Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::cech_complex::Cech_complex< Kernel, SimplicialComplexForCechComplex > Class Template Reference
Cech complex class. More...
Public Member Functions
template<typename InputPointRange >
 Cech_complex (const InputPointRange &points, Filtration_value max_radius, const bool exact=false)
 Cech_complex constructor from a range of points. More...
void create_complex (SimplicialComplexForCechComplex &complex, int dim_max)
 Initializes the simplicial complex from the proximity graph and expands it until a given maximal dimension, using the Cech blocker oracle. More...
Filtration_value max_radius () const
const Point_d & get_point (Vertex_handle vertex) const
std::vector< Sphere > & get_cache ()
const bool is_exact ()
 Check exact option. More...
Detailed Description
template<typename Kernel, typename SimplicialComplexForCechComplex>
class Gudhi::cech_complex::Cech_complex< Kernel, SimplicialComplexForCechComplex >
Cech complex class.
Cech complex is a simplicial complex where the set of all simplices is filtered by the radius of their minimal enclosing ball and bounded by the given max_radius.
Template Parameters
KernelCGAL kernel: either Epick_d or Epeck_d.
SimplicialComplexForCechComplexfurnishes Vertex_handle and Filtration_value type definition required by Gudhi::Proximity_graph and Cech blocker.
Examples
cech_complex_example_from_points.cpp, and cech_persistence.cpp.
Constructor & Destructor Documentation
◆ Cech_complex()
template<typename Kernel , typename SimplicialComplexForCechComplex >
Gudhi::cech_complex::Cech_complex< Kernel, SimplicialComplexForCechComplex >::Cech_complex ( const InputPointRange &  points,
const bool  exact = false
inline
Parameters
[in]pointsRange of points where each point is defined as kernel::Point_d.
[in]max_radiusMaximal radius value.
[in]exactExact filtration values computation. Not exact if Kernel is not CGAL::Epeck_d. Default is false.
Member Function Documentation
◆ create_complex()
void Gudhi::cech_complex::Cech_complex< Kernel, SimplicialComplexForCechComplex >::create_complex ( SimplicialComplexForCechComplex &  complex,
int  dim_max
inline
Parameters
[in]complexSimplicialComplexForCech to be created.
[in]dim_maxgraph expansion until this given maximal dimension.
Exceptions
std::invalid_argumentIn debug mode, if complex.num_vertices() does not return 0.
◆ get_cache()
std::vector<Sphere>& Gudhi::cech_complex::Cech_complex< Kernel, SimplicialComplexForCechComplex >::get_cache ( )
inline
Returns
Vector of cached spheres.
◆ get_point()
const Point_d& Gudhi::cech_complex::Cech_complex< Kernel, SimplicialComplexForCechComplex >::get_point ( Vertex_handle  vertex) const
inline
Parameters
[in]vertexPoint position in the range.
Returns
The point.
◆ is_exact()
const bool Gudhi::cech_complex::Cech_complex< Kernel, SimplicialComplexForCechComplex >::is_exact ( )
inline
Check exact option.
Returns
Exact option.
◆ max_radius()
Filtration_value Gudhi::cech_complex::Cech_complex< Kernel, SimplicialComplexForCechComplex >::max_radius ( ) const
inline
Returns
max_radius value given at construction.
The documentation for this class was generated from the following file:
