = typename Master_matrix::Row |
| using | Entry_constructor = typename Master_matrix::Entry_constructor |
| using | Column_settings = typename Master_matrix::Column_settings |
Public Member Functions | |
| Boundary_matrix (Column_settings *colSettings) | |
| Constructs an empty matrix. More... | |
| template<class Boundary_range = Boundary> | |
| Boundary_matrix (const std::vector< Boundary_range > &orderedBoundaries, Column_settings *colSettings) | |
| Constructs a new matrix from the given ranges of Matrix::Entry_representative. Each range corresponds to a column (the order of the ranges are preserved). The content of the ranges is assumed to be sorted by increasing IDs. The IDs of the simplices are also assumed to be consecutive, ordered by filtration value, starting with 0. More... | |
| Boundary_matrix (unsigned int numberOfColumns, Column_settings *colSettings) | |
| Constructs a new empty matrix and reserves space for the given number of columns. More... | |
| Boundary_matrix (const Boundary_matrix &matrixToCopy, Column_settings *colSettings=nullptr) | |
Copy constructor. If colSettings is not a null pointer, its value is kept instead of the one in the copied matrix. More... | |
| Boundary_matrix (Boundary_matrix &&other) noexcept | |
| Move constructor. More... | |
| Index | insert_boundary (const Boundary_range &boundary, Dimension dim=Master_matrix::template get_null_value< Dimension >()) |
| Inserts at the end of the matrix a new ordered column corresponding to the given boundary. This means that it is assumed that this method is called on boundaries in the order of the filtration. It also assumes that the cells in the given boundary are identified by their relative position in the filtration, starting at 0. If it is not the case, use the other insert_boundary instead by indicating the cell ID used in the boundaries when the cell is inserted. More... | |
| Index | insert_boundary (ID_index cellIndex, const Boundary_range &boundary, Dimension dim=Master_matrix::template get_null_value< Dimension >()) |
| It does the same as the other version, but allows the boundary cells to be identified without restrictions except that all IDs have to be strictly increasing in the order of filtration. Note that you should avoid then to use the other insertion method to avoid overwriting IDs. More... | |
| Column & | get_column (Index columnIndex) |
| Returns the column at the given MatIdx index. The type of the column depends on the chosen options, see PersistenceMatrixOptions::column_type. More... | |
| Row & | get_row (Index rowIndex) |
| Only available if PersistenceMatrixOptions::has_row_access is true. Returns the row at the given row index of the matrix. The type of the row depends on the chosen options, see PersistenceMatrixOptions::has_intrusive_rows. More... | |
| Index | remove_last () |
| Only available if PersistenceMatrixOptions::has_removable_columns is true. Removes the last cell in the filtration from the matrix and updates the barcode if this one was already computed. More... | |
| void | erase_empty_row (Index rowIndex) |
| If PersistenceMatrixOptions::has_row_access and PersistenceMatrixOptions::has_removable_rows are true: assumes that the row is empty and removes it. If PersistenceMatrixOptions::has_map_column_container and PersistenceMatrixOptions::has_column_and_row_swaps are true: cleans up maps used for the lazy row swaps. Otherwise, does nothing. More... | |
| Index | get_number_of_columns () const |
| Returns the current number of columns in the matrix. More... | |
| Dimension | get_column_dimension (Index columnIndex) const |
| Returns the dimension of the given column. More... | |
| void | add_to (Index sourceColumnIndex, Index targetColumnIndex) |
Adds column at sourceColumnIndex onto the column at targetColumnIndex in the matrix. More... | |
| void | multiply_target_and_add_to (Index sourceColumnIndex, const Field_element &coefficient, Index targetColumnIndex) |
Multiplies the target column with the coefficient and then adds the source column to it. That is: targetColumn = (targetColumn * coefficient) + sourceColumn. More... | |
| void | multiply_source_and_add_to (const Field_element &coefficient, Index sourceColumnIndex, Index targetColumnIndex) |
Multiplies the source column with the coefficient before adding it to the target column. That is: targetColumn += (coefficient * sourceColumn). The source column will not be modified. More... | |
| void | zero_entry (Index columnIndex, Index rowIndex) |
| Zeroes the entry at the given coordinates. More... | |
| void | zero_column (Index columnIndex) |
| Zeroes the column at the given index. More... | |
| bool | is_zero_entry (Index columnIndex, Index rowIndex) const |
| Indicates if the entry at given coordinates has value zero. More... | |
| bool | is_zero_column (Index columnIndex) |
| Indicates if the column at given index has value zero. More... | |
| Index | get_pivot (Index columnIndex) |
| Returns the pivot of the given column. More... | |
| void | reset (Column_settings *colSettings) |
| Resets the matrix to an empty matrix. More... | |
| Boundary_matrix & | operator= (const Boundary_matrix &other) |
| Assign operator. | |
Friends | |
| void | swap (Boundary_matrix &matrix1, Boundary_matrix &matrix2) |
| Swap operator. | |
| Master_matrix | An instantiation of Matrix from which all types and options are deduced. |
| using Gudhi::persistence_matrix::Boundary_matrix< Master_matrix >::Boundary = typename Master_matrix::Boundary |
Type of an input column.
