Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::cech_complex::SimplicialComplexForCech Struct Reference
The concept SimplicialComplexForCech describes the requirements for a type to implement a simplicial complex, that can be created from a Cech_complex. More...
Public Types
typedef unspecified Simplex_handle
typedef unspecified Vertex_handle
typedef unspecified Filtration_value
Public Member Functions
int assign_filtration (Simplex_handle simplex, Filtration_value filtration)
Simplex_vertex_range simplex_vertex_range (Simplex_handle const &simplex)
 Returns a range over vertices of a given simplex.
template<class ProximityGraph >
void insert_graph (const ProximityGraph &proximity_graph)
 Inserts a given Gudhi::ProximityGraph in the simplicial complex.
template<typename Blocker >
void expansion_with_blockers (int max_dim, Blocker block_simplex)
 Expands the simplicial complex containing only its one skeleton until a given maximal dimension. expansion can be blocked by the blocker oracle.
std::size_t num_vertices ()
Detailed Description
Member Typedef Documentation
◆ Filtration_value
Handle to specify the simplex filtration value.
◆ Simplex_handle
Handle to specify a simplex.
◆ Vertex_handle
Handle to specify a vertex. Must be a non-negative integer.
Member Function Documentation
◆ assign_filtration()
int Gudhi::cech_complex::SimplicialComplexForCech::assign_filtration ( Simplex_handle  simplex,
Assigns the 'simplex' with the given 'filtration' value.
◆ num_vertices()
std::size_t Gudhi::cech_complex::SimplicialComplexForCech::num_vertices ( )
Returns the number of vertices in the simplicial complex.
The documentation for this struct was generated from the following file:
