10#ifndef POINTS_OFF_IO_H_
   11#define POINTS_OFF_IO_H_
   13#include <gudhi/Off_reader.h>
   25template<
typename Po
int_d>
   28  std::vector<Point_d> point_cloud;
   41  void init(
int dim,
int num_vertices,
int num_faces,
int num_edges) {
   43    std::clog <<
"Points_off_visitor_reader::init - dim=" << dim <<
" - num_vertices=" <<
   44        num_vertices <<
" - num_faces=" << num_faces <<
" - num_edges=" << num_edges << std::endl;
   47      std::cerr <<
"Points_off_visitor_reader::init faces are not taken into account from OFF file for Points.\n";
   50      std::cerr <<
"Points_off_visitor_reader::init edges are not taken into account from OFF file for Points.\n";
   69    std::clog <<
"Points_off_visitor_reader::point ";
   70    for (
auto coordinate :
point) {
   71      std::clog << coordinate <<
   73    std::clog << std::endl;
   76    point_cloud.push_back(Point_d(
point.begin(),
point.end()));
   80  void maximal_face(
const std::vector<int>& face) { }
  121template<
typename Po
int_d>
  133    std::ifstream stream(name_file);
  134    if (stream.is_open()) {
  137      valid_ = off_reader.
read(off_visitor);
  142      std::cerr <<
"Points_off_reader::Points_off_reader could not open file " << name_file <<
"\n";
  164  std::vector<Point_d> point_cloud;
OFF file reader top class visitor.
Definition: Off_reader.h:29
bool read(OffVisitor &off_visitor)
Read an OFF file and calls the following methods :
Definition: Off_reader.h:51
OFF file reader implementation in order to read points from an OFF file.
Definition: Points_off_io.h:122
Points_off_reader(const std::string &name_file)
Reads the OFF file and constructs a vector of points from the points that are in the OFF file.
Definition: Points_off_io.h:131
const std::vector< Point_d > & get_point_cloud() const
Point cloud getter.
Definition: Points_off_io.h:158
bool is_valid() const
Returns if the OFF file read operation was successful or not.
Definition: Points_off_io.h:150
OFF file visitor implementation according to Off_reader in order to read points from an OFF file.
Definition: Points_off_io.h:26
void point(const std::vector< double > &point)
Off_reader visitor point implementation.
Definition: Points_off_io.h:67
void init(int dim, int num_vertices, int num_faces, int num_edges)
Off_reader visitor init implementation.
Definition: Points_off_io.h:41
Point cloud getter.
Definition: Points_off_io.h:89