| using Gudhi::persistence_matrix::Boundary_matrix< Master_matrix >::Column = typename Master_matrix::Column |
Column type.
| using Gudhi::persistence_matrix::Boundary_matrix< Master_matrix >::Column_settings = typename Master_matrix::Column_settings |
Structure giving access to the columns to necessary external classes.
| using Gudhi::persistence_matrix::Boundary_matrix< Master_matrix >::Dimension = typename Master_matrix::Dimension |
Dimension value type.
| using Gudhi::persistence_matrix::Boundary_matrix< Master_matrix >::Entry_constructor = typename Master_matrix::Entry_constructor |
Factory of Entry classes.
| using Gudhi::persistence_matrix::Boundary_matrix< Master_matrix >::Field_element = typename Master_matrix::Element |
Type of an field element.
| using Gudhi::persistence_matrix::Boundary_matrix< Master_matrix >::ID_index = typename Master_matrix::ID_index |
IDIdx index type.
| using Gudhi::persistence_matrix::Boundary_matrix< Master_matrix >::Index = typename Master_matrix::Index |
Container index type.
| using Gudhi::persistence_matrix::Boundary_matrix< Master_matrix >::Row = typename Master_matrix::Row |
Row type, only necessary with row access option.
inline |
| colSettings | Pointer to an existing setting structure for the columns. The structure should contain all the necessary external classes specifically necessary for the chosen column type, such as custom allocators. |
inline |
| Boundary_range | Range type for Matrix::Entry_representative ranges. Assumed to have a begin(), end() and size() method. |
| orderedBoundaries | Range of boundaries: orderedBoundaries is interpreted as a boundary matrix of a filtered simplicial complex, whose boundaries are ordered by filtration order. Therefore, orderedBoundaries[i] should store the boundary of the \( i^{th} \) simplex in the filtration, as an ordered list of indices of its facets (again those indices correspond to their respective position in the matrix). That is why the indices of the simplices are assumed to be consecutive and starting with 0 (an empty boundary is interpreted as a vertex boundary and not as a non existing simplex). All dimensions up to the maximal dimension of interest have to be present. If only a higher dimension is of interest and not everything should be stored, then use the insert_boundary method instead (after creating the matrix with the Boundary_matrix(unsigned int numberOfColumns, Column_settings* colSettings) constructor preferably). |
inline |
| numberOfColumns | Number of columns to reserve space for. |
inline |
| matrixToCopy | Matrix to copy. |
| colSettings | Either a pointer to an existing setting structure for the columns or a null pointer. The structure should contain all the necessary external classes specifically necessary for the chosen column type, such as custom allocators. If null pointer, the pointer stored in matrixToCopy is used instead. |
inlinenoexcept |
Move constructor.
| other | Matrix to move. |
inline |
inline |
| rowIndex | Row index of the empty row. |
inline |
Note that before returning the column, all column entries can eventually be reordered, if lazy swaps occurred. It is therefore recommended to avoid calling get_column between column or row swaps, otherwise the benefits of the the laziness is lost.
| columnIndex | MatIdx index of the column to return. |
inline |
| columnIndex | MatIdx index of the column representing the cell. |
inline |
inline |
| columnIndex | MatIdx index of the column. |
columnIndex.
inline |
Note that before returning the row, all column entries can eventually be reordered, if lazy swaps occurred. It is therefore recommended to avoid calling get_row between column or row swaps, otherwise the benefits of the the laziness is lost.
| rowIndex | Row index of the row to return. |
inline |
Different to the constructor, the boundaries do not have to come from a simplicial complex, but also from a more general entry complex. This includes cubical complexes or Morse complexes for example.
At the insertion, the boundary will be copied as is. The column will only be reduced later when the barcode is requested in order to apply some optimizations with the additional knowledge. Hence, the barcode will also not be updated, so call get_current_barcode only when the matrix is complete.
| Boundary_range | Range of Matrix::Entry_representative. Assumed to have a begin(), end() and size() method. |
| boundary | Boundary generating the new column. The content should be ordered by ID. |
| dim | Dimension of the cell whose boundary is given. If the complex is simplicial, this parameter can be omitted as it can be deduced from the size of the boundary. |
inline |
As a cell has to be inserted before one of its cofaces in a valid filtration (recall that it is assumed that the cells are inserted by order of filtration), it is sufficient to indicate the ID of the cell being inserted.
| cellIndex | IDIdx index to use to identify the new cell. |
| boundary | Boundary generating the new column. The indices of the boundary have to correspond to the cellIndex values of precedent calls of the method for the corresponding cells and should be ordered in increasing order. |
inline |
inline |
inline |
inline |
inline |
inline |
inline |
| columnIndex | MatIdx index of the column to zero. |
inline |
