All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::witness_complex::SimplicialComplexForWitness Struct Reference
The concept SimplicialComplexForWitness describes the requirements for a type to implement a simplicial complex, used for example to build a Witness_complex or Strong_witness_complex. More...
#include <concept/Witness_complex/SimplicialComplexForWitness.h>
Public Types
typedef unspecified Simplex_handle
typedef unspecified Insertion_result_type
 Return type of an insertion of a simplex.
Public Member Functions
Simplex_handle null_simplex ()
 Returns a Simplex_hanlde that is different from all simplex handles of the simplices.
std::size_t num_vertices ()
template<typedef Input_vertex_range>
Insertion_result_type insert_simplex (Input_vertex_range const &vertex_range, Filtration_value filtration)
 Inserts a simplex with vertices from a given range 'vertex_range' in the simplicial complex. The function is only used in Witness_complex class and by construction, it is not necessary to check if the faces are in the simplicial complex before insertion. The simplex is given the filtration value 'filtration'. Filtration_value should be convertible from double. The return type is not used.
template<typedef Input_vertex_range, typedef Filtration_value>
Insertion_result_type insert_simplex_and_subfaces (Input_vertex_range const &vertex_range, Filtration_value filtration)
 Inserts a simplex and all its faces with vertices from a given range 'vertex_range' in the simplicial complex. The function is only used in Strong_witness_complex class. All inserted simplices are given the filtration value 'filtration'. Filtration_value should be convertible from double. The return type is not used.
Simplex_handle find (Input_vertex_range const &vertex_range)
 Finds a simplex with vertices given by a range. More...
void set_dimension (int dimension)
 Sets the dimension of the simplicial complex to 'dimension'.
double filtration (Simplex_handle sh)
 Returns the filtration of the simplex given by the simplex handle 'sh'.
Detailed Description
Member Typedef Documentation
◆ Simplex_handle
Handle to specify a simplex.
Member Function Documentation
◆ find()
Simplex_handle Gudhi::witness_complex::SimplicialComplexForWitness::find ( Input_vertex_range const &  vertex_range)
If a simplex exists, its Simplex_handle is returned. Otherwise null_simplex() is returned.
◆ num_vertices()
std::size_t Gudhi::witness_complex::SimplicialComplexForWitness::num_vertices ( )
Returns the number of vertices in the simplicial complex
The documentation for this struct was generated from the following file:
