All Classes Files Functions Variables Typedefs Enumerations Enumerator Friends Modules Pages
FilteredComplex Struct Reference
The concept FilteredComplex describes the requirements for a type to implement a filtered cell complex, from which one can compute persistent homology via a model of the concept PersistentHomology. More...
#include <concept/Persistent_cohomology/FilteredComplex.h>
Public Types
typedef unspecified Simplex_handle
 Handle to specify a simplex.
typedef unspecified Filtration_value
 Type for the value of the filtration function. More...
typedef unspecified Indexing_tag
 Specifies the nature of the indexing scheme. More...
typedef unspecified Boundary_simplex_iterator
 Iterator on the simplices belonging to the boundary of a simplex. More...
typedef unspecified Boundary_simplex_range
 Range giving access to the simplices in the boundary of a simplex. More...
typedef unspecified Filtration_simplex_iterator
 Iterator over all simplices of the complex in the order of the indexing scheme. More...
typedef unspecified Filtration_simplex_range
 Range over the simplices of the complex in the order of the filtration. More...
Public Member Functions
Simplex_handle null_simplex ()
 Returns a Simplex_handle that is different from all simplex handles of the simplices.
size_t num_simplices ()
 Returns the number of simplices in the complex. More...
int dimension (Simplex_handle sh)
 Returns the dimension of a simplex.
Filtration_value filtration (Simplex_handle sh)
 Returns the filtration value of a simplex. More...
Simplex_handle simplex (size_t idx)
 Returns the simplex that has index idx in the filtration. More...
Boundary_simplex_range boundary_simplex_range (Simplex_handle sh)
 Returns a range giving access to all simplices of the boundary of a simplex, i.e. the set of codimension 1 subsimplices of the Simplex. More...
Filtration_simplex_range filtration_simplex_range ()
 Returns a range over the simplices of the complex in the order of the filtration. More...
Map interface
Conceptually a std::unordered_map<Simplex_handle,std::size_t>.
typedef unspecified Simplex_key
 Data stored for each simplex. More...
Simplex_key null_key ()
 Returns a constant dummy number that is either negative, or at least as large as num_simplices(). Suggested value: -1.
Simplex_key key (Simplex_handle sh)
 Returns the number stored for a simplex by assign_key. More...
void assign_key (Simplex_handle sh, Simplex_key n)
 Store a number for a simplex, which can later be retrieved with key(sh). More...
Detailed Description
Member Typedef Documentation
◆ Boundary_simplex_iterator
value_type must be 'Simplex_handle'.
◆ Boundary_simplex_range
.begin() and .end() return type Boundary_simplex_iterator.
◆ Filtration_simplex_iterator
'value_type' must be 'Simplex_handle'.
◆ Filtration_simplex_range
.begin() and .end() return type Filtration_simplex_iterator.
◆ Filtration_value
typedef unspecified FilteredComplex::Filtration_value
Must be comparable with <.
◆ Indexing_tag
typedef unspecified FilteredComplex::Indexing_tag
is model of IndexingTag.
◆ Simplex_key
typedef unspecified FilteredComplex::Simplex_key
Must be an integer type.
Member Function Documentation
◆ assign_key()
void FilteredComplex::assign_key ( Simplex_handle  sh,
Simplex_key  n
This is never called on null_simplex().
◆ boundary_simplex_range()
Boundary_simplex_range FilteredComplex::boundary_simplex_range ( Simplex_handle  sh)
If the simplex is [v0,,vd], with canonical orientation induced by v0<<vd, the iterator enumerates the simplices of the boundary in the order: [v0,,vi^,,vd] for i from 0 to d
We note that the alternate sum of the simplices given by the iterator gives the chains corresponding to the boundary of the simplex.
◆ filtration()
Filtration_value FilteredComplex::filtration ( Simplex_handle  sh)
If sh is null_simplex(), returns the maximal value of the filtration function on the complex.
◆ filtration_simplex_range()
Filtration_simplex_range FilteredComplex::filtration_simplex_range ( )
◆ key()
Simplex_key FilteredComplex::key ( Simplex_handle  sh)
◆ num_simplices()
size_t FilteredComplex::num_simplices ( )
Does not count the empty simplex.
◆ simplex()
Simplex_handle FilteredComplex::simplex ( size_t  idx)
This is only called on valid indices.
The documentation for this struct was generated from the following file:
