| add_to(const Cell_range_or_column_index &sourceColumn, index targetColumnIndex) | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | inline |
| Base_matrix_with_column_compression(Column_settings *colSettings) | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | inline |
| Base_matrix_with_column_compression(const std::vector< Container_type > &columns, Column_settings *colSettings) | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | inline |
| Base_matrix_with_column_compression(unsigned int numberOfColumns, Column_settings *colSettings) | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | inline |
| Base_matrix_with_column_compression(const Base_matrix_with_column_compression &matrixToCopy, Column_settings *colSettings=nullptr) | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | inline |
| Base_matrix_with_column_compression(Base_matrix_with_column_compression &&other) noexcept | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | inline |
| Cell_constructor typedef | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | |
| Column_settings typedef | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | |
| dimension_type typedef | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | |
| erase_empty_row(index rowIndex) | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | inline |
| Field_element_type typedef | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | |
| Field_operators typedef | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | |
| get_column(index columnIndex) | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | inline |
| get_number_of_columns() const | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | inline |
| get_row(index rowIndex) const | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | inline |
| index typedef | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | |
| insert_boundary(const Boundary_type &boundary, dimension_type dim=-1) | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | inline |
| insert_column(const Container_type &column) | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | inline |
| is_zero_cell(index columnIndex, index rowIndex) | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | inline |
| is_zero_column(index columnIndex) | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | inline |
| multiply_source_and_add_to(const Field_element_type &coefficient, const Cell_range_or_column_index &sourceColumn, index targetColumnIndex) | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | inline |
| multiply_target_and_add_to(const Cell_range_or_column_index &sourceColumn, const Field_element_type &coefficient, index targetColumnIndex) | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | inline |
| operator=(const Base_matrix_with_column_compression &other) | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | inline |
| reset(Column_settings *colSettings) | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | inline |
| Row_type typedef | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | |
| swap(Base_matrix_with_column_compression &matrix1, Base_matrix_with_column_compression &matrix2) | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | friend |
| ~Base_matrix_with_column_compression() | Gudhi::persistence_matrix::Base_matrix_with_column_compression< Master_matrix > | inline |
