Structure representing the coefficient field \(\mathbb{Z}/p\mathbb{Z}\).
More...
- Examples:
- Bitmap_cubical_complex/cubical_complex_persistence.cpp, Bitmap_cubical_complex/periodic_cubical_complex_persistence.cpp, Bitmap_cubical_complex/Random_bitmap_cubical_complex.cpp, Bottleneck_distance/alpha_rips_persistence_bottleneck_distance.cpp, Persistent_cohomology/custom_persistence_sort.cpp, Persistent_cohomology/persistence_from_file.cpp, Persistent_cohomology/persistence_from_simple_simplex_tree.cpp, Persistent_cohomology/plain_homology.cpp, Persistent_cohomology/rips_persistence_step_by_step.cpp, Persistent_cohomology/rips_persistence_via_boundary_matrix.cpp, Rips_complex/rips_distance_matrix_persistence.cpp, Rips_complex/rips_persistence.cpp, Witness_complex/example_nearest_landmark_table.cpp, Witness_complex/strong_witness_persistence.cpp, and Witness_complex/weak_witness_persistence.cpp.
◆ inverse()
| std::pair<Element, Element> Gudhi::persistent_cohomology::Field_Zp::inverse |
Element |
x, |
Element |
P |
inline |
Returns the inverse in the field. Modifies P. ???
◆ plus_times_equal()
| Element Gudhi::persistent_cohomology::Field_Zp::plus_times_equal |
const Element & |
x, |
const Element & |
y, |
const Element & |
w |
inline |
◆ times()
| Element Gudhi::persistent_cohomology::Field_Zp::times |
const Element & |
y, |
const Element & |
w |
inline |
◆ times_minus()
| Element Gudhi::persistent_cohomology::Field_Zp::times_minus |
Element |
x, |
Element |
y |
inline |
The documentation for this class was generated from the following file:
