All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
Gudhi::witness_complex::Witness_complex< Nearest_landmark_table_ > Class Template Reference
Constructs (weak) witness complex for a given table of nearest landmarks with respect to witnesses. More...
Public Member Functions
 Witness_complex (Nearest_landmark_table_ const &nearest_landmark_table)
 Initializes member variables before constructing simplicial complex. More...
template<typename SimplicialComplexForWitness >
bool create_complex (SimplicialComplexForWitness &complex, double max_alpha_square, std::size_t limit_dimension=std::numeric_limits< std::size_t >::max()) const
 Outputs the (weak) witness complex of relaxation 'max_alpha_square' in a simplicial complex data structure. More...
Detailed Description
template<class Nearest_landmark_table_>
class Gudhi::witness_complex::Witness_complex< Nearest_landmark_table_ >
Template Parameters
Nearest_landmark_table_needs to be a range of a range of pairs of nearest landmarks and distances. The class Nearest_landmark_table_::value_type must be a copiable range. The range of pairs must admit a member type 'iterator'. The dereference type of the pair range iterator needs to be 'std::pair<std::size_t, double>'.
Examples
example_nearest_landmark_table.cpp.
Constructor & Destructor Documentation
◆ Witness_complex()
template<class Nearest_landmark_table_ >
Gudhi::witness_complex::Witness_complex< Nearest_landmark_table_ >::Witness_complex ( Nearest_landmark_table_ const &  nearest_landmark_table)
inline
Records nearest landmark table.
Parameters
[in]nearest_landmark_tableneeds to be a range (one entry per witness) of sorted ranges of pairs of nearest landmarks and distances. The class Nearest_landmark_table_::value_type must be a copiable range. The range of pairs must admit a member type 'iterator'. The dereference type of the pair range iterator needs to be 'std::pair<std::size_t, double>' where the first element is the index of the landmark, and the second its (squared) distance to the witness.
Member Function Documentation
◆ create_complex()
bool Gudhi::witness_complex::Witness_complex< Nearest_landmark_table_ >::create_complex ( SimplicialComplexForWitness complex,
std::size_t  limit_dimension = std::numeric_limits<std::size_t>::max()
) const
inline
The function returns true if the construction is successful and false otherwise.
Parameters
[out]complexSimplicial complex data structure compatible which is a model of SimplicialComplexForWitness concept.
[in]max_alpha_squareMaximal squared relaxation parameter.
[in]limit_dimensionRepresents the maximal dimension of the simplicial complex (default value = no limit).
The documentation for this class was generated from the following file:
