Loading [MathJax]/extensions/TeX/AMSsymbols.js
All Classes Namespaces Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Čech complex
Classes
class  Gudhi::cech_complex::Cech_complex< Kernel, SimplicialComplexForCechComplex >
 Cech complex class. More...
Functions
template<typename Kernel , typename SimplicialComplexForMEB , typename PointRange >
void Gudhi::cech_complex::assign_MEB_filtration (Kernel &&k, SimplicialComplexForMEB &complex, PointRange const &points, bool exact=false)
 Given a simplicial complex and an embedding of its vertices, this assigns to each simplex a filtration value equal to the squared radius of its minimal enclosing ball (MEB). More...
Detailed Description
Author
Vincent Rouvreau, Hind Montassif, Marc Glisse
Čech complex definition
Čech complex (Wikipedia) is a simplicial complex constructed from a proximity graph. The set of all simplices is filtered by the radius of their minimal enclosing ball.
The input shall be a range of points where a point is defined as CGAL kernel Point_d.
Remarks
For people only interested in the topology of the Čech complex (for instance persistence), Alpha complex is equivalent to the Čech complex and much smaller if you do not bound the radii. Čech complex can still make sense in higher dimension precisely because you can bound the radii.
Algorithm
Cech_complex first builds a proximity graph from a point cloud. The filtration value of each edge of the Gudhi::Proximity_graph is computed using CGAL kernel functions.
All edges that have a filtration value strictly greater than a user given maximal radius value, \(max\_radius\), are not inserted into the complex.
Vertex name correspond to the index of the point in the given range (aka. the point cloud).
Čech complex proximity graph representation
When creating a simplicial complex from this proximity graph, Cech_complex inserts the proximity graph into the simplicial complex data structure, and then expands the simplicial complex when required.
On this example, as edges \((x,y)\), \((y,z)\) and \((z,y)\) are in the complex, the minimal ball radius containing the points \((x,y,z)\) is computed.
\((x,y,z)\) is inserted to the simplicial complex with the filtration value set with \(mini\_ball\_radius(x,y,z))\) iff \(mini\_ball\_radius(x,y,z)) \leq max\_radius\).
And so on for higher dimensions.
Čech complex expansion
This radius computation is the reason why the Cech_complex is taking much more time to be computed than the Rips complex but it offers more topological guarantees.
If you already have a simplicial complex, it is possible to assign to each simplex a filtration value corresponding to the squared radius of its minimal enclosing ball using assign_MEB_filtration(). This can provide an alternate way of computing a Čech filtration, or it can be used on a Delaunay triangulation to compute a Delaunay-Čech filtration.
Example from a point cloud
This example builds the proximity graph from the given points, and maximal radius values. Then it creates a Simplex_tree with it.
Then, it is asked to display information about the simplicial complex.
#include <gudhi/Cech_complex.h>
#include <gudhi/Simplex_tree.h>
#include <CGAL/Epeck_d.h> // For EXACT or SAFE version
#include <iostream>
#include <string>
#include <vector>
int main() {
// Type definitions
using Kernel = CGAL::Epeck_d<CGAL::Dimension_tag<2>>;
using Point = typename Kernel::Point_d;
using Point_cloud = std::vector<Point>;
Point_cloud points;
points.emplace_back(1., 0.); // 0
points.emplace_back(0., 1.); // 1
points.emplace_back(2., 1.); // 2
points.emplace_back(3., 2.); // 3
points.emplace_back(0., 3.); // 4
points.emplace_back(3. + std::sqrt(3.), 3.); // 5
points.emplace_back(1., 4.); // 6
points.emplace_back(3., 4.); // 7
points.emplace_back(2., 4. + std::sqrt(3.)); // 8
points.emplace_back(0., 4.); // 9
points.emplace_back(-0.5, 2.); // 10
// Init of a Cech complex from points
Filtration_value max_radius = 1.;
Cech_complex cech_complex_from_points(points, max_radius);
Simplex_tree stree;
cech_complex_from_points.create_complex(stree, 2);
// Display information about the one skeleton Cech complex
std::clog << "Cech complex is of dimension " << stree.dimension() << " - " << stree.num_simplices() << " simplices - "
<< stree.num_vertices() << " vertices." << std::endl;
std::clog << "Iterator on Cech complex simplices in the filtration order, with [filtration value]:" << std::endl;
for (auto f_simplex : stree.filtration_simplex_range()) {
std::clog << " ( ";
for (auto vertex : stree.simplex_vertex_range(f_simplex)) {
std::clog << vertex << " ";
std::clog << ") -> "
<< "[" << stree.filtration(f_simplex) << "] ";
std::clog << std::endl;
return 0;
Options::Filtration_value Filtration_value
Type for the value of the filtration function.
Definition: Simplex_tree.h:102
Filtration_simplex_range const & filtration_simplex_range(Indexing_tag=Indexing_tag())
Returns a range over the simplices of the simplicial complex, in the order of the filtration.
Definition: Simplex_tree.h:338
Simplex_vertex_range simplex_vertex_range(Simplex_handle sh) const
Returns a range over the vertices of a simplex.
Definition: Simplex_tree.h:349
static Filtration_value filtration(Simplex_handle sh)
Returns the filtration value of a simplex.
Definition: Simplex_tree.h:614
size_t num_vertices() const
Returns the number of vertices in the complex.
Definition: Simplex_tree.h:651
size_t num_simplices()
Returns the number of simplices in the simplex_tree.
Definition: Simplex_tree.h:664
Cech complex class.
Definition: Cech_complex.h:44
Value type for a filtration function on a cell complex.
Definition: FiltrationValue.h:20
When launching (maximal enclosing ball radius is 1., is expanded until dimension 2):
$> ./Cech_complex_example_from_points
the program output is:
( 0 ) -> [0]
( 1 ) -> [0]
( 2 ) -> [0]
( 3 ) -> [0]
( 4 ) -> [0]
( 5 ) -> [0]
( 6 ) -> [0]
( 7 ) -> [0]
( 8 ) -> [0]
( 9 ) -> [0]
( 10 ) -> [0]
( 9 4 ) -> [0.5]
( 9 6 ) -> [0.5]
( 10 1 ) -> [0.559017]
( 10 4 ) -> [0.559017]
( 1 0 ) -> [0.707107]
( 2 0 ) -> [0.707107]
( 3 2 ) -> [0.707107]
( 6 4 ) -> [0.707107]
( 9 6 4 ) -> [0.707107]
( 2 1 ) -> [1]
( 2 1 0 ) -> [1]
( 4 1 ) -> [1]
( 5 3 ) -> [1]
( 7 3 ) -> [1]
( 7 5 ) -> [1]
( 7 6 ) -> [1]
( 8 6 ) -> [1]
( 8 7 ) -> [1]
( 10 4 1 ) -> [1]
Function Documentation
◆ assign_MEB_filtration()
void Gudhi::cech_complex::assign_MEB_filtration ( Kernel &&  k,
SimplicialComplexForMEB complex,
PointRange const &  points,
bool  exact = false
Applied on a Čech complex, it recomputes the same values (squared). Applied on a Delaunay triangulation, it computes the Delaunay-Čech filtration.
Template Parameters
KernelCGAL kernel: either Epick_d or Epeck_d.
PointRangeRandom access range of Kernel::Point_d.
Parameters
[in]kThe geometric kernel.
[in]complexThe simplicial complex.
[in]pointsEmbedding of the vertices of the complex.
[in]exactIf true and Kernel is CGAL::Epeck_d, the filtration values are computed exactly. Default is false.
