Simplex tree reference manual¶
class
gudhi.
SimplexTree
¶ Bases:
object
The simplex tree is an efficient and flexible data structure for representing general (filtered) simplicial complexes. The data structure is described in Jean-Daniel Boissonnat and Clément Maria. The Simplex Tree: An Efficient Data Structure for General Simplicial Complexes. Algorithmica, pages 1–22, 2014.
This class is a filtered, with keys, and non contiguous vertices version of the simplex tree.
__init__
()¶ SimplexTree constructor.
assign_filtration
()¶ This function assigns a new filtration value to a given N-simplex.
- Parameters
Note
Beware that after this operation, the structure may not be a valid filtration anymore, a simplex could have a lower filtration value than one of its faces. Callers are responsible for fixing this (with more
assign_filtration()
ormake_filtration_non_decreasing()
for instance) before calling any function that relies on the filtration property, likeinitialize_filtration()
betti_numbers
()¶ This function returns the Betti numbers of the simplicial complex.
- Returns
The Betti numbers ([B0, B1, …, Bn]).
- Return type
list of int
- Note
betti_numbers function requires
persistence()
function to be launched first.
dimension
()¶ This function returns the dimension of the simplicial complex.
- Returns
the simplicial complex dimension.
- Return type
int
Note
This function is not constant time because it can recompute dimension if required (can be triggered by
remove_maximal_simplex()
orprune_above_filtration()
methods).
expansion
()¶ Expands the Simplex_tree containing only its one skeleton until dimension max_dim.
The expanded simplicial complex until dimension d attached to a graph G is the maximal simplicial complex of dimension at most d admitting the graph G as 1-skeleton. The filtration value assigned to a simplex is the maximal filtration value of one of its edges.
The Simplex_tree must contain no simplex of dimension bigger than 1 when calling the method.
- Parameters
max_dim¶ (int.) – The maximal dimension.
filtration
()¶ This function returns the filtration value for a given N-simplex in this simplicial complex, or +infinity if it is not in the complex.
- Parameters
simplex¶ (list of int.) – The N-simplex, represented by a list of vertex.
- Returns
The simplicial complex filtration value.
- Return type
float
find
()¶ This function returns if the N-simplex was found in the simplicial complex or not.
- Parameters
simplex¶ (list of int.) – The N-simplex to find, represented by a list of vertex.
- Returns
true if the simplex was found, false otherwise.
- Return type
bool
get_cofaces
()¶ This function returns the cofaces of a given N-simplex with a given codimension.
- Parameters
- Returns
The (simplices of the) cofaces of a simplex
- Return type
list of tuples(simplex, filtration)
get_filtration
()¶ This function returns a list of all simplices with their given filtration values.
- Returns
The simplices sorted by increasing filtration values.
- Return type
get_skeleton
()¶ This function returns the (simplices of the) skeleton of a maximum given dimension.
- Parameters
dimension¶ (int.) – The skeleton dimension value.
- Returns
The (simplices of the) skeleton of a maximum dimension.
- Return type
get_star
()¶ This function returns the star of a given N-simplex.
- Parameters
- Returns
The (simplices of the) star of a simplex.
- Return type
()¶ This function initializes and sorts the simplicial complex filtration vector.
Note
This function must be launched before
persistence()
,betti_numbers()
,persistent_betti_numbers()
, orget_filtration()
afterinserting
orremoving
simplices.
insert
()¶ This function inserts the given N-simplex and its subfaces with the given filtration value (default value is ‘0.0’). If some of those simplices are already present with a higher filtration value, their filtration value is lowered.
()¶ This function ensures that each simplex has a higher filtration value than its faces by increasing the filtration values.
- Returns
True if any filtration value was modified, False if the filtration was already non-decreasing.
- Return type
bool
Note
Some simplex tree functions require the filtration to be valid. make_filtration_non_decreasing function is not launching
but returns the filtration modification information. If the complex has changed , please callinitialize_filtration()
to recompute it.
num_simplices
()¶ This function returns the number of simplices of the simplicial complex.
- Returns
the simplicial complex number of simplices.
- Return type
int
num_vertices
()¶ This function returns the number of vertices of the simplicial complex.
- Returns
The simplicial complex number of vertices.
- Return type
int
persistence
()¶ This function returns the persistence of the simplicial complex.
- Parameters
homology_coeff_field¶ (int.) – The homology coefficient field. Must be a prime number. Default value is 11.
min_persistence¶ (float.) – The minimum persistence value to take into account (strictly greater than min_persistence). Default value is 0.0. Sets min_persistence to -1.0 to see all values.
persistence_dim_max¶ (bool) – If true, the persistent homology for the maximal dimension in the complex is computed. If false, it is ignored. Default is false.
- Returns
The persistence of the simplicial complex.
- Return type
list of pairs(dimension, pair(birth, death))
persistence_intervals_in_dimension
()¶ This function returns the persistence intervals of the simplicial complex in a specific dimension.
- Parameters
dimension¶ (int.) – The specific dimension.
- Returns
The persistence intervals.
- Return type
numpy array of dimension 2
- Note
intervals_in_dim function requires
persistence()
persistence_pairs
()¶ This function returns a list of persistence birth and death simplices pairs.
- Returns
A list of persistence simplices intervals.
- Return type
list of pair of list of int
- Note
persistence_pairs function requires
persistence()
()¶ This function returns the persistent Betti numbers of the simplicial complex.
- Parameters
- Returns
The persistent Betti numbers ([B0, B1, …, Bn]).
- Return type
list of int
- Note
persistent_betti_numbers function requires
persistence()
()¶ Prune above filtration value given as parameter.
- Parameters
filtration¶ (float.) – Maximum threshold value.
- Returns
The filtration modification information.
- Return type
bool
Note
Some simplex tree functions require the filtration to be valid. prune_above_filtration function is not launching
to recompute it.Note
Note that the dimension of the simplicial complex may be lower after calling
than it was before. However,upper_bound_dimension()
will return the old value, which remains a valid upper bound. If you care, you can calldimension()
method to recompute the exact dimension.
()¶ This function removes a given maximal N-simplex from the simplicial complex.
- Parameters
Note
Be aware that removing is shifting data in a flat_map (
to be done).Note
The dimension of the simplicial complex may be lower after calling remove_maximal_simplex than it was before. However,
method will return the old value, which remains a valid upper bound. If you care, you can calldimension()
set_dimension
()¶ This function sets the dimension of the simplicial complex.
- Parameters
dimension¶ (int.) – The new dimension value.
Note
This function must be used with caution because it disables dimension recomputation when required (this recomputation can be triggered by
thisptr
()¶ This function returns a valid dimension upper bound of the simplicial complex.
- Returns
an upper bound on the dimension of the simplicial complex.
- Return type
int
write_persistence_diagram
()¶ This function writes the persistence intervals of the simplicial complex in a user given file name.
- Parameters
persistence_file¶ (string.) – The specific dimension.
- Note
persistence()
