All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Searching...
No Matches
Gudhi::coxeter_triangulation::Manifold_tracing< Triangulation_ > Class Template Reference
A class that assembles methods for manifold tracing algorithm. More...
#include <include/gudhi/Manifold_tracing.h>
Public Types
typedef std::unordered_map< Simplex_handle, Eigen::VectorXd, Simplex_hash > Out_simplex_map
 Type of the output simplex map with keys of type Triangulation_::Simplex_handle and values of type Eigen::VectorXd. This type should be used for the output in the method manifold_tracing_algorithm.
Public Member Functions
template<class Point_range , class Intersection_oracle >
void manifold_tracing_algorithm (const Point_range &seed_points, const Triangulation_ &triangulation, const Intersection_oracle &oracle, Out_simplex_map &out_simplex_map)
 Computes the set of k-simplices that intersect a boundaryless implicit manifold given by an intersection oracle, where k is the codimension of the manifold. The computation is based on the seed propagation — it starts at the given seed points and then propagates along the manifold. More...
void manifold_tracing_algorithm (const Point_range &seed_points, const Triangulation_ &triangulation, const Intersection_oracle &oracle, Out_simplex_map &interior_simplex_map, Out_simplex_map &boundary_simplex_map)
 Computes the set of k-simplices that intersect the dimensional manifold given by an intersection oracle, where k is the codimension of the manifold. The computation is based on the seed propagation — it starts at the given seed points and then propagates along the manifold. More...
 Manifold_tracing ()
 Empty constructor.
Detailed Description
template<class Triangulation_>
class Gudhi::coxeter_triangulation::Manifold_tracing< Triangulation_ >
Template Parameters
Triangulation_The type of the ambient triangulation. Needs to be a model of the concept TriangulationForManifoldTracing.
Examples
cell_complex_from_basic_circle_manifold.cpp, manifold_tracing_custom_function.cpp, and manifold_tracing_flat_torus_with_boundary.cpp.
Member Function Documentation
◆ manifold_tracing_algorithm() [1/2]
template<class Triangulation_ >
void Gudhi::coxeter_triangulation::Manifold_tracing< Triangulation_ >::manifold_tracing_algorithm ( const Point_range &  seed_points,
const Triangulation_ &  triangulation,
const Intersection_oracle &  oracle,
Out_simplex_map interior_simplex_map,
Out_simplex_map boundary_simplex_map
inline
Template Parameters
Point_rangeRange of points of type Eigen::VectorXd.
Intersection_oracleIntersection oracle that represents the manifold. Needs to be a model of the concept IntersectionOracle.
Parameters
[in]seed_pointsThe range of points on the manifold from which the computation begins.
[in]triangulationThe ambient triangulation.
[in]oracleThe intersection oracle for the manifold. The ambient dimension needs to match the dimension of the triangulation.
[out]interior_simplex_mapThe output map, where the keys are k-simplices in the input triangulation that intersect the relative interior of the input manifold and the mapped values are the intersection points.
[out]boundary_simplex_mapThe output map, where the keys are k-simplices in the input triangulation that intersect the boundary of the input manifold and the mapped values are the intersection points.
◆ manifold_tracing_algorithm() [2/2]
Out_simplex_map out_simplex_map
inline
Template Parameters
Parameters
[out]out_simplex_mapThe output map, where the keys are k-simplices in the input triangulation that intersect the input manifold and the mapped values are the intersection points.
The documentation for this class was generated from the following file:
