#include <boost/program_options.hpp>
#include <CGAL/Epick_d.h>
#include <gudhi/Alpha_complex.h>
#include <gudhi/Persistent_cohomology.h>
#include <gudhi/Simplex_tree.h>
#include <iostream>
#include <string>
#include <limits>
void program_options(int argc, char *argv[], std::string &off_file_points, std::string &output_file_diag,
int main(int argc, char **argv) {
  std::string off_file_points;
  std::string output_file_diag;
  int coeff_field_characteristic;
  program_options(argc, argv, off_file_points, output_file_diag, alpha_square_max_value, coeff_field_characteristic,
                  min_persistence);
  using Kernel = CGAL::Epick_d<CGAL::Dynamic_dimension_tag>;
  if (alpha_complex_from_file.create_complex(simplex, alpha_square_max_value)) {
" simplices - " << simplex.
num_vertices() <<
" vertices." << std::endl;
    std::cout <<
"Simplex_tree dim: " << simplex.
dimension() << std::endl;
        simplex);
    pcoh.init_coefficients(coeff_field_characteristic);
    pcoh.compute_persistent_cohomology(min_persistence);
    if (output_file_diag.empty()) {
      pcoh.output_diagram();
    } else {
      std::cout << "Result in file: " << output_file_diag << std::endl;
      std::ofstream out(output_file_diag);
      pcoh.output_diagram(out);
      out.close();
  return 0;
  namespace po = boost::program_options;
  po::options_description hidden("Hidden options");
  hidden.add_options()("input-file", po::value<std::string>(&off_file_points),
                       "Name of file containing a point set. Format is one point per line:   X1 ... Xd ");
  po::options_description visible("Allowed options", 100);
  visible.add_options()("help,h", "produce help message")(
      "output-file,o", po::value<std::string>(&output_file_diag)->default_value(std::string()),
      "Name of file in which the persistence diagram is written. Default print in std::cout")(
      "max-alpha-square-value,r", po::value<Filtration_value>(&alpha_square_max_value)
                                      ->default_value(std::numeric_limits<Filtration_value>::infinity()),
      "Maximal alpha square value for the Alpha complex construction.")(
      "field-charac,p", po::value<int>(&coeff_field_characteristic)->default_value(11),
      "Characteristic p of the coefficient field Z/pZ for computing homology.")(
      "min-persistence,m", po::value<Filtration_value>(&min_persistence),
      "Minimal lifetime of homology feature to be recorded. Default is 0. Enter a negative value to see zero length "
      "intervals");
  po::positional_options_description pos;
  pos.add("input-file", 1);
  po::options_description all;
  all.add(visible).add(hidden);
  po::variables_map vm;
  po::store(po::command_line_parser(argc, argv).options(all).positional(pos).run(), vm);
  po::notify(vm);
  if (vm.count("help") || !vm.count("input-file")) {
    std::cout << std::endl;
    std::cout << "Compute the persistent homology with coefficient field Z/pZ \n";
    std::cout << "of an Alpha complex defined on a set of input points.\n \n";
    std::cout << "The output diagram contains one bar per line, written with the convention: \n";
    std::cout << "   p   dim b d \n";
    std::cout << "where dim is the dimension of the homological feature,\n";
    std::cout << "b and d are respectively the birth and death of the feature and \n";
    std::cout << "p is the characteristic of the field Z/pZ used for homology coefficients." << std::endl << std::endl;
    std::cout << "Usage: " << argv[0] << " [options] input-file" << std::endl << std::endl;
    std::cout << visible << std::endl;
    exit(-1);
