#include <gudhi/graph_simplicial_complex.h>
#include <gudhi/Simplex_tree.h>
#include <gudhi/Persistent_cohomology.h>
#include <gudhi/Points_off_io.h>
#include <boost/program_options.hpp>
#include <string>
#include <vector>
#include <limits>
#include <utility>
#include <map>
using Proximity_graph = Gudhi::Proximity_graph<Simplex_tree>;
using Point = std::vector<double>;
void program_options(int argc, char * argv[]
                     , std::string & off_file_points
                     , std::string & filediag
                     , int & dim_max
                     , int & p
int main(int argc, char * argv[]) {
  std::string off_file_points;
  std::string filediag;
  int dim_max;
  int p;
  program_options(argc, argv, off_file_points, filediag, threshold, dim_max, p, min_persistence);
  Proximity_graph prox_graph = Gudhi::compute_proximity_graph<Simplex_tree>(off_reader.get_point_cloud(),
        threshold,
  st.expansion(dim_max);
  std::cout << "The complex contains " << st.num_simplices() << " simplices \n";
  std::cout << "   and has dimension " << st.dimension() << " \n";
  st.initialize_filtration();
  pcoh.init_coefficients(p);
  pcoh.compute_persistent_cohomology(min_persistence);
  if (filediag.empty()) {
    pcoh.output_diagram();
  } else {
    std::ofstream out(filediag);
    pcoh.output_diagram(out);
    out.close();
  return 0;
                     , int & dim_max
                     , int & p
  namespace po = boost::program_options;
  po::options_description hidden("Hidden options");
  hidden.add_options()
      ("input-file", po::value<std::string>(&off_file_points),
       "Name of an OFF file containing a point set.\n");
  po::options_description visible("Allowed options", 100);
  visible.add_options()
      ("help,h", "produce help message")
      ("output-file,o", po::value<std::string>(&filediag)->default_value(std::string()),
       "Name of file in which the persistence diagram is written. Default print in std::cout")
      ("max-edge-length,r",
       po::value<Filtration_value>(&threshold)->default_value(std::numeric_limits<Filtration_value>::infinity()),
       "Maximal length of an edge for the Rips complex construction.")
      ("cpx-dimension,d", po::value<int>(&dim_max)->default_value(1),
       "Maximal dimension of the Rips complex we want to compute.")
      ("field-charac,p", po::value<int>(&p)->default_value(11),
       "Characteristic p of the coefficient field Z/pZ for computing homology.")
      ("min-persistence,m", po::value<Filtration_value>(&min_persistence),
       "Minimal lifetime of homology feature to be recorded. Default is 0. Enter a negative value to see zero length intervals");
  po::positional_options_description pos;
  pos.add("input-file", 1);
  po::options_description all;
  all.add(visible).add(hidden);
  po::variables_map vm;
  po::store(po::command_line_parser(argc, argv).
            options(all).positional(pos).run(), vm);
  po::notify(vm);
  if (vm.count("help") || !vm.count("input-file")) {
    std::cout << std::endl;
    std::cout << "Compute the persistent homology with coefficient field Z/pZ \n";
    std::cout << "of a Rips complex defined on a set of input points.\n \n";
    std::cout << "The output diagram contains one bar per line, written with the convention: \n";
    std::cout << "   p   dim b d \n";
    std::cout << "where dim is the dimension of the homological feature,\n";
    std::cout << "b and d are respectively the birth and death of the feature and \n";
    std::cout << "p is the characteristic of the field Z/pZ used for homology coefficients." << std::endl << std::endl;
    std::cout << "Usage: " << argv[0] << " [options] input-file" << std::endl << std::endl;
    std::cout << visible << std::endl;
    exit(-1);
