OFF file visitor implementation according to Off_reader in order to read points from an OFF file. More...
#include <include/gudhi/Points_off_io.h>
Public Member Functions | |
| void | init (int dim, int num_vertices, int num_faces, int num_edges) |
| Off_reader visitor init implementation.  More... | |
| void | point (const std::vector< double > &point) |
| Off_reader visitor point implementation.  More... | |
| const std::vector< Point_d > & | get_point_cloud () const |
| Point cloud getter.  More... | |
  inline |
Point cloud getter.
  inline |
The init parameters are set from OFF file header. Dimension value is required in order to construct a vector of points.
| [in] | dim | space dimension of vertices. |
| [in] | num_vertices | number of vertices in the OFF file (not used). |
| [in] | num_faces | number of faces in the OFF file (not used). |
| [in] | num_edges | number of edges in the OFF file (not used). |
  inline |
The point function is called on each vertex line from OFF file. This function inserts the vertex in the vector of points.
| [in] | point | vector of vertex coordinates. |
Point_d must have a constructor with the following form:
