The concept TriangulationForManifoldTracing describes the requirements for a type to implement a triangulation class used for example in Manifold_tracing.
More...
#include <concept/Coxeter_triangulation/TriangulationForManifoldTracing.h>
typedef | Simplex_handle |
| | Type of the simplices in the triangulation. Needs to be a model of the concept SimplexInCoxeterTriangulation.
typedef | Vertex_handle |
| | Type of the vertices in the triangulation. Needs to be a random-access range of integer values.
◆ barycenter()
| Eigen::VectorXd Gudhi::coxeter_triangulation::TriangulationForManifoldTracing::barycenter |
const Simplex_handle & |
s | ) |
const |
Returns the Cartesian coordinates of the barycenter of a given simplex 's'.
- Parameters
| [in] | s | The input simplex given by permutahedral representation. |
◆ cartesian_coordinates()
| Eigen::VectorXd Gudhi::coxeter_triangulation::TriangulationForManifoldTracing::cartesian_coordinates |
const Vertex_handle & |
v | ) |
const |
Returns the Cartesian coordinates of the given vertex 'v'.
- Parameters
◆ locate_point()
template<class Point_d >
| Simplex_handle Gudhi::coxeter_triangulation::TriangulationForManifoldTracing::locate_point |
const Point_d & |
point | ) |
const |
Returns the permutahedral representation of the simplex in the triangulation that contains a given query point 'p'.
- Template Parameters
| Point_d | A class that represents a point in d-dimensional Euclidean space. The coordinates should be random-accessible. Needs to provide the method size(). |
- Parameters
| [in] | point | The query point. |
The documentation for this struct was generated from the following file:
