base_matrix_with_column_compression.h
Go to the documentation of this file.
1 /* This file is part of the Gudhi Library - https://gudhi.inria.fr/ - which is released under MIT.
2  * See file LICENSE or go to https://gudhi.inria.fr/licensing/ for full license details.
3  * Author(s): Hannah Schreiber
4  *
5  * Copyright (C) 2022-24 Inria
6  *
7  * Modification(s):
8  * - YYYY/MM Author: Description of the modification
9  */
10
17 #ifndef PM_BASE_MATRIX_COMPRESSION_H
18 #define PM_BASE_MATRIX_COMPRESSION_H
19
20 #include <iostream> //print() only
21 #include <vector>
22 #include <utility> //std::swap, std::move & std::exchange
23
24 #include <boost/intrusive/set.hpp>
25 #include <boost/pending/disjoint_sets.hpp>
26
27 #include <gudhi/Simple_object_pool.h>
28
29 namespace Gudhi {
30 namespace persistence_matrix {
31
44 template <class Master_matrix>
45 class Base_matrix_with_column_compression : protected Master_matrix::Matrix_row_access_option
46 {
47  public:
48  using index = typename Master_matrix::index;
49  using dimension_type = typename Master_matrix::dimension_type;
53  using Field_operators = typename Master_matrix::Field_operators;
54  using Field_element_type = typename Master_matrix::element_type;
55  using Row_type = typename Master_matrix::Row_type;
57  using Cell_constructor = typename Master_matrix::Cell_constructor;
58  using Column_settings = typename Master_matrix::Column_settings;
65  : public Master_matrix::Column_type,
66  public boost::intrusive::set_base_hook<boost::intrusive::link_mode<boost::intrusive::normal_link> >
67  {
68  public:
69  using Base = typename Master_matrix::Column_type;
70
71  Column_type(Column_settings* colSettings = nullptr)
72  : Base(colSettings) {}
73  template <class Container_type>
74  Column_type(const Container_type& nonZeroRowIndices, Column_settings* colSettings)
75  : Base(nonZeroRowIndices, colSettings) {}
76  template <class Container_type, class Row_container_type>
77  Column_type(index columnIndex, const Container_type& nonZeroRowIndices, Row_container_type& rowContainer,
78  Column_settings* colSettings)
79  : Base(columnIndex, nonZeroRowIndices, rowContainer, colSettings) {}
80  template <class Container_type>
81  Column_type(const Container_type& nonZeroRowIndices, dimension_type dimension, Column_settings* colSettings)
82  : Base(nonZeroRowIndices, dimension, colSettings) {}
83  template <class Container_type, class Row_container_type>
84  Column_type(index columnIndex, const Container_type& nonZeroRowIndices, dimension_type dimension,
85  Row_container_type& rowContainer, Column_settings* colSettings)
86  : Base(columnIndex, nonZeroRowIndices, dimension, rowContainer, colSettings) {}
87  Column_type(const Column_type& column, Column_settings* colSettings = nullptr)
88  : Base(static_cast<const Base&>(column), colSettings) {}
89  template <class Row_container_type>
90  Column_type(const Column_type& column, index columnIndex, Row_container_type& rowContainer,
91  Column_settings* colSettings = nullptr)
92  : Base(static_cast<const Base&>(column), columnIndex, rowContainer, colSettings) {}
93  Column_type(Column_type&& column) noexcept : Base(std::move(static_cast<Base&>(column))) {}
94
95  //TODO: is it possible to make this work?
96  // template <class... U>
97  // Column_type(U&&... u) : Base(std::forward<U>(u)...) {}
98
99  index get_rep() const { return rep_; }
100  void set_rep(const index& rep) { rep_ = rep; }
101
102  struct Hasher {
103  size_t operator()(const Column_type& c) const { return std::hash<Base>()(static_cast<Base>(c)); }
104  };
105
106  private:
107  index rep_;
108  };
109
129  template <class Container_type>
130  Base_matrix_with_column_compression(const std::vector<Container_type>& columns,
131  Column_settings* colSettings);
139  Base_matrix_with_column_compression(unsigned int numberOfColumns,
140  Column_settings* colSettings);
151  Column_settings* colSettings = nullptr);
162
171  template <class Container_type>
172  void insert_column(const Container_type& column);
181  template <class Boundary_type>
182  void insert_boundary(const Boundary_type& boundary, dimension_type dim = -1);
193  const Column_type& get_column(index columnIndex);
203  const Row_type& get_row(index rowIndex) const;
217  void erase_empty_row(index rowIndex);
218
225
237  template <class Cell_range_or_column_index>
238  void add_to(const Cell_range_or_column_index& sourceColumn, index targetColumnIndex);
252  template <class Cell_range_or_column_index>
253  void multiply_target_and_add_to(const Cell_range_or_column_index& sourceColumn,
254  const Field_element_type& coefficient,
255  index targetColumnIndex);
269  template <class Cell_range_or_column_index>
270  void multiply_source_and_add_to(const Field_element_type& coefficient,
271  const Cell_range_or_column_index& sourceColumn,
272  index targetColumnIndex);
273
282  bool is_zero_cell(index columnIndex, index rowIndex);
290  bool is_zero_column(index columnIndex);
291
298  void reset(Column_settings* colSettings) {
299  columnToRep_.clear_and_dispose(delete_disposer(this));
300  columnClasses_ = boost::disjoint_sets_with_storage<>();
301  repToColumn_.clear();
302  nextColumnIndex_ = 0;
303  colSettings_ = colSettings;
304  }
305
314  matrix1.columnToRep_.swap(matrix2.columnToRep_);
315  std::swap(matrix1.columnClasses_, matrix2.columnClasses_);
316  matrix1.repToColumn_.swap(matrix2.repToColumn_);
317  std::swap(matrix1.nextColumnIndex_, matrix2.nextColumnIndex_);
318  std::swap(matrix1.colSettings_, matrix2.colSettings_);
319  std::swap(matrix1.columnPool_, matrix2.columnPool_);
320
321  if constexpr (Master_matrix::Option_list::has_row_access) {
322  swap(static_cast<typename Master_matrix::Matrix_row_access_option&>(matrix1),
323  static_cast<typename Master_matrix::Matrix_row_access_option&>(matrix2));
324  }
325  }
326
327  void print(); // for debug
328
329  private:
333  struct delete_disposer {
334  delete_disposer(Base_matrix_with_column_compression* matrix) : matrix_(matrix) {}
335
336  void operator()(Column_type* delete_this) { matrix_->columnPool_->destroy(delete_this); }
337
339  };
340
341  using ra_opt = typename Master_matrix::Matrix_row_access_option;
342  using col_dict_type = boost::intrusive::set<Column_type, boost::intrusive::constant_time_size<false> >;
343
344  col_dict_type columnToRep_;
345  boost::disjoint_sets_with_storage<> columnClasses_;
347  std::vector<Column_type*> repToColumn_;
349  index nextColumnIndex_;
350  Column_settings* colSettings_;
355  std::unique_ptr<Simple_object_pool<Column_type> > columnPool_;
356  inline static const Column_type empty_column_;
358  void _insert_column(index columnIndex);
359  void _insert_double_column(index columnIndex, typename col_dict_type::iterator& doubleIt);
360 };
361
362 template <class Master_matrix>
364  Column_settings* colSettings)
365  : ra_opt(), nextColumnIndex_(0), colSettings_(colSettings), columnPool_(new Simple_object_pool<Column_type>)
366 {}
367
368 template <class Master_matrix>
369 template <class Container_type>
371  const std::vector<Container_type>& columns, Column_settings* colSettings)
372  : ra_opt(columns.size()),
373  columnClasses_(columns.size()),
374  repToColumn_(columns.size(), nullptr),
375  nextColumnIndex_(0),
376  colSettings_(colSettings),
377  columnPool_(new Simple_object_pool<Column_type>)
378 {
379  for (const Container_type& c : columns) {
380  insert_column(c);
381  }
382 }
383
384 template <class Master_matrix>
386  unsigned int numberOfColumns, Column_settings* colSettings)
387  : ra_opt(numberOfColumns),
388  columnClasses_(numberOfColumns),
389  repToColumn_(numberOfColumns, nullptr),
390  nextColumnIndex_(0),
391  colSettings_(colSettings),
392  columnPool_(new Simple_object_pool<Column_type>)
393 {}
394
395 template <class Master_matrix>
397  const Base_matrix_with_column_compression& matrixToCopy, Column_settings* colSettings)
398  : ra_opt(static_cast<const ra_opt&>(matrixToCopy)),
399  columnClasses_(matrixToCopy.columnClasses_),
400  repToColumn_(matrixToCopy.repToColumn_.size(), nullptr),
401  nextColumnIndex_(0),
402  colSettings_(colSettings == nullptr ? matrixToCopy.colSettings_ : colSettings),
403  columnPool_(new Simple_object_pool<Column_type>)
404 {
405  for (const Column_type* col : matrixToCopy.repToColumn_) {
406  if (col != nullptr) {
407  if constexpr (Master_matrix::Option_list::has_row_access) {
408  repToColumn_[nextColumnIndex_] =
409  columnPool_->construct(*col, col->get_column_index(), ra_opt::rows_, colSettings_);
410  } else {
411  repToColumn_[nextColumnIndex_] = columnPool_->construct(*col, colSettings_);
412  }
413  columnToRep_.insert(columnToRep_.end(), *repToColumn_[nextColumnIndex_]);
414  repToColumn_[nextColumnIndex_]->set_rep(nextColumnIndex_);
415  }
416  nextColumnIndex_++;
417  }
418 }
419
420 template <class Master_matrix>
422  Base_matrix_with_column_compression&& other) noexcept
423  : ra_opt(std::move(static_cast<ra_opt&>(other))),
424  columnToRep_(std::move(other.columnToRep_)),
425  columnClasses_(std::move(other.columnClasses_)),
426  repToColumn_(std::move(other.repToColumn_)),
427  nextColumnIndex_(std::exchange(other.nextColumnIndex_, 0)),
428  colSettings_(std::exchange(other.colSettings_, nullptr)),
429  columnPool_(std::exchange(other.columnPool_, nullptr))
430 {}
431
432 template <class Master_matrix>
434 {
435  columnToRep_.clear_and_dispose(delete_disposer(this));
436 }
437
438 template <class Master_matrix>
439 template <class Container_type>
441 {
442  insert_boundary(column);
443 }
444
445 template <class Master_matrix>
446 template <class Boundary_type>
448  dimension_type dim)
449 {
450  // handles a dimension which is not actually stored.
451  // TODO: verify if this is not a problem for the cohomology algorithm and if yes,
452  // change how Column_dimension_option is choosen.
453  if (dim == -1) dim = boundary.size() == 0 ? 0 : boundary.size() - 1;
454
455  if constexpr (Master_matrix::Option_list::has_row_access && !Master_matrix::Option_list::has_removable_rows) {
456  if (boundary.begin() != boundary.end()) {
457  index pivot;
458  if constexpr (Master_matrix::Option_list::is_z2) {
459  pivot = *std::prev(boundary.end());
460  } else {
461  pivot = std::prev(boundary.end())->first;
462  }
463  if (ra_opt::rows_->size() <= pivot) ra_opt::rows_->resize(pivot + 1);
464  }
465  }
466
467  if (repToColumn_.size() == nextColumnIndex_) {
468  // could perhaps be avoided, if find_set returns something special when it does not find
469  columnClasses_.link(nextColumnIndex_, nextColumnIndex_);
470  if constexpr (Master_matrix::Option_list::has_row_access) {
471  repToColumn_.push_back(
472  columnPool_->construct(nextColumnIndex_, boundary, dim, ra_opt::rows_, colSettings_));
473  } else {
474  repToColumn_.push_back(columnPool_->construct(boundary, dim, colSettings_));
475  }
476  } else {
477  if constexpr (Master_matrix::Option_list::has_row_access) {
478  repToColumn_[nextColumnIndex_] =
479  columnPool_->construct(nextColumnIndex_, boundary, dim, ra_opt::rows_, colSettings_);
480  } else {
481  repToColumn_[nextColumnIndex_] = columnPool_->construct(boundary, dim, colSettings_);
482  }
483  }
484  _insert_column(nextColumnIndex_);
485
486  nextColumnIndex_++;
487 }
488
489 template <class Master_matrix>
492 {
493  auto col = repToColumn_[columnClasses_.find_set(columnIndex)];
494  if (col == nullptr) return empty_column_;
495  return *col;
496 }
497
498 template <class Master_matrix>
501 {
502  static_assert(Master_matrix::Option_list::has_row_access, "Row access has to be enabled for this method.");
503
504  return ra_opt::get_row(rowIndex);
505 }
506
507 template <class Master_matrix>
509 {
510  if constexpr (Master_matrix::Option_list::has_row_access && Master_matrix::Option_list::has_removable_rows) {
511  ra_opt::erase_empty_row(rowIndex);
512  }
513 }
514
515 template <class Master_matrix>
518 {
519  return nextColumnIndex_;
520 }
521
522 template <class Master_matrix>
523 template <class Cell_range_or_column_index>
524 inline void Base_matrix_with_column_compression<Master_matrix>::add_to(const Cell_range_or_column_index& sourceColumn,
525  index targetColumnIndex)
526 {
527  // handle case where targetRep == sourceRep?
528  index targetRep = columnClasses_.find_set(targetColumnIndex);
529  Column_type& target = *repToColumn_[targetRep];
530  columnToRep_.erase(target);
531  if constexpr (std::is_integral_v<Cell_range_or_column_index>) {
532  target += get_column(sourceColumn);
533  } else {
534  target += sourceColumn;
535  }
536  _insert_column(targetRep);
537 }
538
539 template <class Master_matrix>
540 template <class Cell_range_or_column_index>
542  const Cell_range_or_column_index& sourceColumn, const Field_element_type& coefficient, index targetColumnIndex)
543 {
544  // handle case where targetRep == sourceRep?
545  index targetRep = columnClasses_.find_set(targetColumnIndex);
546  Column_type& target = *repToColumn_[targetRep];
547  columnToRep_.erase(target);
548  if constexpr (std::is_integral_v<Cell_range_or_column_index>) {
549  target.multiply_target_and_add(coefficient, get_column(sourceColumn));
550  } else {
551  target.multiply_target_and_add(coefficient, sourceColumn);
552  }
553  _insert_column(targetRep);
554 }
555
556 template <class Master_matrix>
557 template <class Cell_range_or_column_index>
559  const Field_element_type& coefficient, const Cell_range_or_column_index& sourceColumn, index targetColumnIndex)
560 {
561  // handle case where targetRep == sourceRep?
562  index targetRep = columnClasses_.find_set(targetColumnIndex);
563  Column_type& target = *repToColumn_[targetRep];
564  columnToRep_.erase(target);
565  if constexpr (std::is_integral_v<Cell_range_or_column_index>) {
566  target.multiply_source_and_add(get_column(sourceColumn), coefficient);
567  } else {
568  target.multiply_source_and_add(sourceColumn, coefficient);
569  }
570  _insert_column(targetRep);
571 }
572
573 template <class Master_matrix>
575 {
576  auto col = repToColumn_[columnClasses_.find_set(columnIndex)];
577  if (col == nullptr) return true;
578  return !col->is_non_zero(rowIndex);
579 }
580
581 template <class Master_matrix>
583 {
584  auto col = repToColumn_[columnClasses_.find_set(columnIndex)];
585  if (col == nullptr) return true;
586  return col->is_empty();
587 }
588
589 template <class Master_matrix>
592 {
593  for (auto col : repToColumn_) {
594  if (col != nullptr) {
595  columnPool_->destroy(col);
596  col = nullptr;
597  }
598  }
599  ra_opt::operator=(other);
600  columnClasses_ = other.columnClasses_;
601  columnToRep_.reserve(other.columnToRep_.size());
602  repToColumn_.resize(other.repToColumn_.size(), nullptr);
603  nextColumnIndex_ = 0;
604  colSettings_ = other.colSettings_;
605  for (const Column_type* col : other.repToColumn_) {
606  if constexpr (Master_matrix::Option_list::has_row_access) {
607  repToColumn_[nextColumnIndex_] =
608  columnPool_->construct(*col, col->get_column_index(), ra_opt::rows_, colSettings_);
609  } else {
610  repToColumn_[nextColumnIndex_] = columnPool_->construct(*col, colSettings_);
611  }
612  columnToRep_.insert(columnToRep_.end(), *repToColumn_[nextColumnIndex_]);
613  repToColumn_[nextColumnIndex_]->set_rep(nextColumnIndex_);
614  nextColumnIndex_++;
615  }
616  return *this;
617 }
618
619 template <class Master_matrix>
621 {
622  std::cout << "Compressed_matrix:\n";
623  for (Column_type& col : columnToRep_) {
624  for (auto e : col->get_content(nextColumnIndex_)) {
625  if (e == 0u)
626  std::cout << "- ";
627  else
628  std::cout << e << " ";
629  }
630  std::cout << "(";
631  for (index i = 0; i < nextColumnIndex_; ++i) {
632  if (columnClasses_.find_set(i) == col.get_rep()) std::cout << i << " ";
633  }
634  std::cout << ")\n";
635  }
636  std::cout << "\n";
637  std::cout << "Row Matrix:\n";
638  for (index i = 0; i < ra_opt::rows_->size(); ++i) {
639  const Row_type& row = ra_opt::rows_[i];
640  for (const auto& cell : row) {
641  std::cout << cell.get_column_index() << " ";
642  }
643  std::cout << "(" << i << ")\n";
644  }
645  std::cout << "\n";
646 }
647
648 template <class Master_matrix>
649 inline void Base_matrix_with_column_compression<Master_matrix>::_insert_column(index columnIndex)
650 {
651  Column_type& col = *repToColumn_[columnIndex];
652
653  if (col.is_empty()) {
654  columnPool_->destroy(&col); // delete curr_col;
655  repToColumn_[columnIndex] = nullptr;
656  return;
657  }
658
659  col.set_rep(columnIndex);
660  auto res = columnToRep_.insert(col);
661  if (res.first->get_rep() != columnIndex) { //if true, then redundant column
662  _insert_double_column(columnIndex, res.first);
663  }
664 }
665
666 template <class Master_matrix>
667 inline void Base_matrix_with_column_compression<Master_matrix>::_insert_double_column(
668  index columnIndex, typename col_dict_type::iterator& doubleIt)
669 {
670  index doubleRep = doubleIt->get_rep();
671  columnClasses_.link(columnIndex, doubleRep); // both should be representatives
672  index newRep = columnClasses_.find_set(columnIndex);
673
674  columnPool_->destroy(repToColumn_[columnIndex]);
675  repToColumn_[columnIndex] = nullptr;
676
677  if (newRep == columnIndex) {
678  std::swap(repToColumn_[doubleRep], repToColumn_[columnIndex]);
679  doubleIt->set_rep(columnIndex);
680  }
681 }
682
683 } // namespace persistence_matrix
684 } // namespace Gudhi
685
686 #endif // PM_BASE_MATRIX_COMPRESSION_H
Type for columns. Only one for each "column class" is explicitely constructed.
Definition: base_matrix_with_column_compression.h:67
A base matrix (also see Base_matrix), but with column compression. That is, all identical columns in ...
Definition: base_matrix_with_column_compression.h:46
Indicates if the cell at given coordinates has value zero.
Definition: base_matrix_with_column_compression.h:574
void reset(Column_settings *colSettings)
Resets the matrix to an empty matrix.
Definition: base_matrix_with_column_compression.h:298
typename Master_matrix::Column_settings Column_settings
Definition: base_matrix_with_column_compression.h:59
Indicates if the column at given index has value zero.
Definition: base_matrix_with_column_compression.h:582
const Column_type & get_column(index columnIndex)
Returns the column at the given MatIdx index. The type of the column depends on the choosen options,...
Definition: base_matrix_with_column_compression.h:491
If PersistenceMatrixOptions::has_row_access and PersistenceMatrixOptions::has_removable_rows are true...
Definition: base_matrix_with_column_compression.h:508
typename Master_matrix::dimension_type dimension_type
void multiply_source_and_add_to(const Field_element_type &coefficient, const Cell_range_or_column_index &sourceColumn, index targetColumnIndex)
Multiplies the source column with the coefficiant before adding it to the target column....
Definition: base_matrix_with_column_compression.h:558
void add_to(const Cell_range_or_column_index &sourceColumn, index targetColumnIndex)
Adds column represented by sourceColumn onto the column at targetColumnIndex in the matrix.
Definition: base_matrix_with_column_compression.h:524
Base_matrix_with_column_compression(Column_settings *colSettings)
Constructs an empty matrix.
Definition: base_matrix_with_column_compression.h:363
typename Master_matrix::Field_operators Field_operators
Field operators class. Necessary only if PersistenceMatrixOptions::is_z2 is false.
Definition: base_matrix_with_column_compression.h:53
void insert_column(const Container_type &column)
Inserts a new ordered column at the end of the matrix by copying the given range of Matrix::cell_rep_...
Definition: base_matrix_with_column_compression.h:440
void insert_boundary(const Boundary_type &boundary, dimension_type dim=-1)
Same as insert_column, only for interface purposes. The given dimension is ignored and not stored.
Definition: base_matrix_with_column_compression.h:447
typename Master_matrix::Cell_constructor Cell_constructor
void multiply_target_and_add_to(const Cell_range_or_column_index &sourceColumn, const Field_element_type &coefficient, index targetColumnIndex)
Multiplies the target column with the coefficiant and then adds the source column to it....
Definition: base_matrix_with_column_compression.h:541
typename Master_matrix::Row_type Row_type
Definition: base_matrix_with_column_compression.h:56
friend void swap(Base_matrix_with_column_compression &matrix1, Base_matrix_with_column_compression &matrix2)
Swap operator.
Definition: base_matrix_with_column_compression.h:313
const Row_type & get_row(index rowIndex) const
Only available if PersistenceMatrixOptions::has_row_access is true. Returns the row at the given row ...
Definition: base_matrix_with_column_compression.h:500
typename Master_matrix::index index
Definition: base_matrix_with_column_compression.h:48
~Base_matrix_with_column_compression()
Destructor.
Definition: base_matrix_with_column_compression.h:433
typename Master_matrix::element_type Field_element_type
index get_number_of_columns() const
Returns the current number of columns in the matrix, counting also the redundant columns.
Definition: base_matrix_with_column_compression.h:517
Base_matrix_with_column_compression & operator=(const Base_matrix_with_column_compression &other)
Assign operator.
Definition: base_matrix_with_column_compression.h:591
Gudhi namespace.
Definition: SimplicialComplexForAlpha.h:14
