Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > Class Template Reference
A base matrix (also see Base_matrix), but with column compression. That is, all identical columns in the matrix are compressed together as the same column. For matrices with a lot of redundant columns, this will save a lot of space. Also, any addition made onto a column will be performed at the same time on all other identical columns, which is an advantage for the cohomology algorithm for example. More...
Classes
class  Column_type
 Type for columns. Only one for each "column class" is explicitely constructed. More...
Public Types
using index = typename Master_matrix::index
using dimension_type = typename Master_matrix::dimension_type
using Field_operators = typename Master_matrix::Field_operators
 Field operators class. Necessary only if PersistenceMatrixOptions::is_z2 is false.
using Field_element_type = typename Master_matrix::element_type
using Row_type = typename Master_matrix::Row_type
using Cell_constructor = typename Master_matrix::Cell_constructor
using Column_settings = typename Master_matrix::Column_settings
Public Member Functions
 Base_matrix_with_column_compression (Column_settings *colSettings)
 Constructs an empty matrix. More...
template<class Container_type >
 Base_matrix_with_column_compression (const std::vector< Container_type > &columns, Column_settings *colSettings)
 Constructs a matrix from the given ordered columns. The columns are inserted in the given order. If no identical column already existed, a copy of the column is stored. If an identical one existed, no new column is constructed and the relationship between the two is registered in an union-find structure. More...
 Base_matrix_with_column_compression (unsigned int numberOfColumns, Column_settings *colSettings)
 Constructs a new empty matrix and reserves space for the given number of columns. More...
 Base_matrix_with_column_compression (const Base_matrix_with_column_compression &matrixToCopy, Column_settings *colSettings=nullptr)
 Copy constructor. If colSettings is not a null pointer, its value is kept instead of the one in the copied matrix. More...
 Base_matrix_with_column_compression (Base_matrix_with_column_compression &&other) noexcept
 Move constructor. More...
 ~Base_matrix_with_column_compression ()
 Destructor.
void insert_column (const Container_type &column)
 Inserts a new ordered column at the end of the matrix by copying the given range of Matrix::cell_rep_type. The content of the range is assumed to be sorted by increasing ID value. More...
template<class Boundary_type >
void insert_boundary (const Boundary_type &boundary, dimension_type dim=-1)
 Same as insert_column, only for interface purposes. The given dimension is ignored and not stored. More...
const Column_typeget_column (index columnIndex)
 Returns the column at the given MatIdx index. The type of the column depends on the choosen options, see PersistenceMatrixOptions::column_type. More...
const Row_typeget_row (index rowIndex) const
 Only available if PersistenceMatrixOptions::has_row_access is true. Returns the row at the given row index of the compressed matrix. The type of the row depends on the choosen options, see PersistenceMatrixOptions::has_intrusive_rows. Note that the row will be from the compressed matrix, that is, the one with only unique columns. More...
void erase_empty_row (index rowIndex)
 If PersistenceMatrixOptions::has_row_access and PersistenceMatrixOptions::has_removable_rows are true: assumes that the row is empty and removes it. Otherwise, does nothing. More...
index get_number_of_columns () const
 Returns the current number of columns in the matrix, counting also the redundant columns. More...
template<class Cell_range_or_column_index >
void add_to (const Cell_range_or_column_index &sourceColumn, index targetColumnIndex)
 Adds column represented by sourceColumn onto the column at targetColumnIndex in the matrix. More...
void multiply_target_and_add_to (const Cell_range_or_column_index &sourceColumn, const Field_element_type &coefficient, index targetColumnIndex)
 Multiplies the target column with the coefficiant and then adds the source column to it. That is: targetColumn = (targetColumn * coefficient) + sourceColumn. More...
void multiply_source_and_add_to (const Field_element_type &coefficient, const Cell_range_or_column_index &sourceColumn, index targetColumnIndex)
 Multiplies the source column with the coefficiant before adding it to the target column. That is: targetColumn += (coefficient * sourceColumn). The source column will not be modified. More...
bool is_zero_cell (index columnIndex, index rowIndex)
 Indicates if the cell at given coordinates has value zero. More...
bool is_zero_column (index columnIndex)
 Indicates if the column at given index has value zero. More...
void reset (Column_settings *colSettings)
 Resets the matrix to an empty matrix. More...
Base_matrix_with_column_compressionoperator= (const Base_matrix_with_column_compression &other)
 Assign operator.
Friends
void swap (Base_matrix_with_column_compression &matrix1, Base_matrix_with_column_compression &matrix2)
 Swap operator.
Detailed Description
template<class Master_matrix>
class Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >
Template Parameters
Master_matrixAn instanciation of Matrix from which all types and options are deduced.
Member Typedef Documentation
◆ Cell_constructor
template<class Master_matrix >
using Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::Cell_constructor = typename Master_matrix::Cell_constructor
Factory of Cell classes.
◆ Column_settings
using Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::Column_settings = typename Master_matrix::Column_settings
Structure giving access to the columns to necessary external classes.
◆ dimension_type
using Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::dimension_type = typename Master_matrix::dimension_type
Dimension value type.
◆ Field_element_type
using Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::Field_element_type = typename Master_matrix::element_type
Field element value type.
◆ index
using Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::index = typename Master_matrix::index
Container index type.
◆ Row_type
using Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::Row_type = typename Master_matrix::Row_type
Row type, only necessary with row access option.
Constructor & Destructor Documentation
◆ Base_matrix_with_column_compression() [1/5]
Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::Base_matrix_with_column_compression ( Column_settings colSettings)
inline
Parameters
colSettingsPointer to an existing setting structure for the columns. The structure should contain all the necessary external classes specifically necessary for the choosen column type, such as custom allocators.
◆ Base_matrix_with_column_compression() [2/5]
Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::Base_matrix_with_column_compression ( const std::vector< Container_type > &  columns,
inline
Template Parameters
Container_typeRange type for Matrix::cell_rep_type ranges. Assumed to have a begin(), end() and size() method.
Parameters
columnsA vector of Matrix::cell_rep_type ranges to construct the columns from. The content of the ranges are assumed to be sorted by increasing ID value.
◆ Base_matrix_with_column_compression() [3/5]
Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::Base_matrix_with_column_compression ( unsigned int  numberOfColumns,
inline
Parameters
numberOfColumnsNumber of columns to reserve space for.
◆ Base_matrix_with_column_compression() [4/5]
Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::Base_matrix_with_column_compression ( const Base_matrix_with_column_compression< Master_matrix > &  matrixToCopy,
Column_settings colSettings = nullptr
inline
Parameters
matrixToCopyMatrix to copy.
colSettingsEither a pointer to an existing setting structure for the columns or a null pointer. The structure should contain all the necessary external classes specifically necessary for the choosen column type, such as custom allocators. If null pointer, the pointer stored in matrixToCopy is used instead.
◆ Base_matrix_with_column_compression() [5/5]
Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::Base_matrix_with_column_compression ( Base_matrix_with_column_compression< Master_matrix > &&  other)
inlinenoexcept
Move constructor.
Parameters
otherMatrix to move.
Member Function Documentation
◆ add_to()
void Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::add_to ( const Cell_range_or_column_index &  sourceColumn,
inline
The representatives of redundant columns are summed together, which means that all column compressed together with the target column are affected by the change, not only the target.
Template Parameters
Cell_range_or_column_indexEither a range of Cell with a begin() and end() method, or any integer type.
Parameters
sourceColumnEither a cell range or the MatIdx index of the column to add.
targetColumnIndexMatIdx index of the target column.
◆ erase_empty_row()
void Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::erase_empty_row ( index  rowIndex)
inline
Warning
The removed rows are always assumed to be empty. If it is not the case, the deleted row cells are not removed from their columns. And in the case of intrusive rows, this will generate a segmentation fault when the column cells are destroyed later. The row access is just meant as a "read only" access to the rows and the erase_empty_row method just as a way to specify that a row is empty and can therefore be removed from dictionnaries. This allows to avoid testing the emptiness of a row at each column cell removal, what can be quite frequent.
Parameters
rowIndexRow index of the empty row.
◆ get_column()
const Base_matrix_with_column_compression< Master_matrix >::Column_type & Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::get_column ( index  columnIndex)
inline
Remark: the method it-self is not const, because of the path compression optimization of the union-find structure, when a column is looked up.
Parameters
columnIndexMatIdx index of the column to return.
Returns
Const reference to the column.
◆ get_number_of_columns()
Base_matrix_with_column_compression< Master_matrix >::index Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::get_number_of_columns
inline
Returns
The number of columns.
◆ get_row()
const Base_matrix_with_column_compression< Master_matrix >::Row_type & Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::get_row ( index  rowIndex) const
inline
Parameters
rowIndexRow index of the row to return.
Returns
Const reference to the row.
◆ insert_boundary()
void Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::insert_boundary ( const Boundary_type &  boundary,
dimension_type  dim = -1
inline
Template Parameters
Boundary_typeRange of Matrix::cell_rep_type. Assumed to have a begin(), end() and size() method.
Parameters
boundaryRange of Matrix::cell_rep_type from which the column has to be constructed. Assumed to be ordered by increasing ID value.
dimIgnored.
◆ insert_column()
void Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::insert_column ( const Container_type &  column)
inline
Template Parameters
Container_typeRange of Matrix::cell_rep_type. Assumed to have a begin(), end() and size() method.
Parameters
columnRange of Matrix::cell_rep_type from which the column has to be constructed. Assumed to be ordered by increasing ID value.
◆ is_zero_cell()
bool Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::is_zero_cell ( index  columnIndex,
index  rowIndex
inline
Parameters
columnIndexMatIdx index of the column of the cell.
rowIndexRow index of the row of the cell.
Returns
true If the cell has value zero.
false Otherwise.
◆ is_zero_column()
bool Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::is_zero_column ( index  columnIndex)
inline
Parameters
columnIndexMatIdx index of the column.
Returns
true If the column has value zero.
false Otherwise.
◆ multiply_source_and_add_to()
void Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::multiply_source_and_add_to ( const Field_element_type coefficient,
inline
Template Parameters
Parameters
coefficientValue to multiply.
sourceColumnEither a Cell range or the MatIdx index of the column to add.
◆ multiply_target_and_add_to()
void Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::multiply_target_and_add_to ( const Cell_range_or_column_index &  sourceColumn,
inline
Template Parameters
Parameters
◆ reset()
void Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix >::reset ( Column_settings colSettings)
inline
Parameters
operatorsPointer to the field operators.
cellConstructorPointer to the cell factory.
The documentation for this class was generated from the following file:
