Processing math: 100%
All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::persistent_cohomology::Persistent_cohomology< FilteredComplex, CoefficientField > Class Template Reference
Computes the persistent cohomology of a filtered complex. More...
Public Types
typedef FilteredComplex::Simplex_key Simplex_key
 Data stored for each simplex.
typedef FilteredComplex::Simplex_handle Simplex_handle
 Handle to specify a simplex.
typedef FilteredComplex::Filtration_value Filtration_value
 Type for the value of the filtration function.
typedef CoefficientField::Element Arith_element
 Type of element of the field.
typedef std::tuple< Simplex_handle, Simplex_handle, Arith_elementPersistent_interval
 Type for birth and death FilteredComplex::Simplex_handle. The Arith_element field is used for the multi-field framework.
- Public Types inherited from PersistentHomology
typedef unspecified Filtered_complex
 Type of filtered cell complex on which persistent homology is computed. More...
typedef unspecified Coefficient_field
 Type of coefficients to be used for computing persistent homology. More...
Public Member Functions
 Persistent_cohomology (FilteredComplex &cpx, bool persistence_dim_max=false)
 Initializes the Persistent_cohomology class. More...
void init_coefficients (int charac)
 Initializes the coefficient field.
void init_coefficients (int charac_min, int charac_max)
 Initializes the coefficient field for multi-field persistent homology.
void compute_persistent_cohomology (Filtration_value min_interval_length=0)
 Compute the persistent homology of the filtered simplicial complex. More...
void output_diagram (std::ostream &ostream=std::cout)
 Output the persistence diagram in ostream. More...
std::vector< int > betti_numbers () const
 Returns Betti numbers. More...
int betti_number (int dimension) const
 Returns the Betti number of the dimension passed by parameter. More...
std::vector< int > persistent_betti_numbers (Filtration_value from, Filtration_value to) const
 Returns the persistent Betti numbers. More...
int persistent_betti_number (int dimension, Filtration_value from, Filtration_value to) const
 Returns the persistent Betti number of the dimension passed by parameter. More...
const std::vector< Persistent_interval > & get_persistent_pairs () const
 Returns a list of persistence birth and death FilteredComplex::Simplex_handle pairs. More...
std::vector< std::pair< Filtration_value, Filtration_value > > intervals_in_dimension (int dimension)
 Returns persistence intervals for a given dimension. More...
Detailed Description
Constructor & Destructor Documentation
◆ Persistent_cohomology()
template<class FilteredComplex, class CoefficientField>
Gudhi::persistent_cohomology::Persistent_cohomology< FilteredComplex, CoefficientField >::Persistent_cohomology ( FilteredComplex cpx,
bool  persistence_dim_max = false
inlineexplicit
Parameters
[in]cpxComplex for which the persistent homology is computed. cpx is a model of FilteredComplex
[in]persistence_dim_maxif true, the persistent homology for the maximal dimension in the complex is computed. If false, it is ignored. Default is false.
Exceptions
std::out_of_rangeIn case the number of simplices is more than Simplex_key type numeric limit.
Member Function Documentation
◆ betti_number()
int Gudhi::persistent_cohomology::Persistent_cohomology< FilteredComplex, CoefficientField >::betti_number ( int  dimension) const
inline
Parameters
[in]dimensionThe Betti number dimension to get.
Returns
Betti number of the given dimension
Examples:
Persistent_cohomology/plain_homology.cpp.
◆ betti_numbers()
std::vector<int> Gudhi::persistent_cohomology::Persistent_cohomology< FilteredComplex, CoefficientField >::betti_numbers ( ) const
inline
Returns
A vector of Betti numbers.
Examples:
Persistent_cohomology/custom_persistence_sort.cpp.
◆ compute_persistent_cohomology()
void Gudhi::persistent_cohomology::Persistent_cohomology< FilteredComplex, CoefficientField >::compute_persistent_cohomology ( Filtration_value  min_interval_length = 0)
inline
Parameters
[in]min_interval_lengththe computation discards all intervals of length less or equal than min_interval_length
Assumes that the filtration provided by the simplicial complex is valid. Undefined behavior otherwise.
Examples:
Bitmap_cubical_complex/cubical_complex_persistence.cpp, Bitmap_cubical_complex/periodic_cubical_complex_persistence.cpp, Bitmap_cubical_complex/Random_bitmap_cubical_complex.cpp, Persistent_cohomology/custom_persistence_sort.cpp, Persistent_cohomology/persistence_from_simple_simplex_tree.cpp, Persistent_cohomology/plain_homology.cpp, and Witness_complex/example_nearest_landmark_table.cpp.
◆ get_persistent_pairs()
const std::vector<Persistent_interval>& Gudhi::persistent_cohomology::Persistent_cohomology< FilteredComplex, CoefficientField >::get_persistent_pairs ( ) const
inline
Returns
A list of Persistent_cohomology::Persistent_interval
Examples:
◆ intervals_in_dimension()
std::vector< std::pair< Filtration_value , Filtration_value > > Gudhi::persistent_cohomology::Persistent_cohomology< FilteredComplex, CoefficientField >::intervals_in_dimension ( int  dimension)
inline
Parameters
[in]dimensionDimension to get the birth and death pairs from.
Returns
A vector of persistence intervals (birth and death) on a fixed dimension.
◆ output_diagram()
void Gudhi::persistent_cohomology::Persistent_cohomology< FilteredComplex, CoefficientField >::output_diagram ( std::ostream &  ostream = std::cout)
inline
The file format is the following: p1*...*pr dim b d
where "dim" is the dimension of the homological feature, b and d are respectively the birth and death of the feature and p1*...*pr is the product of prime numbers pi such that the homology feature exists in homology with Z/piZ coefficients.
Examples:
Bitmap_cubical_complex/cubical_complex_persistence.cpp, Bitmap_cubical_complex/periodic_cubical_complex_persistence.cpp, Bitmap_cubical_complex/Random_bitmap_cubical_complex.cpp, Persistent_cohomology/persistence_from_simple_simplex_tree.cpp, Persistent_cohomology/plain_homology.cpp, and Witness_complex/example_nearest_landmark_table.cpp.
◆ persistent_betti_number()
int Gudhi::persistent_cohomology::Persistent_cohomology< FilteredComplex, CoefficientField >::persistent_betti_number ( int  dimension,
Filtration_value  to
) const
inline
Parameters
[in]fromThe persistence birth limit to be added in the number (persistent birth \leq from).
[in]toThe persistence death limit to be added in the number (persistent death > to).
Returns
Persistent Betti number of the given dimension
Examples:
◆ persistent_betti_numbers()
std::vector<int> Gudhi::persistent_cohomology::Persistent_cohomology< FilteredComplex, CoefficientField >::persistent_betti_numbers ( Filtration_value  from,
Filtration_value  to
) const
inline
Parameters
Returns
A vector of persistent Betti numbers.
The documentation for this class was generated from the following file:
GUDHI  Version 3.0.0  - C++ library for Topological Data Analysis (TDA) and Higher Dimensional Geometry Understanding.  - Copyright : MIT Generated on Tue Sep 24 2019 09:57:51 for GUDHI by Doxygen 1.8.13
