All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Searching...
No Matches
Gudhi::coxeter_triangulation::TriangulationForManifoldTracing Struct Reference
The concept TriangulationForManifoldTracing describes the requirements for a type to implement a triangulation class used for example in Manifold_tracing. More...
#include <concept/Coxeter_triangulation/TriangulationForManifoldTracing.h>
Public Member Functions
template<class Point_d >
Simplex_handle locate_point (const Point_d &point) const
 Returns the permutahedral representation of the simplex in the triangulation that contains a given query point 'p'. More...
Eigen::VectorXd cartesian_coordinates (const Vertex_handle &v) const
 Returns the Cartesian coordinates of the given vertex 'v'. More...
Eigen::VectorXd barycenter (const Simplex_handle &s) const
 Returns the Cartesian coordinates of the barycenter of a given simplex 's'. More...
Public Attributes
typedef Simplex_handle
 Type of the simplices in the triangulation. Needs to be a model of the concept SimplexInCoxeterTriangulation.
typedef Vertex_handle
 Type of the vertices in the triangulation. Needs to be a random-access range of integer values.
Detailed Description
Member Function Documentation
◆ barycenter()
Eigen::VectorXd Gudhi::coxeter_triangulation::TriangulationForManifoldTracing::barycenter ( const Simplex_handle s) const
Parameters
[in]sThe input simplex given by permutahedral representation.
◆ cartesian_coordinates()
Eigen::VectorXd Gudhi::coxeter_triangulation::TriangulationForManifoldTracing::cartesian_coordinates ( const Vertex_handle v) const
Parameters
[in]vThe input vertex.
◆ locate_point()
Simplex_handle Gudhi::coxeter_triangulation::TriangulationForManifoldTracing::locate_point ( const Point_d &  point) const
Template Parameters
Point_dA class that represents a point in d-dimensional Euclidean space. The coordinates should be random-accessible. Needs to provide the method size().
Parameters
[in]pointThe query point.
The documentation for this struct was generated from the following file:
