Rips complex reference manual¶
class
gudhi.
RipsComplex
¶ Bases:
object
The data structure is a one skeleton graph, or Rips graph, containing edges when the edge length is less or equal to a given threshold. Edge length is computed from a user given point cloud with a given distance function, or a distance matrix.
__init__
()¶ RipsComplex constructor.
- Parameters
Or
- Parameters
distance_matrix¶ – A distance matrix (full square or lower triangular).
And in both cases
- Parameters
sparse¶ (float) – If this is not None, it switches to building a sparse Rips and represents the approximation parameter epsilon.
